Old Nov 10, 2011, 12:25 AM
luzwingnut is offline
Find More Posts by luzwingnut
United States, TX, Palestine
Joined Oct 2007
Putting it all together... just testing the "idea" out. I still NEED to glue in some hardwood BETWEEN the wing spars to adequately support a TIGHT C.F spar fitting... then web the spars with lite-ply. (so much to do, yet)
I am building the center wing junction in sections.... then I'll cap it off with another rib#2 templated lite-ply rib. Wanna make sure I have enough "meat" to screw it all together in completed form.
Just about have all the main assy. put together now... just need to finish it all out... servo mounts in the wing, TRY to put together a "springy" landing gear system, on and on it goes!! I'll finish out the wing's center section tomorrow and get it bolted together and do a static lift "on the wing". (THAT section of the wing is CRITICAL for strength!!)
"DGCA..." (Dried Glue Chewers of America)
-Luz
luzwingnut is offline Find More Posts by luzwingnut
Old Nov 10, 2011, 12:38 AM
Joined Oct 2007
Pop QUIZ!!!
Anyone know what the term is for "negative" DIHEDRAL?? (The A-7 Corsair has "negative dihedral" in its design.)
ANSWER: ANHEDRAL
Old Nov 10, 2011, 01:16 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Wasn't she married to Fred Hedral?
Lnagel is online now Find More Posts by Lnagel
Old Nov 10, 2011, 01:53 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Also has a sister name of Anne, but she's a bit droopy
Family pet is a parrot - Polly, of course.
Dereck is offline Find More Posts by Dereck
Old Nov 10, 2011, 01:55 PM
Dereck is offline
Joined Dec 1996
On a technical note, the 'real' J3, and subsequent Cub-ish variants, have very slight dihedral. Probably to stop 'Ann Hedral' looks creeping in
One of the best laser cut Super Cub kits, alas now defunct, had no dihedral and it stuck out like the proverbial hammer-struck opposable digit.
Old Nov 11, 2011, 11:07 AM
tr6world is offline
Find More Posts by tr6world
Mike Brinker
tr6world's Avatar
SouthEast Michigan
Joined May 2008
She Is A Wonderful Flying Plane
Hello LZWNT,
Great build thread! I absolutely love this kit. The piper cub makes a wonderful addition to your hangar. I built my Carl Goldberg Anniversary Edition Piper Cub back in the 80's and then converted it to electric back in 2008. I have a couple of old youtube videos of me maidening the cub back in 2008 after the electric conversion if you want to view them. Let me know if you want me to post them on your thread or not or I can PM you the links. I don't want to hijack.
Here is my setup:
Motor: Scorpion Brushless Outrunner 3026-8 1212KV motor producing 1000 watts of power
Prop: 12" x 6" APC E
Speed Controller: Scorpion Commander 70 amp ESC
Batteries: 2 - 11.1V 4000 mah lipo 25C COPPER TAB HECELL that I paralleled together.
Keep up the great work. I look forward to seeing your maiden!
tr6world is offline Find More Posts by tr6world
Old Nov 11, 2011, 09:51 PM
Joined Oct 2007
Absolutely Mike!! Make yourself at home! Some vids. would be awesome. BTW... what was your AUW with the 6s set-up (3s X 2)? Great looking CUB, Mike!
Yesterday... well, I didn't do ANY building. Had to do some administratives. Today? Made alot of progress... but not too much building.
I am building a "Take apart" wing on this kit. My last update got a CF wing spar put in, BUT... I needed some "alignment" pegs forward and aft of the center wing panel CF spar build. So... I looked inside the box of wooden parts and made some alterations to accomplish this task.
Here's what I did (and it worked GREAT!!!):
(pics on my next replay... they tell the whole story)
Old Nov 11, 2011, 10:42 PM
Joined Oct 2007
Forward wing alignment: I suppose I could call the design a "fork and tongue alignment system" since that's what it is. It is NOT designed for flight load bearing weights... that is what the C.F. spar is for, but it IS robust and very strong. I used super glue to harden the plywood forks and polished them with some light sandpaper. I get a 100% "lock" with this and the alignment keeps the designed dihedral angle PERFECT!! I'll be using a simple dowel rod in the aft part of the wing rib for alignment to the center wing panel.
Old Nov 11, 2011, 10:50 PM
Joined Oct 2007
"Ann and Fred" Hedral??" Glad everyone is HAVING some fun, here!! Thanks everyone.
-luz
Old Nov 11, 2011, 11:00 PM
Joined Oct 2007
Tomorrow... I'll finish the center wing panel build and get the wing bolted together and finish the planking. Still deciding IF... I want to do an aileron "build-up" instead of using the aileron balsa stock. (Flaps may still happen... who knows) IF I DO... the built-up ailerons, I'll be doing barndoor flaps.... even IF they aren't scale "J3".
What would you all like to see done? Machine gun pods and rocket launchers aren't scale impliments for a CUB!!!
The Piper Cub IS quite popular, though... anyone know IF a "gyro-cub" has ever been built before? THAT would be interesting!!
Old Nov 12, 2011, 01:18 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
-luz
Don't forget their daughter Diane. But they just call her Di for short.
Great looking build. Following it with interest.
Larry
Old Nov 12, 2011, 03:02 AM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
Don't worry about the weight and everybody overpowers the J3. I learned to fly on the J3 60 years ago and bought the Berkley J3 kit in 1956. It was my first "Giant Scale" with a wingspan of about 72 inches. I believe Sig bought the rights for the Berkley kit when Berkley went out of business. The plans specifed a 15 but I overpowered mine with an Enya 19 and it wouldn't come down at idle. I had to wait unti the engine quit to land. It flew at scale speed even at idle. Almost all J3 models that I have seen fly far too fast and zipped around the sky at P51 speeds. The real J3 couldn't fly inverted without folding the wings. One advantage of heavy construction is being able to fly in the wind instead of haveing to wait for a calm day.
ChuckA is offline Find More Posts by ChuckA
Old Nov 12, 2011, 08:32 AM
Dereck is offline
Joined Dec 1996
'Best' J3 I had the misfortune to watch was bought by one of the Grande Iams of a big DC area EC club. His MO was to buy huge models, sell them soon after to the club's more affluent model buyers - and then still get to fly the, as the new owners couldn't.
Nice trick, if you can pull it off...
This 'model' - around 100" span - was usually seen in a hover atop a heck of a racket.
Different tack - was the clipwing J3 inverted capable? It's wing struttery is somewhat different and heftier than the regular span aircaft.
D
Old Nov 12, 2011, 09:21 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I would think that a bigger concern when flying a full size Cub inverted would be the oil system of the engine. It takes a special oil system to properly lube the engine during sustained inverted flight.
Larry
Discussion Carl Goldberg Piper Cub **neons** Glow to Electric Conversions 41 Feb 16, 2016 07:43 PM
Sold Vintage Carl Goldberg Anniversary Edition Piper Cub spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 4 Sep 20, 2011 10:51 PM
Sold CARL GOLDBERG Anniversary Piper Cub STARTED syed Aircraft - Fuel - Airplanes (FS/W) 0 May 01, 2011 09:14 PM
For Sale Carl Goldberg Piper Cub .40 Sport Airplane in Cub Yellow. waynebang Aircraft - Fuel - Airplanes (FS/W) 0 Feb 13, 2008 06:38 PM
F/S: Carl Goldberg Anniversary Piper Cub Jay C Aircraft - Fuel - Airplanes (FS/W) 8 Jul 17, 2003 10:26 AM
