Old Nov 05, 2011, 05:50 PM
vashdao is offline
Find More Posts by vashdao
Joined Aug 2011
RSSI Digital in? What does that mean?
Hi guys,
I have an RVOSD5 and it says it accepts digital RSSI input according to the manuals.
Thanks!
vashdao is offline Find More Posts by vashdao
Old Nov 05, 2011, 06:56 PM
n5iln is offline
Find More Posts by n5iln
United States, CA, Salinas
Joined Nov 2011
That means it will accept a signal from the receiver to produce a "receiver signal-strength indication" (RSSI) on the OSD.
n5iln is offline Find More Posts by n5iln
Old Nov 06, 2011, 01:12 AM
vashdao is offline
Joined Aug 2011
Thanks for the quick reply man,
Does that mean I can directly connect my D8R-II Telemetry Frsky RSSI to the RVOSD5, since you said it's digital? Or do I need to convert it to analogue first?
If I have to convert to analogue, that would defeat the purpose of digital RSSI input right?
Anyone else here agree?
Old Nov 06, 2011, 01:19 AM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
It's actually "Relative Signal Strength Index," least how I was taught, which means its basically just a changing voltage to represent the strength of the received signal.
Blueshy is offline Find More Posts by Blueshy
Old Nov 06, 2011, 01:25 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Frsky RSSI is still analog, even it is PWM. It's another kind of modulation, but the unit is analog, the measure is given by a time period lenght, which is an analog unit.
Digital is when those pulses encodes a number, which is not the case for Frsky RSSI.
All you need to do to connect Frsky RSSI to any OSD is to smooth the pulses with a RC filter, as described here.
renatoa is online now Find More Posts by renatoa
Old Nov 06, 2011, 01:38 AM
vashdao is offline
Joined Aug 2011
Thanks for the great reply guys! You guys really helped! An RC filter I guess I'll have to get. Actually, I was just making sure I needed one before I get it.
Question: Is this one good? And will this work?
http://www.ebay.com.au/itm/FrSky-RSS...item1c1bba84d0
It's a bit costly, but I think it's designed for D8R series.
Thanks for both of you guys help man!
Old Nov 06, 2011, 01:27 AM
Joined Sep 2007
This was developed before D8RSP, now it's obsolete if you reflash the receiver with CPPM+RSSI firmware.
Old Feb 21, 2012, 05:17 PM
mkuvy is offline
Find More Posts by mkuvy
New Zealand, Waikato, Cambridge
Joined Feb 2012
Hm, which exactly firmware is this? Would you please attach a link?
mkuvy is offline Find More Posts by mkuvy
Old Feb 22, 2012, 02:21 AM
Joined Sep 2007
Sorry, was wrong, the firmware I wrote above bring only CPPM, not RSSI.
For RSSI you still need the ebay device.
Or, get D4FR, that outputs directly CPPM and RSSI.
Look here for a matrix of all Frsky receivers with their features:
http://www.rcgroups.com/forums/showt...4#post20795757
Old Feb 22, 2012, 11:24 AM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
RVOSD5 has three options for RSSI input, analog, digital and PWM.
The digital option will count the number of pulses over one second time period.
You can get more information about this on the rangevideo forum:
http://rangevideo.com/forum/showthre...progress...%29
Elcheapo is offline Find More Posts by Elcheapo
Discussion What does this Alarm on my charger mean? termeric Electric Plane Talk 3 Oct 23, 2011 09:01 AM
Discussion What does this mean to you ??.. touching VRX/VTX antennas ?? khaled_abobakr FPV Talk 9 Sep 22, 2011 12:54 AM
Help! What does it mean to "Glass" dylang Waterplanes 7 Sep 14, 2011 06:08 PM
Discussion "bump" - new to rc groups and see this in the classified listings, what does it mean? nautique Trader Talk 9 Aug 31, 2011 07:35 PM
Discussion What does 60VA mean in my power supply? seair Batteries and Chargers 6 May 17, 2011 10:43 AM
