Art-Tech Falcon 400 Beginner/Novice 3D CCPM Helicopter Review
Overview:
The helicopter looks really nice with its red, white and blue canopy. This is a 400 size helicopter and is 24 inches long. It’s the largest helicopter with a 45 degree flybar that offers the agility of a CCPM helicopter. The landing gear is sturdy and attaches directly to the frame. The user manual is well written and isn’t written in Chinglish!! Also included in the box is a CD containing simulator software. You also get a simulator cable that plugs into the transmitter. There is also a transmitter manual and simulator manual. The heli manual contains an exploded diagram and disassembly instructions as well as a full parts list. The battery tray is part of the frame and limits your battery choices to batteries that are 1 ¼ inches wide or less. You can go taller and longer, but NO MORE WIDTH! The stock battery weighs 101 grams. I have a 25C 1500mah battery that fits in the tray and weighs 134 grams. Since the stock motor is brushed, I’ll have to stick with slightly shorter flights.
First Thoughts:
My actual first thought was, “Wow”! I mean, I’ve owned three or four 6 channel CCPM helicopters and I was always terrified to spool them up in the house and even attempt a hover. Without doing anything, I plugged in the battery and spooled the Falcon up. Seconds later it was floating in my small upstairs office. Don’t get me wrong, I was fighting it. The helicopter was not at all trimmed out, so I only hovered it for about 20-30 seconds before bringing it down safely. Although the heli was nicely packaged and looked beautiful, I was expecting it to be setup right out of the box. It is, after all, a “Beginner Heli”. It would be nice if the heli flew tamely, right out of the box. Not the case here. The first thing I noticed is a swing right in the tail. Even with full left trim I was constantly correcting the rudder. I had to adjust the rudder servo and tail slider length to get the tail to hold with no transmitter trim. There was also a slight backwards drift. The swashplate wasn’t level. It was angled to the rear, which would explain the drift. I had to shorten the elevator linkage to level the swash in order to correct the drift. Only slightly disappointing, but this is an easy fix. At this point you have a great beginner setup and you could easily start with this heli instead of a fixed pitch helicopter. This may be a helicopter you can learn and grow with.
Tuning and Flying:
Besides the initial setup to trim out the helicopter, there really isn’t much to tune. This heli has turned out to be pretty easy and I am really getting to like this heli very much.
You have the option to fly with dual rates on or off which can limit the travel of the servos making the helicopter movements more or less dramatic. With high rates the rotor disk has a lot of travel (and now we have good control too) but the weighted flybar tends to negate or counteract some of this, as is the purpose to provide a co ax like feel of stability where the rotor disk will recover on its own due to the centrifugal force of the flybar. However the weights on the flybar are heavy and prevent quick changes of direction and finer level of control. If some less heavy flybar weights can be found you may get more fine control back. This may be an excellent and cheap future mod. Nice quick forward flight is possible and the heli flies really well. One major drawback is that when making a left to right turn with the nose going away from you, you will lose altitude. A lot of altitude. When making this turn I have to give almost full power to keep the Falcon from dropping to the ground. From what I understand, this happens when you don’t have enough power from the main motor. When the helicopter turns that way, the tail motor is requiring a large amount of power to make the turn. That takes power from the main and the result, in this helicopter, is altitude loss. The fix would be a more powerful motor that can handle the power loss when the tail needs it (see brushless upgrade below).
As for the 3D I can’t say much as I don’t fly 3D. The 3D mode works, but since I don’t fly 3D, I only tested it out. The TX doesn't have a throttle hold switch so crashing could be an issue b/c it'd be quite a task to flip the 3D switch, then drop the throttle to zero before the Falcon hit the ground. For those that do fly 3D and are used to simply hitting a throttle hold, getting used to this may be difficult. While in 3D mode, placing the throttle at center does have zero pitch. The only thing I can do is bounce the heli up and down going below and above center stick. That’s all I’m up for at the moment. This is a 3D trainer, so maybe I’ll give some light 3D a try soon.
Future Possibilities:
Servos: The servos all seem good. At this point I really don’t see a reason to upgrade.
Gyro: The gyro is huge! I’ve never seen such a large gyro. I don’t think it needs to be replaced, but it can. It certainly wouldn’t hurt to change it out.
Motor/ESC: Another modification you may want to think about is an upgrade to a brushless motor and ESC. As it sits, the Falcon 400 doesn’t get light on the skids until I’ve applied about 40-50% throttle. If I can figure out how to adjust the blade pitch, this may change, but right now I’m flying at 50-85% throttle to keep the Falcon 400 in the air. The Falcon 3D includes a brushless motor and ESC and I’ve ordered both. The upgrade costs $37 shipped and looks like a direct drop-in replacement. I will keep you posted on that upgrade in this thread.
Blades: Another future modification may be different blades. The stock blades are cheap and they seem brittle or at least easily deformed. The blades are foam, wrapped in white plastic. They are short too. Usually a 400 size helicopter would use 275mm blades. The blades on the Falcon 400 are only 248mm root to tip. There are many options out there for upgraded blades. There are wooden, carbon fiber, and fiber reinforced blades that range in size from 255mm to 315mm. I wouldn’t go more than 315mm. I ordered a number of blades, listed below with weights, lengths and results.
Stock 248mm (26.6g): You know the results if you’ve read this review.
Xtreme 275mm (53.4g): Too heavy to use unless the brushless upgrade is in your future.
Carbon Fiber 288m (36.5g): Heli flies just the same, but the motor gets hot faster. I’m going to need more power!
Stealth 315mm (49.5g): With the stock motor, it’s too much blade. The heli swings and the tail just can’t keep up.
Canopy: I’ve contacted Fusuno about their custom canopies, but they don’t make anything for Art-Tech helis and they offer no suggestions. The stock canopy is fine. It looks good and it’s made of a thick and durable plastic. I removed the decals with some Goo Gone and I like it. I’m sure the other canopies from the Falcon Perfect 3D and the Falcon 3D will work. I do have a V400D02 canopy that after making the same small cut as the stock canopy, fits like a glove!! That means that a custom Fusuno Canopy can be made for this helicopter!
Durability and Spare Parts:
Overall the heli seems pretty durable. The frame seems really solid and the skids have held up great with a few bounced landings.
Blades unfortunately, as previously mentioned seem to be a sore spot for this heli. They are soft and deform easily. I haven’t broken them yet, but I have had them deform after coming into contact with the blade grips and/or the ground. The tail blades are the same as the mains. No breakage yet and no deformity, but I can see it happening.
Right now it seems parts are easily available at Parkflyers.com. If you can’t find them there, Xheli has parts for the Falcon 3D. I believe that some of those parts will work on this heli too.
Conclusion:
While I have this heli setup to the point that I enjoy flying it, it still leaves you wanting more. It flies very much like a co-ax, and I would prefer the traditional head and flybar paddle setup as a trade off for the stability. It is still a good concept heli that fills a niche no other heli does. It’s easily setup to perform really well and will be a fun outdoor flyer that surpasses the performance of a co-ax and fixed pitch helicopter.
Where can you buy the Falcon 400 Beginner/Novice helicopter?
The only place I’m aware of in the US is that has this helicopter in stock is ParkFlyers.com. There are some places in China that sell them, but they are backordered or just not in stock.
I will be posting some video’s including some outdoor flight action next.
Hope this helps anyone considering this helicopter!
