Old Dec 03, 2012, 10:58 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Hey Hoghead!
Did you get your power set up issues taken care of?
Dead is offline Find More Posts by Dead
Old Dec 03, 2012, 11:21 PM
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Originally Posted by Liberty10 View Post
I looked at the manual and you need to change to life in the user programing.
Here's a video; http://www.youtube.com/watch?feature...&v=h9wHP4ZBL9w
thanks for the help guys
nickelbn1 is offline Find More Posts by nickelbn1
Old Dec 03, 2012, 11:39 PM
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
sure did Dead. thanks to you and aeroplayin we got it all sorted and working as it should.
i tell ya, i had a headache for a couple days but i sure learned alot from you guys.
hoghead5150 is offline Find More Posts by hoghead5150
Old Dec 03, 2012, 11:42 PM
Joined Jul 2012
hey nickelbn1, if your ever down our way hit us up and we will go flying. we fly at the poteau airport every weekend, and sometimes during the week when the losers are off work!!
we are about 20 minutes from fort smith.
Old Dec 04, 2012, 02:09 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Wish i could. I drive down I-40 fairly often to go to family in Checotah, but i never get down your way. Would be cool to fly at an airport.
Old Dec 06, 2012, 10:13 PM
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Originally Posted by jw357_23043 View Post
Has anyone here ran a Torque 2818 900kv on any of their 48" EXP's?
Not enough motor for 3s, exps are too heavy.
JimTMich is offline Find More Posts by JimTMich
Old Dec 07, 2012, 06:21 AM
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
So is there anything that can be done to repair a motor with a slightly bent bell. Its just enough you can feel the vibration w/ no prop. Torque 2814/820
Liberty10 is offline Find More Posts by Liberty10
Old Dec 07, 2012, 10:40 PM
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
Have Scopion 4020 series motors been tested on EF 60" airplanes? I am thinking of spinning 16X8 with scorpion 4020-14 480kv or 4020-16 415kv on 6S setup. woulb it be a good setup? how many amp will it draw?
VR Eyedoc is offline Find More Posts by VR Eyedoc
Old Dec 08, 2012, 06:33 AM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Other than another 20 grams of weight, everything else looks okay. If you have one already, you may as well see if it fits under the hood, otherwise, the Motrolfly 4615 is still $45 less. Tom, Frank, and I have pounded the three motors we bought last December and they're still running great.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Dec 08, 2012, 06:39 AM
Play Dead!
Dead's Avatar
Joined Jul 2003
I don't know why people are not all over the new Torque MK II. You can not beat the combo price!
O bought the Motrofly 4315 for my Edge cause the old Torque could not swing a 16". But the MK II which is on my MXS 64" ROCKS! Considering the price, I can not imagine going with the Motrofly. It simply is not a bit better in my experience.
If you are gonna fly the 64 MXS, I don't think the Scorpian is the way to go. The MXS already runs tail heavy and the lipo has to go way back to CG. I have my Boss ESC as far back as i can get it (just above LG Plate) and the 3800 lipo touches the wing tube. I do not have extra lipo to run BEC however. If I did, then it could be placed behind the RX o help balance.
Old Dec 08, 2012, 08:12 AM
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
how many amp will the MKII draw with 16X8? I may have ot upgrade my EXC. I bought the 60" extra300 airframe only, the MKII was not available at the time. can I still have discounted price now?
Old Dec 08, 2012, 09:24 AM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I seen Chris grant it after the fact before, wouldn't hurt to contact him to check if you can.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 08, 2012, 10:11 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
The thing we all have in common here is that if you did not buy the Scorpion yet, the MKII or the Motrolfly 4315-480 are great options, and the MKII will drop right in. The plane, the MKII motor, and 85A ESC are perfect for the setup and paying $170 for a Scorpion, without knowing how it mounts or balances, is a big gamble.
So yes... considering the combo price, the fact that EF will honor the price even after you bought the ARF, the MKII with the 85A Airboss becomes a no-brainer.
Old Dec 09, 2012, 03:30 AM
Joined Oct 2011
Ok finally got my 20x8 props in and was able to do some testing with my 4330-216. All tests were static on the bench 70degrees F @ 140 feet ASL. Readings were with the Castle logger at 10 readings per second (10Hz), so numbers were more accurate.
APC 19x8E
Just weighed it 70g
APC 20x8E
Weight 112g
Peak: 8167 RPM, 3123 watts, 69.8 amps, 44.8 volts
Settled in: 7990 RPM, 2749 amps, 63.1 amps 43.6 volts
Xoar 19x8 PJN
Weight 54g
Peak: 8330 RPM, 2855 watts, 63.8 amps, 44.8 volts
Settled in: 8124 RPM, 2518 watts, 57.8 amps, 43.5 volts
Xoar 20x8 PJN
Weight 61g
Peak: 8102 RPM, 3180 watts, 71.3 amps, 44.6 volts
Settled in: 7947 RPM, 2863 amps, 65.5 amps, 43.7 volts
Strictly from a numbers point of view I should go with the APC, but I will run the Xoar 20x8 due to the lighter prop being less wear and tear from gyroscopic maneuvers. Spool up was noticeably slower with the heavier APC. I wish I had the means for measuring static thrust. I will see lower numbers in the air and the 20x8 props settled in right where I wanted them to so I am happy.
A little difference between the 19x8E and 20x8E APC props. I wonder if they changed there design to lighten up props recently. In the picture the 20x8 on top has a thicker hub and thicker blades. Both are thin E props, but the 20" is 42grams heavier and significantly thicker.
Old Dec 09, 2012, 04:00 AM
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
It would rarely if ever be the bell itself that was bent, almost invariably it's the shaft bent inside the motor which causes the bell to sit 'wonky'.
I'd recommend to remove the shaft and check it for being bent by rolling on a smooth flat surface.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 11 Oct 12, 2011 08:58 AM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 10:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 05:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 10:29 PM
