Old Jan 26, 2012, 05:56 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
Scott Cuppello's Avatar
United Kingdom, England, Carlisle
Joined Mar 2007
Originally Posted by clive45 View Post
Hey Gaz, Its been a bit quiet on here recently.
Seems that HK got a whole swag of Hawk's or no one is buying them as they are still in stock?
We got a lot in, they are selling just fine!
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Jan 26, 2012, 06:07 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Gaz, I have just been looking at the 3 pics of your Jetfan 90 installation and am I correct you have removed the upper part of the bulkhead at the fan mounting. Has that weakened the sides or allow flexing or have you added some other reinforcing?
With the tape you used does it allow you to slide one tube into another before it grips or do you leave the colored strip on and pull it off when the tube has been pushed in etc.
the part I remover from memory was because I was going to fit a lander the ridge stopped me from sliding it forward into the ducting.my ducting from the front is flush with the fan mount so i put a double layer of tape on the jetfan where it needed to sit on the mount parellel the the fan edge and put a double layer on the rear wooden mount peeled the font tape slid the fan in using the tape as a stop the the rear tape can be peeled and the fan fully seated in the tape with zip ties.using mylar for the eflux meant I can collapse the tube and insert from the exhaust end.I actually had all of the front ducting in place and internally siliconed as to make sure of smooth sealed joints ages ago the only not fully seales point is where the esc is fitted this is to allow the air to flow into the to top intakes past the bec and batts and out into the main fan ducting flow.
Gaz-b is offline Find More Posts by Gaz-b
Old Jan 26, 2012, 06:09 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
You could send some to europe then after all it is an RAF scheme.
Old Jan 26, 2012, 06:56 AM
Joined Mar 2007
It will be there soon....lot's going on in UK at the mo.
Old Jan 26, 2012, 07:09 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Interesting UK not Germany
Old Jan 26, 2012, 09:28 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
The landing gear would be nice too.
alexandermh is offline Find More Posts by alexandermh
Old Jan 27, 2012, 08:00 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Has anyone had their Hawk in the air yet.........................?
clive45 is offline Find More Posts by clive45
Old Jan 27, 2012, 09:07 PM
vettster is online now
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Yes....When it was being delivered by airmail
I just started tinkering with mine. Ive rapped the intakes with CF tow.
vettster is online now Find More Posts by vettster
Old Jan 27, 2012, 09:49 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Good one Trevor
Didn't your have the clear spiral around it already...........
I have just go the front air ducts in and the joining piece cut to fit the fan, won't glue the front of the ducts to the fuse till I finally fit the fan.
I have cut a slot in the former behind the fan so I can slide the fan backward to remove it later as I am making my own thrust tube that can be fitted from the rear, otherwise it will be a damn hard job to get the fan out for repair etc.
I have also been building/modifying an All Flying Tail as per GazB's with a little change here and there. Servos are in the wing but I don't like the supplied linkages,they look good but I'm not sure I would trust them. The rods don't screw into the clevis because they are too thin. What do you intnd to do with yours.
Old Jan 28, 2012, 01:58 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
just wondering. Does the multiplex all moving rod work for this plane??? Thats a cheap and easy to find piece of hardware
There are two sizes available
pavcon is offline Find More Posts by pavcon
Old Jan 28, 2012, 02:50 AM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Pavcon, care to explain further, maybe a link..
Old Jan 28, 2012, 03:37 AM
pavcon is offline
Joined Jan 2010
http://www.modelmaniacsonline.co.uk/...k+(Pendel+Lock)
Old Jan 28, 2012, 03:39 AM
pavcon is offline
Joined Jan 2010
im sure there is a larger size also but i can't seem to find it now...
Old Jan 28, 2012, 03:53 AM
clive45 is offline
clive45's Avatar
Joined Mar 2006
Thanks for that pavcon, but the BAE Hawk has the AFT on the fuse not the tail fin so its too wide to use that idea, also it is down level with the thrust tube so you cannot go through the fuse without going through the thrust tube. Good thought tho
Old Jan 28, 2012, 06:41 AM
pavcon is offline
Joined Jan 2010
just a thought....
Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's FlyBoyTha1 Electric Ducted Fan Jet Talk 701 Mar 23, 2015 06:32 PM
Discussion HK 90mm BAE Hawk Build Thread! neversommer Electric Ducted Fan Jet Talk 33 Jan 23, 2012 02:21 AM
Discussion BAE Hawk Full Composite for 90mm EDF Kerberos Electric Ducted Fan Jet Talk 79 Oct 15, 2010 12:57 AM
Build Log ETM Signature Series Composite BAE Hawk 90mm FL62 Electric Ducted Fan Jet Talk 86 Jun 19, 2010 01:48 PM
