Old Jan 07, 2013, 05:45 PM
aeromeddeler is offline
Find More Posts by aeromeddeler
Soulles Normandy France
Joined Feb 2011
Finally got a temporary working machine so have been able to scan a few more.
Got hold of a few old M.A.N and American Modeler mags so will be posting from these as well. 50+ might have posted some that I will be posting but just in case those I post will be full sized with full documentation.
Model Aircraft August 1950
Smoothie 44" Span FF wakefield rubber powered
Thunderbolt 28" Soan C/L Scale P47N Thunderbolt posted at
http://www.rcgroups.com/forums/showp...&postcount=626
Model Aircraft October 1960
Fevair 48" span FF rubber powered wakefield
Model Airplane News November 1957
Profile Silviare
33" span profile semi scale FF or U control posted at
Sure Fun 37" span C/L ( J Roberts flight control system ) sport posted at
Zyphyr 29" span FF rubber
Model Airplane News January 1958
1957 Mulvihill winner 47.5" span FF rubber
Comper Swift 40" span FF scale
Lieutenant 48" span C/L stunt posted at
aeromeddeler is offline Find More Posts by aeromeddeler
Old Jan 07, 2013, 09:47 PM
algy2 is offline
Find More Posts by algy2
Joined Jun 2011
Aeromodeller free flight plans
Hi,
Going to the January 1971 AEROMODELLER with the cover featuring Woodford’s “MISS AEROMODELLER 1970” LINDA STAFFORD posing with John O’Donnell’s Wakefield “SLOW COACH”.
The first free flight plan is a very nice scale MILES M.5 SPARROWHAWK by D.M. COLLIN.
The original model was powered by D.C DART .5cc diesel and featured pendulum control but flight trials showed it to be both unstable and underpowered.
A switch to .75cc or 1cc diesel and a fixed rudder solved all the problems resulting in a model that flys well and looks great in the air. The plan is 1/7th full size.
Of 351/2 inch wingspan the construction article has all the details.
Next to a quick “Chuck” glider by Canadian E. AVORY. TRIBUTE is just 15in span and the designer said at 15gramms is very sensitive to lift and prone to O.O.S. flights.
Finally to AIRCRAFT DESCRIBED and the SEPCAT “JAGUAR” with drawings by C.J.NICHOLS.
Cheers
algy2 is offline Find More Posts by algy2
Old Jan 07, 2013, 11:29 PM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Truly a thing of beauty that Sparrowhawk.
Many thanks and Happy New Year to you all.
Modelholic is offline Find More Posts by Modelholic
Old Jan 08, 2013, 12:34 AM
Luckyducky is offline
Find More Posts by Luckyducky
AMA 179
United States, CA, Huntington Beach
Joined Dec 2007
Nice plans and scans Aeromeddeler! Especially like the Smoothie. I was wondering if there might be the possibility of posting these files with titles lending themselves to easy filing, such as: "Smoothie 44-inch Span FF wakefield rubber 1950" This would avoid much renaming when sorting them out.
Luckyducky is offline Find More Posts by Luckyducky
Old Jan 08, 2013, 05:39 AM
WMD is offline
WMD
Find More Posts by WMD
WMD
WMD's Avatar
Bradford, UK
Joined Jan 2010
Cripes. Aw, look now I've just spat my coffee out all over my keyboard.
Nice work, Aeromeddler. Good to have you back.
WMD is offline Find More Posts by WMD
Old Jan 08, 2013, 07:18 PM
Joined Feb 2011
Two problems with long names
1 Look at some of 50+ posts in the vintage group the ones with long names are unreadable due to the names overlapping. Plus if you use a download manager you get.
Ace%20of%20Diamonds%2036in%20SS%20pusher%20with%20 Warren-Young%20wing%20George%20Wools%20Aeromodeller%20195 8%2008
2. As the must build list gets longer the time you have left to build them gets shorter. The MAN mag posted below required over twenty pages to be scanned to produce the three files. Each one has to be straightend,cut and pasted to reduce the text to 3 or 4 pages and the plan has to be scaled. Then the whole lot is converted to a PDF to fit the upload. Plus I am a terrubbule speler.
Model Airplane News January 1959
Satellite 600 64" Span FF Pylon model
Wee Champion 21" span rubber powered scale Aeronca Champion FF
Supermarine S6B 29.5" span C/L scale posted at
http://www.rcgroups.com/forums/showp...&postcount=627
Old Jan 09, 2013, 07:19 AM
algy2 is offline
Joined Jun 2011
Hi,
Going this time to the January 1972 AEROMODELLER with the cover showing an actual Hot Air balloon scending during the flying display of the Shuttleworth Collection Old Warden UK.
In fact the plans to pass along from this issue are for MIDAIR by S.T.MIDSON.
MIDAIR is a three foot diameter Hot Air Balloon giving 24 cubic foot capacity.
A 11/2 minute burn on a still air day will get you to some 300 feet in altitude. All the details are in the construction article and on the working drawings. Certainly an intriguing model to make.
Finally to AIRCRAFT DESCRIBED and A.A.P. LLOYD takes a detailed look at the OR-65-2 OWL RACER.
Cheers
Algy
Old Jan 10, 2013, 06:40 PM
Newtmagick is offline
Find More Posts by Newtmagick
United States, CA, Oceano
Joined Oct 2011
a: I have downloaded every one of your postings and I am verry happy with the way you are doing them. The little extra work I spend filing them keeps me out of the pool hall I can't thank you enough for all of the work you are doing.
Newtmagick is offline Find More Posts by Newtmagick
Old Jan 12, 2013, 10:46 PM
algy2 is offline
Joined Jun 2011
HI,
This time to the February 1971 AEROMODELLER. The cover features H.C QUEK’S semi scale YAK 9D Control Line Stunt Model.
This issue has two full size free flight plans the first being the delightful rubber powered ORLIK. Designed by MIROSLAV ROHLENA the simple 331/2 inch is a cabin model with a good performance.
Next is LITTLE DEER by JACK ALLEN. Jack said he was inspired after attending the 1969 World Champs and seeing KARL RIEKES unusual high mounted tail plane model.
Of 291/2 inch wingspan the original was powered by a .5cc engine . All the details are in the construction article.
Finally to AIRCRAFT DESCRIBED and a close look is taken at the DORNIER DO-X a twelve engined 1926 flying boat.
Cheers
Algy
Old Jan 14, 2013, 07:38 PM
Joined Feb 2011
Model Aircraft July 1960
Loopstick 49" span FF sport
Kentish Wind 52" span C/L stunt posted at http://www.rcgroups.com/forums/showp...&postcount=633
Model Aircraft August 1960
Cessna 210 another of Ray Malmstom`s minature gliders
Poppet 37"span FF sportster
Long John 42" span C/L F.A.I. class team racer posted at http://www.rcgroups.com/forums/showp...&postcount=633
Model Aircraft September 1960
Indoor Hand Launched glider article with plan for 17" span glider
Last edited by aeromeddeler; Jan 14, 2013 at 07:40 PM. Reason: forgot to add cessna
Old Jan 17, 2013, 07:20 PM
Joined Feb 2011
MAN July 1958
Mini Missile 3.75" span FF jetex 50
Swif-f-ft 22.75" span FF jetex 150 and Swif-f-ft 17.5" span FF jetex 50
Whatizit 37" span C/l stunt http://www.rcgroups.com/forums/showp...&postcount=637
Sport Coupe[/B] 31.75" span sport and stunt C/L http://www.rcgroups.com/forums/showp...&postcount=637
Old Jan 17, 2013, 07:39 PM
aaron_jeffrey is offline
Find More Posts by aaron_jeffrey
Joined Nov 2003
Same name, different model
Nothing against the Smoothie in post #796, but Hank Cole's Smoothie, also a rubber model, beats it in a beauty contest.
aaron_jeffrey is offline Find More Posts by aaron_jeffrey
Old Jan 19, 2013, 07:23 PM
Joined Feb 2011
Model Aircraft September 1950
Hyperion 71" span A2 class Sailplane
Mustang IV 30" span FF rubber scale
Model Aircraft April 1961
1/2A Wunda 34" span FF for .049 power class
Coy Kat 54" span C/L stunt http://www.rcgroups.com/forums/showp...&postcount=638
M.A.N. May 1959
SE5 41" span FF scale
Pied Piper 30" span C/L Rat Racer http://www.rcgroups.com/forums/showp...&postcount=638
Starfire 13" span semi scale whip control http://www.rcgroups.com/forums/showp...&postcount=638
Old Jan 21, 2013, 07:46 AM
rogerc41 is offline
Find More Posts by rogerc41
Joined Sep 2011
Meadowlark Minor and Bi-Star
Here are joined versions of Meadowlark Minor and Bi-Star uploaded by Algy
Roger
rogerc41 is offline Find More Posts by rogerc41
Old Jan 21, 2013, 09:38 PM
algy2 is offline
Joined Jun 2011
Hi,
Going to the March 1971 AEROMODELLER in search of Free Flight Plans.
The cover features the YAK 18 PS flown by IGOR EGOROV winner of the Individual Would Championships at R.A.F Hullavington 1970 plus the YA8 PM flown to individual Woman’s Championship by Miss SAVITSKAYA.
One free flight plan to be found in this issue and it’s a scale FAIRY BARRACUDA from WW11.
Designed by PHIL McALROY it’s of 32 inch wingspan and powered by a Mills .75cc diesel.
Phil said the model is near scale and designed for flying over rough ground. The plan is to 1/8th scale.
Finally to AIRCRAFT DESCRIBED and the YAKOVLEN YAK 18PM & PS by JOHN BLAKE with scale drawings by P. LlOYD.
Roger thanks for joining up the BI STAR and MEADOWLARK MINOR plans. As I mentioned, when making the post, the Meadowlark proved to be a great R/C trainer and happily trundled about the sky as I tried to work out which way it was heading and what to do next.
Cheers
Algy
For Sale A few things - added a few more 7up Non R/C Items (FS/W) 2 Apr 23, 2010 11:59 PM
Build Log 51'' scratch built lobster style cruiser ( have added a few more pics of my progress) BG-boats06 Scale Boats 12 Apr 28, 2009 09:03 PM
Discussion A little PSS research... (! A FEW MORE PICS ADDED) mr_editor Slope 10 May 05, 2008 09:22 AM
Sold 2M Carbon Blade...TX Ready...added a few more pix Flyextreme Aircraft - Sailplanes (FS/W) 6 Mar 05, 2008 04:43 PM
