Old Jun 02, 2012, 12:59 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by Aeroplayin View Post
We went through two Turnigy motors in Tom's PA 260 two years ago ... one of them came with the plane when we bought it from a friend ... before we decided that cheap motors were just too expensive. It is not to say that putting very small props on them and running them up to max RPMs in straight and level flight will have the same affect, but we have always sought the bigger prop option, and the cells, and the motor, to accommodate 3D and extreme aerobatic maneuvers.
In flying IMAC sequences, larger props provide more consistent velocity at all attitudes than smaller props, which is important in scoring, and bigger props provide more low RPM torque, and more airflow over control surfaces that are in full departure, so it has always been the direction we have gravitated.
To spin a 24x10 prop on our 50cc airframes between 85 and 88 inches, we went to a very expensive Hacker, but I feel in the long run that the investment will prove to be worth it, just like the Motrolfly has been with the 48 and 60. I actually have a NIB Turnigy that I bought two years ago but never mounted it on an airplane because I had virtually no faith that it would do what it was intended for, or last through any real extreme aerobatic flying for any amount of time. I don't like bashing products, but seeing this only reminds me how passive you really have to be with HK motors. The Plush, K-Force, and Superbrain ESC series, on the other hand, have been as good as, or better than, anything I have used on 48 to 60 size airframes.
I have enough trouble trying to keep from dumb-thumbing a great airframe into the ground, and I donít need any help from motors like this. If anyone is interested in paying the shipping, Iíd be happy to send this HK motor to you for free just to keep it from finding its way onto one of my airplanes in a weak moment, or to keep me from giving it to a club member and having to hear the dark stories from them later.
I'll take it, PM sent
3drcparts is offline Find More Posts by 3drcparts
Old Jun 02, 2012, 03:58 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Originally Posted by stgdz View Post
You are going to really like those combos, way better than the sunnyskys
Flew my motorlfly's today. Not as much punch, power, or speed as the sunnysky motors, BUT the motrofly motors ran about 30 degrees COOLER, and at just about 7 or 8 amps less than the sunnysky motors.
I'm happy with them, as they'll allow me to fly hard during the hot summer months... but I think I'll miss the extra oomph I was getting from the sunnysky motor.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jun 02, 2012, 04:58 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Wow that's the complete opposite that I had with the sunny sky 2820 800.
The things was a complete dog compared to the motroflys. You never were able to post rpms with yours, the rpms on mine were way low for power output.
stgdz is offline Find More Posts by stgdz
Old Jun 03, 2012, 12:38 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
12x6 800 vs 13x6.5 600
The top speed of these two should be the same rite? My laser felt slower on 4s than my 5s mxs and extra.
Old Jun 03, 2012, 12:48 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Speed will be a direct result of prop pitch and RPMs, and RPMs depend on volts, Kv, and Kv efficiency with the specific prop specs, and volts will vary over the course of the flight envelop. Probably more variables too, but that's why I always read RPMs and volts. It tells me everything I need to know.
If the 600 is a Motrolfly and the 800 is something else, then it's tough to even speculate.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Jun 06, 2012, 03:11 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
What was the verdicts of the Xoar 13x7 PJN on the 750Kv motor? Did we see data on this combo yet? looks like the L ratings are clear right through 10,000 RPMs.
Old Jun 07, 2012, 07:03 AM
Joined Nov 2010
I'm interested also, as I'm looking for a little more oooomph out of my setup
Old Jun 07, 2012, 07:59 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I just did some digging and found this from past data. It is probably Steve's numbers:
8971 RPMs @ 79.8% KvE and 64A
I think I have one in prop box and if I do I'll try it on the 638Kv motor on 5S too. If angular momentum has anything to do with motor durability, which so far seems to be the case, then I should be in the clear. I was only getting 9540 RPMs with the 13x6.5e APC.
Old Jun 07, 2012, 08:10 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Yeah, Steve posted the numbers on the 48 Edge thread... Thanks, Steve.
Old Jun 07, 2012, 08:22 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Motrolfly DM2820
Kv: 600Kv
Prop: Xoar 13x7 PJN
Cells: 5S
RPM: 8800 RPM
Watts: 720W
Amps: 40A
Airspeed: 58.3 mph
Static Thrust: 2.81kg
These were my numbers
Old Jun 07, 2012, 08:45 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Motrolfly DM2820
Kv: 600Kv
Prop: Xoar 13x7 PJN
Cells: 5S
RPM: 8800 RPM
Watts: 720W
Amps: 40A
Airspeed: 58.3 mph
I've got them in my chart too... I'm going to try to add a column with the value for angular momentum if I can get the weights for the Xoar props like I have for the APC, and then publish the chart here. So far, I have 19 rows of data for Torque, Motrolfly, and the Sunny Sky on 12x6, 13x6.5, 13x7, 14x7, 14x8.5, and 15x6 prop sizes... from 600 to 820 Kv.
Old Jun 07, 2012, 10:15 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Thanks for the work Aero... these are helpful.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jun 07, 2012, 10:38 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I'm really glad to say that everyone here has contributed, and Steve and a few others put a few motors at risk to deliver some interesting data that begins to show where the edge of the envelop is, so we're all in this together here... but thanks.
Old Jun 07, 2012, 10:45 AM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
I appreciate everyone making the effort. I have learned a lot
GetSome! is offline Find More Posts by GetSome!
Old Jun 07, 2012, 11:44 AM
Joined Oct 2011
Totally... I didn't mean to leave out all the people that have contributed to the testing. Thanks
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 15 Feb 25, 2015 03:15 PM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 10:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 05:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 10:29 PM
