Sep 24, 2003, 02:14 PM
San Francisco, CA, USA
Joined Jun 2001
hi payton. i'm not saying the predator is heavy, compared to other 90s. it's the lightest, which is one of the reasons i chose it. i'm just saying the canopy is heavy compared to what us electric guys are used to. my logo 20 canopy is made out of thin lexan, which is much lighter than the polypropelyene (milkjug plastic) that many nitro helis use.
my reason for making a one piece lower frame is so that i can install a motor mount for the actro motor. the actro needs to be supported from the bottom, unlike most electric motors. i doubt the new frames will save me any weight. coincidentally, it looks like the tip of the actro's shaft will fit right into the 5mm bearing that normally supports the starter shaft (i think?), so the motor will be supported at both ends. this should be a pretty easy conversion.
