Old Nov 06, 2011, 04:38 PM
DeeBee1 is online now
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Question
Small Servos for Diesel/Glow Planes
What make/model of servo do you guys use for small R/C planes powered by diesel or glow (40" or less like an R/C converted Tomboy or similar)?
I usually use Futaba or Hitec servos for electric planes but their ranges of smaller servos (sub-mini, micro etc.) state that they shouldn't be used with IC engines, due to vibration I guess. Do you simply risk it with small servos or are there some made for IC?
The lightest I can find that is suitable is 21g. Any suggestions?
DeeBee1 is online now Find More Posts by DeeBee1
Old Nov 07, 2011, 08:05 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
I've been using 8 gram HS-55 and HS-45B's in 1/2A Texaco planes with no problems as do many guys we fly with. I have a Brown Jr powered plane using HS-82MG's also and again they work great. I've never heard of the "do not use with IC engines" statment so went looking. Futaba in thier chart indicates smaller servos for small plane and electric ,but then Hitec just indcates plane with no power or size exceptions.
Hitec chart: http://www.hitecrc.de/store/servo_chart.html
Futaba chart: http://www.futaba-rc.com/servos/servochart.pdf
Leadchucker is offline Find More Posts by Leadchucker
Old Nov 07, 2011, 08:25 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
A HS-55 would certainly be inadequate as the elevator servo for a typical ".40 size" glow plane.
I don't see why it wouldn't work for "radio assist" of a 40" free flight airplane. If balance allows, I'd mount it near the control surface and far from the engine.
perttime is offline Find More Posts by perttime
Old Nov 08, 2011, 03:36 PM
DeeBee1's Avatar
Joined Apr 2007
Thanks guys. I've flown larger IC planes with standard servos and all sizes/types of electrics with standard/mini/micro servos. Just no experience with small IC RC.
Leadchuker - I noiced the Fuataba 'small planes' servo types the other day but wasn't sure if they meant IC as well as electric. Spektrum give aircraft type advice e.g.:
http://www.spektrumrc.com/Products/D...rodID=SPMDSP60
Hitec give recommendations in their product descriptions e.g.:
http://www.hitecrcd.com/products/ana...ini/hs-55.html
Old Nov 08, 2011, 06:07 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
But do any of them actually say they can't be used with IC engines ? That was what you originally claimed wasn't it ?
Anyway I think the 4-6 g servos are probably a bit small. I've often seen HS55s and standard 9g servos used with no problems (not tried 'em myself in IC models cus I've converted everything except C/L stuff to electric ). Going slightly bigger something like Hitec HS81s, commonly used as aileron servos on 40-size models like the Wot 4, would have no trouble and even they are only 16g.
Steve
slipstick is online now Find More Posts by slipstick
Old Nov 09, 2011, 03:59 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
My thinking of radios with converted Free Flight models is definitely in terms of "radio assist": ensure safe take-off and landing, suggest to the airplane that it should remain over your field. More for trim than maneouvering. Then surfaces and deflections will be small, as will the forces on the servos.
Others might not share this thinking.
Old Nov 09, 2011, 11:39 AM
AMA7224 LSF1832
Joined Sep 2008
I would share the same thinking in general. Forces are probably closer to thermal duration sailplanes except for the very high powered glow competition old timers under power that climb like rockets. The smaller and sport flying old timers don't fall into the rocket climb catagory normally.
Old Nov 09, 2011, 04:09 PM
DeeBee1's Avatar
Joined Apr 2007
Yes it was, although I'm sure the manufacturer's sites used to state this more clearly. However, I have found some examples of this being stated at Tower Hobbies (see the Comments section) of the link below:
http://www3.towerhobbies.com/cgi-bin...?&I=LXNCV8&P=7
Anyway, I think I agree that as for free flight assist of smaller models, smaller servos are probably fine.
Old Nov 12, 2011, 01:17 PM
brokenenglish is online now
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Hi all,
This interests me because my next build is going to be a Super Buccaneer reduced to 36" span (an old RN kit bought on eBay).
Concerning the servos, I think the simple fact is that oriental manufacturers just donít realise that there are nuts like us flying RC with ED Babies, Darts, Mills & Amco, etc. For them, small RC means electric, and i.c. means powerful engines. In any case, weíre not sufficiently numerous to represent a significant market (there ainít many of us still running around loose!).
However, Iíve reached the (totally unsupported) conclusion that a well designed and properly damped servo mounting is unlikely to result in a servo being damaged by an ED Baby or Mills .75... with a few obvious precautions like balancing propellers, etc.
Anyway, Iíve purchased some 4g servos and some 8g. Iím going to try the 8g in the Super Buccaneer and I donít anticipate any problems...
Finally, Iím out in the sticks with no proper Internet and Iíve only just found these forums, but no doubt my Super Buccaneer efforts will be put online.
Brian
brokenenglish is online now Find More Posts by brokenenglish
Old Nov 12, 2011, 04:57 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Brian
Welcome on board! We are supposed to have 4 meg broadband down here in the Limousin as we are only a couple of kilometers outside Rochechouart which is (allegedly!) an ADSL hub, but my speed checks rarely produce better than a half meg - manage to get by OK though. May I ask where the devil you get your diesel fuel from - I would love to lay my hands on some so that I could build a KK Pirate 2 channel model for my Kalper (well, actually just a second fuselage to use the flying surfaces from the electric one). I fly only electric these days, but have a Mills 75, an AE 0.5 and a Bee as well as the Kalper.
There are some great build logs on this forum, can I interest you in building a Frog model for the build-off? See http://www.rcgroups.com/forums/showthread.php?t=1510260
Regards
George
Sundancer is online now Find More Posts by Sundancer
Old Nov 13, 2011, 10:35 AM
DeeBee1's Avatar
Joined Apr 2007
Originally Posted by brokenenglish View Post
Hi all,
Anyway, I’ve purchased some 4g servos and some 8g. I’m going to try the 8g in the Super Buccaneer and I don’t anticipate any problems...
Hi Brian, welcome to the forum.
I would avoid using sub-mini/micro servos (< 5g) for anything other than indoors as they can be quite flimsy. I recently had to replace two such servos on some small electric indoor flyers - one disintegrated and one just stopped working. I agree that something around 8-10g (e.g. Hitec HS-55) should be robust enough for a small diesel. Now that some small 2.4GHz receivers can be powered by very light and small lipos, a slightly heavier servo just results in the same overall net weight (if that makes sense).
The problem is that if a servo dies in-flight, the plane won't suddently become a free-flighter, the chances are that a control surface may become jammed fully up/down/left/right, followed by the inevitable crunch!
PS - Lovely Kalper you've got there Sundancer. They used to be made quite close to where I live In Southwick in East Sussex by Seymour, Hylda & Co. (a few years before I was born though).
New Product Combined on/off/charge switchjack ideal for small 2S/3S planes PLD Parkflyers 0 Jun 29, 2011 10:17 PM
New Product PLD-ESJ8A: On/Off/Charge combo switchjack for small powered planes PLD Power Systems 0 Jun 29, 2011 10:13 PM
Discussion didn't someone build and fly a Coro Delta with small diesel engine earlwb SPAD - Simple Plastic Airplane Designs 15 May 27, 2011 09:56 PM
Discussion Receiver Batteries For Glow Planes RCMikeofIndiana Fuel Plane Talk 37 May 06, 2011 03:45 PM
Wanted Diesel or glow power pod appropriate for 3m woodie arukum17 Aircraft - Sailplanes (FS/W) 3 Sep 14, 2007 01:38 PM
