Old Nov 08, 2011, 05:01 AM
PLD is online now
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Build Log
PLD-BESJ5AR: 5A linear regulator with alarm, switchjack, voltage readout, decoupling
This one has been sitting in my "might build" archive for a loooooong time.
It's a 3A or 5A linear regulator with voltage readout and alarm and electronic switchjack.
The 3A/5A difference comes from the selection of the actual regulator chip. The 3A units are a little bit cheaper but will shutdown sooner, the 5A ones are about double the price but give you more headroom. Ultimately at a -constant- current both will shut down from thermal effects before they run out of current ability. MOST R/C flight gear setups however will not be consuming 3 or 5A constantly - most are 0.3~1.0A average.
The back of this unit will have a 21x21mm heatsink attached, this will give us about 6'C/W cooling which means for the "typical" 50'C allowance that's almost 10W of dissipation - or 2V drop @ 5A (eg, 5V from 7V), so we've got a reasonable amount of margin there.
Hoping this one takes off in the market, as it's a nice compact unit, only 50 x 22mm ( 2 x 0.86" ) but should deliver solid power with very low noise.
Features:
  • Accepts A123, Lipo, Lilion
  • Extremely low loss switch MOSFET (0.075W loss)
  • Voltage readout via LED
  • Power good LED
  • Dual regulated power output headers, allows for cable failure or higher current delivery to RX or dual RXs
  • Audiable alarm available for Lipo version ( else generic alarm at ~6.2V input below which unit ceases to correctly regulate)
  • super compact, 50x22mm
Will take a single supply in from A123 or Lipo, provides dual outputs
Paul.
PLD is online now Find More Posts by PLD
Old Nov 11, 2011, 02:02 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
PCB has been put in to production by the factory, probably 4~5 days and they'll ship it.
Old Nov 11, 2011, 11:44 AM
Dan Zero-G is offline
Find More Posts by Dan Zero-G
France, PACA, Aix-en-Provence
Joined Dec 2007
I am following this with great interest.
I would love to see some test results simulating F3J style loading with six powerhungry digital servo's and a 2s LiFE battery.
Peak load (launch, so servo's under heavy load or continuous stop start motion for all servo's - simulating butterfly deployment) 5A for 20 seconds (just for conservative check) and continuous load of around 300 mA and look for the voltage output and temperature changes (with no cooling, as we have to enclose them in our fuselages).
I love the dual output cables. I would hope the input cable is of a slightly larger cross section.
Also, please let us know the total weight ready to go.
Dan Zero-G is offline Find More Posts by Dan Zero-G
Old Nov 11, 2011, 06:14 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Belginique,
It will be interesting to see how it holds up. There will be a 21x21mm pinhead heatsink on the back side (in part that is why there are so many holes under the regulator, so that it provides a better thermal conduction path when they're filled with solder).
The input leads will likely be 20AWG high-flex silicon wire, which should be ample for the capabilities of the system.
Old Nov 12, 2011, 01:29 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Small update - I was looking around today at some cooling options and I've noticed I can get 20x20x10mm fans that only need 80mA of power and run off 5V, I was thinking that could be a nice addition for some people, they're not the cheapest fans around but it would add to the constant current handling ability (more than the increase that the 80mA for the fan would take).
Old Nov 12, 2011, 07:16 AM
Mathelo is offline
Find More Posts by Mathelo
USA, CT, Stamford
Joined Jun 2006
What is the highest peak load that one could expect in this scenario?
Louis
Mathelo is offline Find More Posts by Mathelo
Old Nov 12, 2011, 07:28 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Actually looking forward to getting more data on things like this when I receive the circuit boards for the servo-logger.
Old Nov 12, 2011, 11:22 AM
Joined Dec 2007
Louis
That is a good question. There is a lot of theories around, but not much solid data. The best I could find was a post by Tuan, it is actual real-life data: http://www.rcgroups.com/forums/showp...&postcount=224
It shows flight loggin of an entire flight with a 2s LiFE pack unregulated. Peak loading during launch is about 3.5 Amps (but he takes 10 samples a second, so there could be some missing data). However, I think it means that a conservative estimate of max 5 Amps is not unrealistic.
Another thing is the stop / start current of digitals, but one would have to be very agressive on the sticks to have all servo's peaking at the same time (is my opinion anyway).
Old Nov 12, 2011, 07:09 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
That's some good data there. Considering that the 5A version will be able to handle 7.5~10A peaks it does give a reasonable safety overhead.
Interesting to note that for the rest of the flight the average is almost always under 1A.
Old Nov 13, 2011, 07:11 AM
Mathelo is offline
USA, CT, Stamford
Joined Jun 2006
Thanks! That is helpful.
Old Nov 15, 2011, 10:05 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Received notice that the PCBs have now been shipped... 2wks delivery now to wait :\
Old Nov 23, 2011, 11:18 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
The boards arrived today, they look good - will try get one built up tonight to test the performance.
Not really expecting any surprises here.
Paul.
Old Nov 24, 2011, 05:49 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
PLD-BAC-ESJ-3AR up and running
Some pictures of the newly built PLD-BAC-ESJ-3AR (yes, I know, the names are getting longer )
Size: 50 x 23 x 16mm
Weight: 9g
Battery input: 2S lipo or A123
Alarm point: 6.2V
Regulated output: 5.0V
Current: 3A
Old Nov 24, 2011, 11:40 AM
Joined Dec 2007
It would be great to see some test data giving it a hard time, simulating peak loading for 10-30 seconds of 5 amps then 10 minutes of 2 amps and then another minute of 5 amps for 1--30 seconds with no airflow to provide cooling and see how the voltage holds up and what the temperature fluctuations are.
Also simulated results for a spike of 10 amps if a couple of servo's would be seized up, just to see if it would survive such a beating.
It can't get much tougher than that for a F3J glider anyway.
It does look very pretty in any case!
Old Nov 24, 2011, 07:01 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I think the task for this weekend is to build up a suitable load & test generator for these new regulators.
New Product BAC-ESJ: lipo 5V regulator with voltage alarm, readout, charge port and switch PLD Slope 3 Aug 17, 2014 08:08 PM
Help! LiPo Reg PLD-BAC-ESJ-LMA Tmark65 Hand Launch 3 May 02, 2011 02:47 AM
New Product 2S280-12C slim lipos (for use with BAC and BAC-ESJ units) PLD Hand Launch 1 Aug 13, 2009 03:51 AM
Cool DL50 with a PLD BAC-ESJ neilmny Hand Launch 27 May 10, 2009 03:20 AM
