tolice
Some time ago I did make an educational! video, use headphones to hear the engine! http://www.youtube.com/watch?feature...&v=MBvtbA0wp3k I do fly this Taurus for nearly 600 flights now. Nearly 4 kg and MVVS 10CCM so to compare with your PT60 In the slow motion you can see the front leg in detail and when of good design it can withstand a lot of deformation. Have attention for 2min 51sec. The speed in touch and go maneuvers is 40 km/h, is 25 mph. I fly both, nose wheel and tailwheel. With a nosewheel it is easy to keep the track and nose over nearly isn't possible as you can see in the video!! Important is the length adjustment for grass or plaved runways, for grass the noseleg normally has to be longer. A well designed tricycle undercarriage also prevents to take off with too low speed. There is more to tell about differences! The easy way, a taildragger is more complicated in take-off and landing than a tricycle. If you want to know more differences, let me know. Cees |
Latest blog entry: Pics of the Side Pocket pattern kit for...
I upgraded to a Sullivan S865 nose gear in my 71" Hobbistar and it's been great. You can see it clearly here:
tolice,
Learn how to land is learn how to fly a circuit, Only then you have the references to start the final glide path on right altitude and distance in the wind conditions of that day. My golden rules Learn to fly the circuit a way you always can reach the field when the engine quits. Of course the first flights of the day and not when it's too late. After that, try to prevent to fly on a location and altitude that you cannot reach the field when the engine quits. Third practice to land the plane on any moment by idling the engine. Fourth, practice to land the plane on any moment by idling the engine. In the end, practice to land the plane on any moment by idling the engine. Of course, start these procedures with the maiden flight and not after you did destroy and repair the first set of undercarriage. Keep in mind, there are not much possibilities to reduce the speed when you start the final glide path on a too high position. When the speed is too high you cannot make a touchdown on the mains. Another video to show a normal touch down on the mains: http://www.youtube.com/watch?feature...&v=mK8TGW-fL44 This Taurus is 68 1/2 inch span and powered with an OS Max 35 engine. So a full multi pattern plane with same span as your PT-60 trainer but half the power?? Maybe your biggest problem isn't the undercarriage but the power in idle position and weight of the plane. Result often is, you cannot reduce the speed to make a decent touch down on the mains because the plane is overpowered and too heavy! Let me know what you think about that! Cees |
tolice,
First Taurus 10 pounds with fuel, second about 6 pounds, yours 8,5 (maybe with fuel 9) pounds and that’s heavy IMO. It is possible to compare some data but there are two important facts to count with. First the Taurusses do have their CG high located in the fuselage. low wingers, your plane the CG low positioned and wings on top. That's makes it more difficult for you to maneuver in final glide. Second important fact is, the wings of these Taurusses are thick (19 %) so I can reduce the speed without a risk of stalling but more important, there is also a lot of drag generated by these wings. When the plane is light of weight and the wings thick the speed automatically is reduced by drag in the glide path. So I even can start a final glide in some high positions. Also I can fly these Taurusses with high angle of attack and in that case there is much more drag of tailcone etc Your plane is heavy and drag is low so starting the final on a too high position can give you problems. The speed will increase while trying to lower the altitude as result of high wing load and low drag. So depending of wind speed it is important for you trying to find out the optimum position to start final glide with throttled engine. If the approach isn't alright, power and try again the complete circuit for learning the process. For me this is the only way to do and, if completed, you will be content with the results. The pictures. This is the nose leg of the heaviest Taurus and the pivot block is made of steel plate and bushing. 15 kgf or 147 Newton or 33 pounds was needed to press down the nose as visible on the picture for about 45 degrees without any negative result. That force nearly is 3.5 times the weight. At this pressure of course the wheel isn’t rolling anymore which is visible on that moment in the video of post 4, on moment 2min 51sec , in that case the leg will bent more until the wheel gets his space to escape. The nose wheel is made of massive nylon, not the mains, these are of normal construction. Of course normally this isn’t needed but it shows what sometimes is needed and possible. Success Cees |
I wouldn't push too hard on the "learn how to fly/land" shpeal. My club field is like it was carpet bombed. It's so-called astrotuf and is covered in giant bumps and potholes. To top it off it's held down with giant bolts with a line of them running right down the center. A perfect landing can still beat up a plane.
Don't shoot the messenger, this is a joke
Often we of Old School have to think very very elementary, for example in this case. Is Dream Archer right? As normally I do take a look in the personal attachements (pictures) and find this one (really!) and than its clear. "Dream Archer, this forum is about aeromodeling, wake up!" Compensation. Because I also did read about the problems of your P47 tailwheel, a picture, of my Orion, bom crater safe. Maybe you can use the idea = transfer know-how. Cees |
| Thread Tools | |
| Discussion Actual Photos of Carl Goldberg Small/Medium Tail Wheel Build and Installation | ChrisFlysRC | Scale Fuel Planes | 1 | Oct 06, 2011 04:57 PM |
| For Sale light weight retractable tail wheel or nose gear!!! | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 0 | Sep 23, 2011 09:24 PM |
| Sold light weight retractable tail wheel!!! | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 0 | Sep 09, 2011 08:43 AM |
| Discussion Fixed tail wheel or movable on tail dragger | tyra | Fuel Plane Talk | 11 | Aug 26, 2011 03:33 PM |
| Help! ZH Racing Front Wheel for GPV-1 | hutchy46 | Motorcycles | 3 | Aug 05, 2011 10:39 AM |
