They come in 3 different sizes I believe...http://www.hobbyking.com/hobbyking/s...idProduct=6998
i suppose it would be losing its sleekness maybe a bit to much drag however i would only make them small
I think this post covers where you are at hook was 1/3 from CG or LE ? towards the nose.I use heavy duty horns as hooks they double as a skid.http://www.hobbyking.com/hobbyking/s...dProduct=10409. |
![]() ![]() On the weight issue. Yes the lighter the better.. everyone who flies RC planes knows that but you still need to have the right power set up and balance (CG). To get the right power to fly this Hawk then you will have to go over the suggest weight there is no other choice. The heavier the plane, the faster it will have to fly to stay airborne. and the finer is the line between flying well and loosing air speed and control, and this Jet will drop like a brick. You cannot afford to lose speed so you need to speed up to compensate for the loss when pulling up, banking flying downwind ect and this is where it gets very tricky and risky if you not 100% focused or an EDF begginer. Clive, I recommend you practice on a Simulator like phoenix and use a Jet like the Hawk, fly it all the way to the runway and try to land as fast possible without crashing. yes its not the real thing, but its the next best thing to smashing your Jets. This is how I practice and it really helps when I land my real EDFs. Another way, buy a foamy Hawk, add weight gradully so it becomes unstable when you dont fly it full ball, then practice until you feel you are ready for this one.
| Thread Tools | |
| Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 699 | Nov 13, 2012 07:17 AM |
| Discussion HK 90mm BAE Hawk Build Thread! | neversommer | Electric Ducted Fan Jet Talk | 33 | Jan 23, 2012 02:21 AM |
| Discussion BAE Hawk Full Composite for 90mm EDF | Kerberos | Electric Ducted Fan Jet Talk | 79 | Oct 15, 2010 12:57 AM |
| Build Log ETM Signature Series Composite BAE Hawk 90mm | FL62 | Electric Ducted Fan Jet Talk | 86 | Jun 19, 2010 01:48 PM |
