Old Nov 04, 2011, 01:38 PM
noaman is offline
Find More Posts by noaman
Falcon
United Arab Emirates, Dubai, Dubai
Joined Mar 2011
Gas Engine: Breaking in and Tuning
Hi floks,
I have been searcing on this topic for several days but unfortunately could not get the required and to the point information. I really appreciate if you can share your experiances which will help myself and lot other beginners.
Questions:
1 - How long normally the breakin process takes and how we know that the engie is now fully broken? I have seen few guys writing that they have already fired 3 gallons of fuel but still breaking in .....
2 - How to tune the gas engine? What makes you decide that now LOW end needle needs to be adjusted or HIGH end needle?
3 - How much engine temprature is expected? Is it normal to have temprature going high on new engines vs the ones which are fully broken? My brand new DLE-30 engine was giving me a reading upto 160 C (320 F) during the flight (checked on my Spektrum DX8 with its telemetry system)
4 - I have used fuel with 1:30 using Makita 2 stroke synthetic oil. Is it recommended to increase the ratio (1:40 - 1:50) after breaking in and will it require to tune again if oil mixture ratio has been changed?
noaman is offline Find More Posts by noaman
Old Nov 04, 2011, 01:51 PM
Sonsight is offline
Find More Posts by Sonsight
Sonsight's Avatar
United States, AR, Cabot
Joined Aug 2004
Look for the Sticky under "Engines."
Jake
Sonsight is offline Find More Posts by Sonsight
Old Nov 04, 2011, 11:33 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
On a DLE 30 you need to stick to 32 to 1
The DLE 30 needs a long break in.
When tuning the DLE I start at 1 1/2 on both needles.
Warm your engine up then at full throttle lean the HS out very slowly then go to and idle and lean the LS needle out.
Then go from Idle to full throttle if it wants to die richen the ls up if it sputters then lean it.
On a gasoline engine only go a screwdriver blade width at a time.
kerwin50 is offline Find More Posts by kerwin50
Old Nov 05, 2011, 01:57 PM
noaman is offline
Falcon
Joined Mar 2011
@kerwin50 - how long the break in will be? How do i know that now its fully broken?
Old Nov 05, 2011, 05:08 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
It will have a lower idle.
Old Nov 13, 2011, 01:46 PM
ACKopter is offline
Find More Posts by ACKopter
Branford, Florida
Joined Jun 2010
Jake
Brand new to gas engines here. So you are saying to tune a gas engine the same way you do a glow? I ask because there is nothing specific to gas engines provided in that sticky.
ACKopter is offline Find More Posts by ACKopter
Old Nov 13, 2011, 05:45 PM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
here's how I do it now.....let the engine warm up....go to full throttle and adjust the high end to peak.....now retard to idle and let the engine cool a bit...now advance the throttle so that you're turning between 2500 and 3000 RPM...and adjut the low to peak...
check the high end again.....shut it down and let it cool.....start it up after it cools down and after a very brief idle open it to full...the engine should advance to power with out much of a load up issue....go fly and make small adjustments based on what you see and hear.....
Break in on a gasser is in the gallons range 1 to 3 longer if you break in using synthetic oil....I break in at 32:1 using Lawn Boy ashless....then I peak out at 40:1 using Red Line synthetic oil and leave it there...
Yes you an go leaner but why....never heard of an engine being ruined by too much oil
Good Luck
jetmech05 is offline Find More Posts by jetmech05
Old Nov 14, 2011, 03:01 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Gas is the way to go. I only touch my needles twice a year, when it gets cold and when it gets hot.
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Nov 15, 2011, 06:13 PM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
You live in Vegas. Don't you mean "When it's hot" and "When it's unbearable"?
I miss LV. Used to live on the west side by Red Rock.
banzi28 is offline Find More Posts by banzi28
Question "Pre breaking in" two stroke engine options? JROMA Engines 17 Oct 30, 2011 09:26 AM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 02:41 PM
Discussion Installing an electric motor in place of a gas engine tenspeed Glow to Electric Conversions 7 Mar 08, 2011 08:32 PM
Discussion gas engine tuning MOUNTAINROAD Engines 2 Jan 19, 2009 06:25 PM
Question What is the proper tuning procedure for a GAS engine? mdennis Engines 1 Jun 14, 2006 04:13 PM
