Old May 29, 2012, 08:50 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Got this plane on my radar as an upgrade from my slightly smaller Sapac Composite T-45 and I am noticing that you guys are builting this very heavy. Much more than the recommended 2.6-2.8Kg AUW.
The Sapac T-45 wing area is ~17.5dm2 vs the 24dm2 of this bird.
I fly mine on 1.7-1.8Kg AUW and it is super stable. Last weekend I tried a 100gr heavier battery and it started to become slightly challenging. Another 1-200gr and it would be a handfull.
I think most of the change in flying behaviour comes from the weight, too much control throws on elevator and ailerons and CoG too forward.
anlucas is online now Find More Posts by anlucas
Old May 29, 2012, 09:11 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
Originally Posted by Samjet View Post
Mine did the same When I earlier posted my comments about this jet's unstable flight charateristics, nobody was listening. I wasted 600 $. I just wonder why it hasn't become a well known fact that the hawk is a piece of
Originally Posted by phoenix racing View Post
Because....it isn't.
And you work for.......?
Samjet is offline Find More Posts by Samjet
Old May 29, 2012, 10:15 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Something I've noticed on a completely different airframe. I have a couple P3 F-16s. One is a real light set-up and it flies like a pussycat. Another has a heavier set-up and it flies so much more erratic. While we all know that the more weight for the same airframe increases the wing loading, it seems to me that the change is not linear. In other words, it doesn't fly just "heavier," but the increased weight changes the flying characteristics in fundamental ways. Reading the posts here, this seems to apply to the hawk. Thoughts?
alexandermh is offline Find More Posts by alexandermh
Old May 29, 2012, 11:34 AM
phily32 is offline
Find More Posts by phily32
phily32's Avatar
redcar cleveland uk
Joined Nov 2010
Originally Posted by Hixxer View Post
I was thinking of these for my T45 and grass is all I have, did the strut break? Please keep me posted if bigger wheels helped
Hi hix i dont think i will be bothering with wheels as the power system i,am using is increasing the auw to around 8.5lbs, I,am thinking of removing as much weight as possible and bungeeing im even considering increasing the motor for a higher kv and using less cells i will decide after ive weighed it retract free and anthing else i can bin cheers.
phily32 is offline Find More Posts by phily32
Old May 29, 2012, 11:42 AM
torque roll is offline
Find More Posts by torque roll
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Hobbyking. He's Scott from Hobbyking. You know, the cheerful funny guy we usually see in the Hobbyking Daily Videos?
torque roll is offline Find More Posts by torque roll
Old May 29, 2012, 11:52 AM
anlucas's Avatar
Joined May 2011
After 3 failed maidens,of a fiberglass warmliner(HTG Speedy), in exactly the same manner as most of the Hawk's stalls and spins, and after I mastered it on the slope without the motor running, I realised that with the heavier wingloading you need more air speed to provide level flight. Without a motor and on the slope, it needed 20mph of wind at least. At 18mph it could not fly.
When there is a strong tail wind, we may tend to reduce throttle because of the ground speed increase, the plane loses altitude and the unwary may tend to compensate with the elevator because the ground speed seems normal. If I had lots of elevator travel and used it, the the stall and spin would come abrubptly without warning with a tailwind.
With a headwind, there would be enought time to recover because of higher air speed which slows down the onset of the stall and the wing rocking left and right provides just enought warning.
Old May 29, 2012, 12:36 PM
Samjet is offline
Samjet's Avatar
Joined Mar 2010
Yes, That's my point.
Old May 29, 2012, 02:27 PM
phily32 is offline
phily32's Avatar
redcar cleveland uk
Joined Nov 2010
[QUOTE=anlucas
Hi i agree i can imagine that alot of these crashs are from the downwind runs to the final approach i always start with enough altitude reducing the throttle keeping the nose slightly down keeping a constant speed raising the nose is a killer. i see this mistakes all the time especially when people have moved on from foam models which will high alpha in to land these planes have to be flown in keeping a constant airspeed well that always works for me
Old May 29, 2012, 04:08 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
WOW it's amazing how the Chinese whispers work on these forums people seem to read what they want it flew great while I was looking at it stupidly I looked to make sure if I was clear of the runway.The weights given on the listing is not achievable mine built as light as poss less servos lighter tube no retracts very light motor fan combo and it was still over 2.6 KG without batts so with retracts would be well over the max listed 2.8 KG flying weight with batts is ay least .8 or so more.
Gaz-b is offline Find More Posts by Gaz-b
Old May 29, 2012, 04:23 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
There are many MANY videos of the exact same model in different colors being flown at the hands of pilots with intermediate to expert experience. It is NOT a piece of .... My suggestion to you is...get more experience and learn to fly better.
vettster is offline Find More Posts by vettster
Old May 29, 2012, 04:31 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
[QUOTE=phily32;21744112][QUOTE=anlucas
Hi i agree i can imagine that alot of these crashs are from the downwind runs to the final approach i always start with enough altitude reducing the throttle keeping the nose slightly down keeping a constant speed raising the nose is a killer. i see this mistakes all the time especially when people have moved on from foam models which will high alpha in to land these planes have to be flown in keeping a constant airspeed well that always works for me[/QUOTE]
Spoken by someone that knows what their doing. Good advise Philly
Old May 29, 2012, 04:45 PM
phily32 is offline
phily32's Avatar
redcar cleveland uk
Joined Nov 2010
hi gaz sorry for the misunderstanding but i was,nt talking about your crash, just talking about flying these type of planes in genral.
p.s i think the only way to get the weight down is to fly it on 6s higher kv motor?even then i cant see been much lighter.
Old May 29, 2012, 04:52 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Higher volts less amps for the same watts this had a10s s 2250 60c pack in it.
Old May 29, 2012, 05:03 PM
phily32 is offline
phily32's Avatar
redcar cleveland uk
Joined Nov 2010
2250mah packs, that would keep the weight down but what sort of flight times do u think you would have had?.Iam using 3850s didnt want to go any lower but also a higher kv motor will also reduce the flight times?.
p.s i.am also using a 1200kv motor
Old May 29, 2012, 05:12 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
That pack was not intended as the normal pack I was going to use 3300 s .On the maiden I wanted it as light as poss with the power to weight it had I don't think it would be consuming many amps. just looked up a test run 3.3 KW 90 A.
Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's FlyBoyTha1 Electric Ducted Fan Jet Talk 701 Mar 23, 2015 06:32 PM
Discussion HK 90mm BAE Hawk Build Thread! neversommer Electric Ducted Fan Jet Talk 33 Jan 23, 2012 02:21 AM
Discussion BAE Hawk Full Composite for 90mm EDF Kerberos Electric Ducted Fan Jet Talk 79 Oct 15, 2010 12:57 AM
Build Log ETM Signature Series Composite BAE Hawk 90mm FL62 Electric Ducted Fan Jet Talk 86 Jun 19, 2010 01:48 PM
