Old Nov 07, 2011, 07:33 PM
bpkdasbaum is offline
Find More Posts by bpkdasbaum
Joined Nov 2011
Help!
Need help adjusting balancer charger circuit for 2x LiPo
Hi,
I would like to request some help with a circuit: I am currently following these 2 guides here for a netduino LED circuit powered by 2 LiPo batteries.:
Original Guide Hackerspace/Coding4fun
Thundergod Guide using netduino mini
But from what I found out so far about LiPo charging ... the solution for the charger in the circuit I currently have is not very safe and quite old (design from 2004 or something like that)
Here is the original design of the whole circuit:
From the original I need to alter the following:
- balance charger for LiPos
- add more LEDs: 50 total now (easy and already updated in the new schematic below)
- add a step down module from 7,4V to 5V: original design was used with a netduino, but i use a "netduino mini" to fit everything into a smaller space and the netduino can only handle 200mA ... so I have to route a seperate power supply to the max7219 instead of using the netduinos 5v output
- remove the charging pins (probably will simply add a small sized connector to the disk instead)
Here is a download (Eagle .sch) and an image of the whole circuit I currently have:
I hope the charge detection part can stay as it is, but I wouldn't mind if it had to go. Ideally the circuit would be able to charge and still power the LED circuit, so I could use the disc as an ambient light at home ... i guess it is possible since most cellphones work that way (still work while beeing attached to a charger).
General Data that might be relevant:
requirements:
LEDs 50x20mA = 1000mA
netduino ~80mA
max7219 ~80mA
step down module ??? afaik there is some loss here during converting
Lipo Battery I wanted to use: 2x 850mah 2c 3.7V
Oh and almost forgot to mention: I did search the forums (as well as via google) but I could not find any premade solution in form of a breakout charger or similar, only for single cell ... did find some balancers and chargers here on the forums (also read the lipo stickies) but they were 4.2V or seemed to have other usages that wouldntt fit the circuit i need ... Also I have no clue about electronics, but I learned quite a lot about general stuff in the last week
So after that long introduction: Can anyone provide or point me towards a circuit I could use please?
Any help appreciated and thanks in advance
Edit: I already got a suggestion on the netduino forums to use 2x premade single cell charger, which I will do if all else fails, but I would prefer a circuit that works while beeing charged, similar to the one in the original deisgn
Edit 2: found a balance charge on the forums and was suggest to adjust it for my circuit new schematic and eagle file below)
bpkdasbaum is offline Find More Posts by bpkdasbaum
Old Nov 08, 2011, 05:16 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I bet yyou have no idea that there is a forum area just for such DIY electronics projects.
http://www.rcgroups.com/diy-electronics-199/
Charles
Old Nov 08, 2011, 07:11 AM
Joined Nov 2011
true, i have no idea, thought since i have a battery problem i post it in the battery forum
but thx ill check the forum section out you mentioned
if a mod reads this and my post does not fit here, please move it
edit: reported thread to be moved to the DIY section
Old Nov 10, 2011, 10:16 AM
Joined Nov 2011
Update:
Can anyone tell me if it will work like this? I was already told i need to "adjust/change the resistors divider of LM2577" in the charging circuit , no idea how to do that yet is that done by the potentionmeter? and all the other resistors can stay as they are?
eagle schematic here
Old Nov 10, 2011, 02:08 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
The first thing you need to understand is that 7.4V is the nominal voltage. The operating voltage range of a lipo cell goes from 4.2V when fully charged down to around 3V which is the lowest voltage they should ever be discharged to. Lipos are charged to 4.2V per cell so any lipo 2 cell balance charger would charge them just fine.
Have you built that charger circuit yet? It seems extremely complex for someone with "no clue about electronics", and, I see at least a couple problems with it. You would be much better off just buying a 2 cell lipo balance charger.
jeffs555 is offline Find More Posts by jeffs555
Old Nov 10, 2011, 04:20 PM
Joined Nov 2011
thx for the info about the nominal voltage
and nope, didnt build it yet, only trying to figure out how to charge my batteries ... throwing ideas around and so on ... and the charger is a copy paste from another thread here (altered it from 3 modules down to 2), i asked the guys involved in the making of it, they said it could be used for my circuit.
another scource actually discoureged me from using that circuit though, since it is rather complex.
I was also told to go the IC route. There are supposed to be easy usable ICs for lipo dual cell charging. Guess I have to find one, any recommendations are welcomed
Old Nov 10, 2011, 11:03 PM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
"Also I have no clue about electronics"
I would stay well away from a DIY Lipo charger then.
Lipo charging needs great care to reduce the substantial risk of serious fires if it goes wrong.
Very definetly NOT a beginners project.
Where are you based, no where near me I hope ?
srnet is offline Find More Posts by srnet
For Sale Hirobo 7.4v Charger (stock) + 1 lipo 7.4v 480mah glhelinski Aircraft - Electric - Helis (FS/W) 3 Nov 02, 2010 03:59 PM
Sold Hirobo 7.4v Charger (stock) + 1 lipo 7.4v 480mah glhelinski Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 17, 2010 04:20 PM
For Sale e flite 7.4v balance charger &7.4v lipo for sale newtohelis Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 20, 2009 06:31 PM
Discussion Eflite 2cell 7.4V Li-Po balance charger melw Batteries and Chargers 3 Dec 10, 2008 05:37 PM
For Sale e flite balance charger for 7.4v batteries newtohelis Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 26, 2008 01:12 PM
