Old Nov 04, 2011, 08:41 PM
Flazo is online now
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
I think they just did about a minute ago?
Flazo is online now Find More Posts by Flazo
Old Nov 04, 2011, 08:52 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yeah... I kinda like it! lol... it just kinda freaked me out. I was editing a post and when I hit "save" it changed and I was like "What did I do?!?!" haha
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Nov 04, 2011, 09:20 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
I noticed it too. It looks good!
_OZ_ is offline Find More Posts by _OZ_
Old Nov 04, 2011, 09:47 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
I just stumbled on a curiosity. PA's Thrust 40 vs. Torque 2814T/820
The torque is 143 gr and good to 38 amps (Peak or Constant Unknown?) and 500 to 550 Watts.
The KV is 820 and they recommend a 13 x 6.5 on 3s
The Thrust 40 is 850KV only 140 grams and is good to 500 watts and 35 amps constant and 45 amps 10 sec burst and they recommend a 14 x 7on 3s. The Thrust motor does not specify what 4s prop to use, only that you should stay within the suggested amps.
Is the Torque motor under rated? Could you safely put a 13 x 5 or 13 x 6 on it with 4s? I would think the lower KV of the Torque would allow for higher prop sizing?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Nov 04, 2011, 09:50 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
My Torque runs a 12x6 and pulls slightly over 40 amps. I suppose if you use an amp meter and are careful about it, you could, but I doubt it will turn the bigger prop. However, I have heard of guys running a 13x4 onf 4S on the Torque.
--Tom K.
Old Nov 04, 2011, 09:52 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
If you want to swing a big prop on 4S, the Motrolfly 2820-750 will swing a 14x7 on 4S at 7900RPM's at about 35 amps constant. My custom Motrolfy 2820-750 with 680 kv (comes stock with 630) will swing a 14x7 8200RPM's at about 45 amps producing almost 10 pounds of thrust.
--Tom K.
Old Nov 04, 2011, 09:55 PM
frankjp is offline
Find More Posts by frankjp
2.3 D Hack Bradenton FL
frankjp's Avatar
Joined Dec 2010
Originally Posted by leespaddock View Post
Knock em dead Tom.
Whoo Hoo! Hoo Rah!
Love this new thread. It's like a brand new playground dibs on the monkey bars
The propeller forecast. Showers of falling ego's with cloud breaks of paradigm shifting in-lighten-ment. lol
OK,,,Can't resist this. I'm good at making "Half Props" so I cleaned one of these up ,,,(hacksawed it through the center),, and weighed it. The prop was a Turnigy Light Electric 16x8. I don't have one xactly like what you are testing but this method should get us some spool up data Right?
The total (half) is 20.5 grams 41gr before landing? It balances on my Buck Knife at 2.66",(67.53mm),from center hole which would be center of mass right?
Tip 6.9 gr
Ctr 13.8 gr
Center mass Dia 5.32" /135.06mm
It gained a couple grams at my Harbor Freight/ one car garage lab.
Worth while ?? or do I have to go sit in the stands?
frankjp is offline Find More Posts by frankjp
Old Nov 04, 2011, 10:08 PM
They Call him Dead!
Joined Jul 2003
--Tom K.
Yes, I just bolted on a motrofly 2315 custom wound to 700KV. Unfortunately all I have is a Xoar 13 x 6.5. I am only getting around 37 amps and 67 ounces of thrust. I plan on getting a 14 x 7 to put on and see what I get!
Old Nov 04, 2011, 10:12 PM
They Call him Dead!
Joined Jul 2003
Tip 6.9 gr
Ctr 13.8 gr
Can you translate this????
Old Nov 04, 2011, 10:14 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
I believe ef said you could run the larger prop but you would slowly kill the motor, that is why the 12x6 was recommended.
stgdz is offline Find More Posts by stgdz
Old Nov 04, 2011, 10:40 PM
frankjp is offline
frankjp's Avatar
Joined Dec 2010
Would it be worthwhile to know which prop would spool up the quickest? In addition to Thrust,Amps,of course. The same amount of weight farther away from the center would spool up slower. Like the Vess for instance,has wider blades toward the tips.
I think this (weighing both ends of a half prop)would be a way of determining how far from the prop shaft the center of mass is which in turn will have a barring on how fast the prop spools up.
Old Nov 04, 2011, 11:07 PM
They Call him Dead!
Joined Jul 2003
Ah, Now I get it! Sounds interesting to me
Old Nov 04, 2011, 11:08 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Hmmm... good point Frank! Seems like a good testing point.
--Tom K.
Old Nov 04, 2011, 11:37 PM
frankjp is offline
frankjp's Avatar
Joined Dec 2010
We need to save broken props for this test,,,hate to cut good ones in half. There may be another way to do this test,,,,accelerate it in a vacuum?
Old Nov 04, 2011, 11:39 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
A friend of mine had a vacuum chamber big enough for this... but he kinda fell of the radar a year or so ago. You remember James right?
--Tom K.
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 15 Feb 25, 2015 03:15 PM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 10:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 05:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 10:29 PM
