Old Jun 11, 2012, 01:49 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by GetSome! View Post
Ken wrote 700kv on it
Yeah but it wouldnt be unreasonable to 'round up' a 683kv wind and call it 700 Most manufacturers state their motor kv as the nearest round number rather than the actual measured kv. Depending on how you measure kv you could easily be 20kv out in either direction anyway so picking the nearest round number is perfectly reasonable..
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jun 11, 2012, 10:17 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Does 50% throttle result in 50% less amps? The fets are turning on and off faster when not at full throttle so there is more heat and heat usually equals amps.
stgdz is offline Find More Posts by stgdz
Old Jun 11, 2012, 11:52 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Steve
It is possible, however unless there is mistake (like when he made me a 4315-480 that was more like 430. He rewound it free) Ken means what he writes on the motors.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jun 12, 2012, 12:10 AM
Aberdeen
Joined Mar 2006
A difference of approx 50 is 'doable'. It's when people expect Ken to be able to wind precisely any kv number of their choosing down to the single digit accuracy that they are deluding themselves.
I fully appreciate that Ken is an expert motor winder but he's still bound by the laws of physics and a turn of wire is still a turn of wire. No matter how good you are you cant wind half a turn
If in doubt about it just drop Ken a line and I'm sure he'll confirm what I'm saying.
Steve
Old Jun 12, 2012, 12:35 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
For the record he had no problem hitting my 1130kv mark I requested. I don't see not being able to go somewhere in between 683 and 750 kv also.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Jun 12, 2012, 02:22 AM
Joined Nov 2010
Steve
I'm sorry Steve, but I'm not sure what your point is?
Old Jun 12, 2012, 05:11 AM
Aberdeen
Joined Mar 2006
The only point was that it's impossible even for someone as expert as Ken to wind every specific kv imaginable in incremental steps of anything close to 1kv (as some seem to think is possible).
When winding a motor kv is adjusted by varying the number of turns of wire that you wrap around the stator 'teeth', more turns = lower kv. Each turn makes a difference of many kv (perhaps 50 or so for a motor like the DM2820) so it's impossible to hit any specific kv between what the number of turns produces.
For the DM2820 the achievable kv (in delta configuration) seems to be: 966, 750, 683, 638, and 600 (some of these numbers are probably rounded slightly). Most of these steps will represent one turn of wire on the stator, though the jump between 750kv and 966kv is probably three turns meaning kv's of approx 810 and 880 could also be wound.
Old Jun 12, 2012, 06:48 AM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
I reckon the DM2820 as a 880 would rock on 3s for smaller lighter planes swinging 14x7 props. Sort of like the Scorpion 3020-890, but a few less amps in that kV range.
bigroger is offline Find More Posts by bigroger
Old Jun 12, 2012, 07:51 AM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
No. I guess it may be possible to set the throttle curve to do so, but we have data from the original tests that shows some half-throttle setting readings along with WOT to get a better understanding of this. You will see that on average, 50% throttle was 70% of the WOT RPMs, 27% of the WOT Amps, and 27% of the WOT Watts.
This means that more than 70% of the power and consumption of energy comes in the last 30% of the prop speed. There is a lot more going on at the top end that will compensate for the resistance of switching at the lower settings. The increase in current will geometrically increase the relationship between resistance and heat.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Jun 12, 2012, 08:16 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
ok I found franks data, I knew the data was on the webpage somewhere but I think it was somewhat late when I posted the question. Looks like amps rise logarithmically.
I always wondered how you guys could get such long flight times at half throttle when I usually zip around at 3/4-full throttle and seemingly come down with the same flight time. Guess thats why I like my setup as my flight times are now longer than the old 12x6 setups
Old Jun 12, 2012, 09:05 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
It also looks like Lee's data showed about the same results plus or minus a tick or two.
For me, the high speed stuff is not what I'm looking for because I have planes that can do over 110 mph when I feel the need for speed, but with the 48 Edge, I'm averaging about 250mAh per minute.
This means my average current draw is 26A, which is 400W. This also means 70% of WOT Amps and Watts, so as far as stick settings, I'm right in the half-throttle range, according to the average test data percentages.
Old Jun 12, 2012, 09:23 AM
Aberdeen
Joined Mar 2006
I dropped Ken an email to confirm what kv's he can wind and what he can't. He confirmed he could do those I listed above but also using different winding method he can also do a step inbetween those I stated, though he said that it gets difficult.
Depending on the motor he says he can typically achieve 20kv increments, but some arent easy.
Steve
Old Jun 12, 2012, 09:25 AM
Aberdeen
Joined Mar 2006
Anyone have any experience of using the DM3615-750 in a 48" EXP?
Ken gave me details of this motor and in it's light weight version it's only a few grams heavier than th DM2820 and a little shorter. Seems like this might be the ideal motor to spin a 14" prop on the 48" EXP's and not have to compromise on speed or be worried about structural; strangth of the motor?
Steve
Old Jun 12, 2012, 09:44 AM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
Steve
yep, just peeked thru my cowling to see what ken wrote on the 2820...702kv
GetSome! is offline Find More Posts by GetSome!
Old Jun 12, 2012, 12:33 PM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
I am curious why it's not possible to hand wind to within 1% ? I know you can with a semi-automatic process.....as the +/- 1% was a tolerance - ok there was more rigging/tensioners wire feeders and guides...etc... but should be able to do some of this within a hand wired process no?
Space Bat is offline Find More Posts by Space Bat
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 15 Feb 25, 2015 03:15 PM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 10:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 05:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 10:29 PM
