![]() Now Trump want to build yet another And he picks what's about the foggiest place on the planet to build it. I'm no golfer but my guess is it helps if you can see more than 10 yds in front of your nose?Too late.. you got me started
Golf is the main reason I started flying RC again after many years. I can have a lot more fun with a lot less money even when you consider what I just spent powering the 27%. A LOT more fun and A LOT less money. Between me, Tom and my wife, we now have six sets of golf clubs we may never use again taking up valuable space where we can be putting new airplanes.
A much better use would be a rifle/pistol range (I was into competition shooting before) or a flight field! |
I've repaired my DM2820. I followed Ken's instructions and it was all sorted in 15 minutes. I used Loctite 480 to bond the bearing tube into the back mount. Ken actually recommended Loctite 410 but that's harder to find over here, 480 is the same stuff but thinner. Basically 410 and 480 are just CA glue toughened by addition of rubber powder for impact resistance.
The only things to watch if you do the fix to your own motors is to get both parts squeaky clean and also to hit the joint with kicker around the windings immediately after mating the parts. This is because the CA based Loctite will apparently take the coating off the winding wire if it's left in contact for long while it's liquid, and it's hard to be sure that some of the Loctite hasn't squeezed out of the joint onto the windings. Using a small drill (2mm I think) I carefully recessed the bearing tube for the two set screws to locate into and blue Loctited the screws in place. It's all assembled now and feels nice and tight with no play at all. I'll give it 24 hours to cure. Time and weather permitting (and if they havent built a golf course or driving range on my flying site ) I'll give it a test tomorrow. I'll go with a 13x7 Xoar and see how it stands up.Steve Steve |
United States, NV, Las Vegas
Joined Nov 2010
Did you get a weight measurement and run any numbers for the Xoar? That may actually be a great prop for the 750. Tom put the Xoar 12x6 on the Torque 820 that's on the 48 Extra and you could see the difference in power right from takeoff compared with the 12x6 APC. Definitely a few more Amps, though, but in your case, I think it may improve more than one thing.
Missed this part of your post AJ.... We only maidened the Godfrey 27% Extra 300 this weekend because of the high winds from the sub-tropical storm moving up the east coast. Two flights in three weeks now so not a lot of flying. Tom has seven more days of school so if this year is anything last last year, we'll be out four or five times a week. One can only hope.
I still highly suggest putting the 638 on the extra, I'm really liking the setup on mine. The air boss should be able to handle it no problem.
Docs video of the laser was a reminder for of the pullout difference between the 4s 12x6 and the 5s 13x6.5. It just didn't have the acceleration in pullout that the 13" does. I may do a video of 13" vs 14" on the edge for 4s. |
I would suggest you wait for this motor because you will like it on 4S if your preference is the 14 inch prop for high torque, which is the way to go IMO. If you want more speed, then the 750 on a 13x6.5, and 'maybe' a 13x7, will definitely be the speed combo. |
Guys, I put the torque 820 onto my edge today to run up and fly with 4s.
Tried out Apc 12x6, APC 13x6.5, vox 13x5 and Vox 13x6.5 with Turnigy 40C4s2200 cells. Numbers were very interesting and not what I expected. APC 12x6, 10650rpm, 46A, 761W Vox 13x5, 10110rpm, 42A, 646W Vox 13x6.5, 9300rpm, 51A, 796W APC 13x6.5, 9390rpm, 60A, 950W. Of course the APC 13x6.5 seems to really drag out the amps so I test flew on the vox 13x6.5 and apc 12x6. Even though the apc 12x6 and vox 13x6.5 give similar numbers in terms of watts at the meter they seem very different to fly. I flew 6 packs in total, two on the apc 12x6 and 4 on the vox 13x6.5. The vox really seemed to have a lot more vertical pullout than the apc 12x6, post stall was heaps more stable, stable hover, easier to torque roll and snaps and tumbles more aggressive. Maybe it was me setup, but the apc 12x6 really felt anaemic by comparison. Now I know this is probably way above the specs for the torque motor, but as it was just sitting around, I thought why not give it a go. Worst that can happen is burn out the motor, but after 4 packs back to back of pretty hard hucking the torque didn't really feel very hot to the touch. I might keep it this way for a while and fly its guts out and see whats what. I would like a set of Gens Ace 4s2200 to try, as they are heaps lighter than the turnigy 4s2200 from what I can see. |
Latest blog entry: full scale
| Thread Tools | |
| Question RC kits for experimenting with flight control systems | SubZer0 | DIY Electronics | 11 | Oct 12, 2011 08:58 AM |
| Wanted left wing for extreme flight yellow and black 74 yak | hondaboy92hatch | Aircraft - Fuel - Airplanes (FS/W) | 0 | Sep 29, 2011 10:18 AM |
| Discussion Extreme power systems & Royal Evo 12 | rbehrends | Radios | 5 | Oct 11, 2007 05:55 PM |
| Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? | WeatherB | Electric Heli Talk | 6 | Jan 25, 2007 10:29 PM |
