I say stay at 750kv and dial it back or modulate a bit in ke spins or blenders.
I have my dm3615-750 dialed back to 80% to save amps from the lipo on my slick and honestly 65A vs 79A I can't really feel it in flight. Still unlimited vertical and tumbles that make you shake your head in disbelief. |
Latest blog entry: full scale
I am sure the issue of bigger props in high energy spins will be the root cause of alot of these failures....I am sure some motor designs will handle the bigger props better than others.....does anyone own a high speed camera?? I think a prop when spinning and facing gyroscopic loads...will bend and twist that shaft more than people think...something a high speed camera would capture....
Brian,
I've only run the 750 motor in this size with Turnigy batts and struggled to get much over 8500rpm on 14x7 props. On my bigger 3615-750 I am using a 85A ZTW esc and after setting throttle end points as per instructions, I dial the throttle top end point down to 80% or something under 8500rpm at WOT. I fly this way in the 51" slick and it doesn't suffer one little bit. In fact I think it gives my Gens 25C4s2600 lipos a bit more head space doing this as I'm a bit of a throttle hog when it comes to tumbles etc and will use wot if its available to accelerate the plane. |
Have you checked the actual kv?
There are other winding patterns that could achieve in-between kv's (e.g.star, half parallel) but nobody no matter how good they are can wind to precise kv unless that just happens to correspond with a particular winding pattern. The basic fact is you have a number of turns of wire which go in increments of one turn. |
United States, NV, Las Vegas
Joined Nov 2010
want to trade for my 683kv? :-)
I flew my Edge again today, with the 14x8, and that seems to fit my style better! I'm happy with the punch power and the top end speed, so this may be the middle ground I wanted. 53-54a continuous, about 8100rpm, and just over 800w. ![]() ![]() ![]() ![]()
| Thread Tools | |
| Question RC kits for experimenting with flight control systems | SubZer0 | DIY Electronics | 11 | Oct 12, 2011 08:58 AM |
| Wanted left wing for extreme flight yellow and black 74 yak | hondaboy92hatch | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 29, 2011 10:18 AM |
| Discussion Extreme power systems & Royal Evo 12 | rbehrends | Radios | 5 | Oct 11, 2007 05:55 PM |
| Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? | WeatherB | Electric Heli Talk | 6 | Jan 25, 2007 10:29 PM |
