Old Nov 06, 2011, 12:33 AM
seedo is offline
Find More Posts by seedo
Plane crasher
seedo's Avatar
Joined Jun 2007
Help!
my plane motor went off while flying need help!
Hello Dear Members:
quickly i will go to the point i have an EDF jet & its components consist of the following:
ESC Turnigy 30A
EDF size 64mm
EDF motor 4400Kkv
Battery 1300mah 11.1v - 25-35c discharge
while flying after 5 mins the plane throttle suddenly drops from full to half by it self, then i put the throttle down and lift it up again to full throttle and it was ok and then after 30 seconds the throttle went 0% and i couldn't let the motor work again, thank god the plane was so fast so it was practically gliding so i landed it and servos where working fine, when it was in the ground i checked the battery it was a little above being warm and also the ESC, couldn't reach the motor, also i noticed the wires were hot in a not normal degree, but in the end i thing the main reason for this is that the motor max load is 26A and am using 30A ESC and most of the flying time i was on full throttle, do you think this is the reason why the plane motor fail?
Thank you folks
seedo is offline Find More Posts by seedo
Old Nov 06, 2011, 04:08 AM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
Is this for real?
How much did you charge back into the pack?
Neil Guildford is offline Find More Posts by Neil Guildford
Old Nov 06, 2011, 05:49 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
26A/(1.3Ahx.8)=25C=2.4min motorruntime.
A 5 minute flight would drain your pack far past safe margins. You had a LVC (low Voltage cut off) .
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Nov 06, 2011, 09:49 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
ok guys your feedback is very useful i really appreciate it thank you.
well i noticed now that the battery is a little puffy like a balloon though its working normally, also i would like to mention that when i land the plane i found that the battery have 20% only left, for now the ESC and the motor are working properly, am suspecting two things:
- I need bigger battery.
or
- I need to check the connectors soldering it might be not soldered properly.
what do you think guys?
Old Nov 06, 2011, 11:20 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
I think your first guess it the correct one.
BTW, do you own a fire extinguisher.
1320fastback is offline Find More Posts by 1320fastback
Old Nov 06, 2011, 11:24 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
and a video camera!
invertmast is offline Find More Posts by invertmast
Old Nov 06, 2011, 12:55 PM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
Fire extinguisher?! nope
and yes for the Camera
Old Nov 06, 2011, 04:16 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
To put Erik's info another way, a 1300 mah pack can do 1.3 amps for an hour, 2.6 amps for 30 minutes, 5.2 amps for 15 minutes, 10.4 amps for 7.5 minutes and 20.8 amps for 3.75 minutes, etc. Although it can theoretically be discharged at 25C (32.5 amps), it would only last about 2 minutes at that rate, and that would be pushing it.
5 minutes is WAY over capacity for that pack at anything over about 15 amps. That battery is either DOA, or about to be. Don't use it again!
You need about a 2500 pack to fly for 5 minutes at 25 amps or so. I would guess that would make your plane too heavy, however.
kelberts is offline Find More Posts by kelberts
Old Nov 06, 2011, 04:30 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Originally Posted by invertmast View Post
and a video camera!
and are you related to sherlockkaboom?
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Nov 06, 2011, 06:13 PM
Joined Mar 2004
nope.. but if someone is gonna make a show, I dont want to miss out
Old Nov 06, 2011, 08:46 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
This is what happens if you abuse a battery like I did.
ApexAero is offline Find More Posts by ApexAero
Old Nov 06, 2011, 09:32 PM
Hawk Fanatic
Joined Jul 2008
You found a way to burn a nano-tech?!?!
Here was my lipo fire IN FLIGHT!!!
Lipo Fire In Flight!!! (0 min 53 sec)
Old Nov 07, 2011, 12:28 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
opsyyyyyyyyyyyy
that's really a scary stuff guys, it remind me of this clip
http://www.youtube.com/watch?v=BPfUF-lexCM
Old Nov 07, 2011, 12:34 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
So which battery i should get?
this is my plane dimensions:
length 970mm
wing span 632mm
Flying Weight 520g
also i would like to mention i get 540g of thrust from my EDF unit
Old Nov 07, 2011, 05:35 AM
clinth01 is offline
Find More Posts by clinth01
Vertical Arrival Specialist
clinth01's Avatar
Townsville, Australia
Joined Sep 2009
That was my first EDF about two years ago. It flies nicely, but you won't get more than about 3 1/2 minutes in the air on a 1300mAh battery without damaging the battery. It balances perfectly with this sized battery with no need to add weights.
You might squeeze in a 1500mAh battery, but you'd need to add weight at the tail to balance it. The extra weight would mean that it wouldn't fly as nicely, and would land much faster.
The foam in the nose is fairly thin. The plastic battery cage helps add strength to the fuselage above the nose wheel. DO NOT REMOVE THE PLASTIC CAGE TO FIT A LARGER BATTERY. You will snap the nose off on your first landing. Don't ask me how I know this.
I would suggest being happy with the performance on the smaller, recommended battery, and to just buy 2 or 3 others to give you more flights of shorter duration.
clinth01 is offline Find More Posts by clinth01
Discussion Need help on a motor/esc combo for my trainer. superfastwrx Power Systems 3 Sep 27, 2011 12:47 PM
Wanted Need Help Picking a Motor for .25 plane andernamen Aircraft - Electric - Power Systems (FS/W) 4 Sep 06, 2011 10:01 AM
Discussion Had a Hawk swoop in on my MSR while flying in my back yard donmei Micro Helis 7 May 31, 2011 07:46 PM
Rant Went flying today ... (what if you could only have one plane...) WimH Electric Sailplanes 6 Apr 22, 2011 04:31 PM
Motor shuts off while testing my setup. Leafy Power Systems 7 Nov 06, 2004 11:11 PM
