HK BAE Hawk 90mm EDF Composite 1140mm
I ordered mine today as well as a few others, Looks like we bought them all out in an hour or so. I got mine at 5:00am after getting a text from Vettster. So here is where will will start our build logs when they arrive. I didn't get the retracts and struts, By the time I found them they were gone. good luck everyone.
![]() Link to the HK retracts http://www.hobbyking.com/hobbyking/s...dproduct=19949 Notes, This was from the fist batch of kits. Your results may vary. ![]() -The supplied clevises don't fit the supplied rods. -Mounting area for nose gear needs to be beefed up a bit. -CG successful first flights have been done with the CG set at 105mm from lead edge -I m using these HK electric retracts. http://www.hobbyking.com/hobbyking/s...dproduct=14838 - |
http://www.rcgroups.com/forums/showthread.php?t=1336449
http://www.rcgroups.com/forums/showthread.php?t=1336098 I used HET 700-68-1500 with HET fan, running 8s-3300 packs. 5000 will be way too heavy. |
Latest blog entry: Multicopters
I actually used one of those main strut as the nose, with E-Flite 15-25 e-retracts. I didn't think the smaller nose strut would handle the weight of this plane. And after seeing the abuse it's getting on landings, I am glad I didn't use the nose strut. If I had another main strut, I'd replace all 3 of them. Right now I am using the stock wires on E-Flite retracts on the main. About 20 some landings and so far so good.
Waiting for somebody to have the CMP stock struts in stock... |
| Thread Tools | |
| Build Log Jet Teng Models Full Composite 90MM Bae Hawk V2 From RC-Warbirds Build & Video's | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 699 | Nov 13, 2012 07:17 AM |
| Discussion HK 90mm BAE Hawk Build Thread! | neversommer | Electric Ducted Fan Jet Talk | 33 | Jan 23, 2012 02:21 AM |
| Discussion BAE Hawk Full Composite for 90mm EDF | Kerberos | Electric Ducted Fan Jet Talk | 79 | Oct 15, 2010 12:57 AM |
| Build Log ETM Signature Series Composite BAE Hawk 90mm | FL62 | Electric Ducted Fan Jet Talk | 86 | Jun 19, 2010 01:48 PM |
