Joined Jan 2004
What about a simple POLL asking what prop/watts in , is your prefference for the various EF models. I would gear up my 48" powerplant for the majority polled winner.
FWIW I would have never known/guessed an APC 10X4.7 SF would be such a winner @ 300-400Watts for 24-26 oz airframes. I like it much better than Xoars I tried for this weight range, this is the kind of data I think a poll would bring to light. |
Joined Jan 2004
For instance if I want to put 100watts into a given prop, my formula would again say 10g battery nets 25 watts ouptut, so to get to a 100 watts into a specific prop it would be roughly a 40gram battery it doesnt matter if I use a 1s @ 26 amps or a 10s @ 2.5 amps if both batteries are 40 grams it is going to spin that prop roughly the same rpm calculated with appropriate KV motor. What one may find worth exploring, that I feel is being done in helis and not planks is that wattage coming from voltage versus amperage will be the next best thing. It may just be the ease to which voltage flows in hardware versus amperage. I am always amazed when people think that increased cell count is a speed thing....... |
** This was a known issue with those props and APC now sells that prop with a thicker hub and center blade. I run the APCs on the 48" because it is so low the the ground that I find it more durable. On everything else I run Xoars. The lighter prop is easier on ESCs, bearings, X mounts (break those all the time) and the plane. |
My approach on this thread is going to be focused on completing the data collection and analysis using an specific process. The reason I’m going to approach it this way is because many guys want to take a lot of momentum/speed into a big tumbling/spinning maneuver, and for this, they may need a setup different than the guy who wants to segway from one full stall maneuver to another in a relatively small box, or airspace.
These two differences generally relate to prop speed (pitch and rotation) versus torque (diameter and rotation – an over simplification, I know). My focus will be about power… instead of how much it takes to move a 250 pound fireman up a 40 foot ladder in 1 minute, I’m interested in the prop type (make and model) that when applied to a specific motor and battery combination will hold a 5.5 pound airplane suspended in a hover with less throttle setting, and pull the 5.5 pound plane over a greater vertical distance in less time when the throttle is moved instantly to WOT. There are also two Watts variables in this analysis that need to be defined. The meter reads volts and Amps and multiplies the two and displays this value in the Watts output field of your meter. The meter is doing the math, and not really measuring the power (749 Watts = 1 HP) a system needs to turn a propeller with a specific diameter, pitch, and mass, a specific number of RPMs. The assumption will be that turning the same prop faster will generate more measurable thrust and require more power (Watts), in some relative way unless prop stall or pitch distortion is the result. This is how I will proceed, and I’m open to suggestions, but anyone can add their input and findings by doing the following so that we can maintain a standard. Here's a standard checklist that I came up with. Location or Elevation General Wind Conditions and Air Temp Weigh your all-up airplane, RTF Motor Make Motor Kv ESC Make ESC Amp Rating Battery Make Number of Battery Cells Battery mAh Battery C rating Prop Make Prop Model Prop Length and Pitch At-Rest Volts on the startup stand Half-Throttle Volts on the startup stand WOT Volts on the startup stand Half-throttle Amps on the startup stand WOT Amps on the startup stand Half-throttle RPMs on the startup stand WOT RPMs on the startup stand At this point, go fly around at half throttle for a full minute. With the video camera on, pull into a hover and hold it level for at least a few seconds. Punch the throttle to WOT and hold it until the plane climbs to at least 75 to 100 ft. Fly around for another minute at about half throttle and then land the plane. Keep track of your total flight time, and take a volt reading of you battery after 5 minute at rest. Put the battery back on the charger and record the mAh that was put back. Add the following to your checklist. Flight Time Post Flight Volts Returned Capacity (mAh) Put the video on Youtube and link us up in a posting on this thread along with the above data. If you can do this with different motors, batteries, and different props, great. But any meaningful data that you can contribution will be appreciated, and I think it is the core of what will make this thread valuable. If we can get just four or five guys to follow all of these steps using different setups, we can probably start accumulating something very valuable to everyone. Tom, Frank, and I will have some fun with this over the next few weeks. |
I see where your going with the flight test as any kind of completely subjective based test would just be disputed and thus really not provide good research value. A dammed if you do dammed if you don’t senerio. My only suggestion for your consideration would be a timed and measured WOT level pass in addition the hover to WOT vertical climb. I think it would give pilots an idea of the airplane speed difference created by different pitch props, put a little more load on the system and add to the end results data. To pull off a simple level flight speed test you could grab a radar or Lidar gun and just document the flight speed. If you don't have one you could do a few high speed donuts with your car in front of a state patrol and make them chase you at high speed to the field for flight testing. What's a little jail time, this is life or death important testing and I am sure the stater will completely understand. I will post your bail, Not! lol Thank you in advance for all your work, effort, support and thoroughness regarding this very very interesting topic and the important development of standardized prop testing methodologies. I think once both are refined the std bench and flight testing guidelines should be posted at the front of the thread. I owe you some more data my friend. Once complete I will send you my WOT and 50% throttle bench test results for the APC and Xoar 14x7 comparison. Kindest Regards, Lee |
We'll take anything we can get, and the only problem is that wind conditions, upwind and downwind passes, etc, will make the visual element a little tough as far as objectivity. If you look at Tom's video from yesterday, you can see the plane moving at wharp speed downwind. Not as helpful in comparison to no wind conditions, which may not happen for us until June. Weather Underground said steady 14-15 mph winds and gusts to 26 yesterday at Sarasota Airport. But like I said, if you have it, add it.
On another silly note. Here is a vid of something I want to build for my dog for Christmas.
Perpetual doggy fun 24/7. |
All the factual data is good but one thing I believe we all want to know is...
1. What did each pilot like about each prop and why? 2. And dislike about each prop and why? 3. What prop do they choose to fly? Regards, JC ps - Getting 4 or 5 guys with videos is a most excellent idea! |
I may actually return to the Xoar myself, until the 14x7 I'll be putting on the 48 inch Edge, and the 16x8 on the 60 inch, clips the ground a few times and begins to cost me in time and money to replace them. But they may be worth it. Let's see. |
| Thread Tools | |
| Question RC kits for experimenting with flight control systems | SubZer0 | DIY Electronics | 11 | Oct 12, 2011 08:58 AM |
| Wanted left wing for extreme flight yellow and black 74 yak | hondaboy92hatch | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 29, 2011 10:18 AM |
| Discussion Extreme power systems & Royal Evo 12 | rbehrends | Radios | 5 | Oct 11, 2007 05:55 PM |
| Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? | WeatherB | Electric Heli Talk | 6 | Jan 25, 2007 10:29 PM |
