Old May 25, 2012, 08:51 AM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
An iffy thing with these motors is that they don't have there collar on the back. Cabledawg has 100 5s 13x6.5 flights on his though.
stgdz is offline Find More Posts by stgdz
Old May 25, 2012, 09:17 AM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
The very first conversion I did was an 8S on a Frenzy that originally had a Saito 1.25 turning a 16x6 inch Evolution prop to about 9400 RPMs. Since it was my first go with electric, I didn't want to invest in the e-flite 110 so I bought the ExceedRC 110 equivalent for about $45. It turned an 18x8 to 7500 RPMs and 1450 Watts-out, which was a lot of fun. I liked the motor, even though it was a bit heavy, and so I bought the .46 equivalent and used that to swing a 14x7e APC to about 8500 RPMs on a 4S in another coversion from an OS 55.
I also bought the 160 since it was only $50 but never used it, so a flying buddy put it on his plane and magnets starting coming loose from the first flight. He kept gluing them back with black locktite and finally fried the motor and the ESC.
The same kind of hit-or-miss is what most of my friends experience with HK motors. Tom and I could not keep one in the PA 260 for more than a few flights, and when we went to Motrolfly, every motor we bought is still in an airplane with zero failures or issues.
The Frenzy is in the garage with the other retirees, but I'll bet the motor will pull that plane around for quite some time considering that it lasted for about 100 flights, give or take a few. With the new battery technology and weight difference, I'll bet I can shave a few ounces off the plane and improve the performance, but it will never fly like an EXP, so it will sit there on the rack for a long time, I'm afraid.
Aeroplayin is online now Find More Posts by Aeroplayin
Old May 25, 2012, 10:24 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
An easy to fix though... Just reverse the shaft. The other end of the shaft has a flat machined in which I assume is for collar retaining screw to sit against. The rotor has drilling for a bolt on prop adapter, a Hacker one would fit perfectly.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old May 25, 2012, 10:44 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Have any of you come up with a decent HK motor for 8S that can do 2600 to 2800 Watts-in? I'm thinking about an 11 pound plane (5Kg) conversion and would like a 300Kv that can swing at least a 20 inch prop. 22 would be better, of course, but I don't see that happening with a 500 gram motor which will keep the weight about the same as the gas setup. This would be about the same output as a 33 to 35cc gas engine and the new GT33 power is what I'm trying to replicate... about 2400W and 3.2 HP.
Old May 25, 2012, 10:57 AM
Aberdeen
Joined Mar 2006
A couple of possibilities:
http://www.hobbyking.com/hobbyking/s...0KV_2400W.html
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old May 25, 2012, 11:21 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Originally Posted by JetPlaneFlyer View Post
Here is what I see, so please tell me what I'm missing. They say this is a 6 to 8S motor and their test is with 6S using a 17x8 prop to 1312W at 22.2v and 60A.
A 270Kv motor on even 23.2v will swing a 17x6 prop to only 5950 RPMs on 6S and that is only if the motor is operating at a 95% Kv efficiency:
23.2v * 270Kv * 0.95 = 5950 RPMs
A motor only needs 350 Watts to spin a 17x6 prop 5950 RPMs. I'll bet the HK motors will never deliver anything near 95% KvE, which means that at 80%, the RPMs will only be 5010 and the Watts-out will be 205.... now that's a joke, right....
Am I missing something?
Old May 25, 2012, 11:37 AM
Aberdeen
Joined Mar 2006
Yep.. the HK 'test' data often needs to be taken with a large pinch of salt
Old May 25, 2012, 11:41 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
The other motor is showing the same discrepancy in power....
290Kv on 23.2v (6S) with an 80% KvE with a 19x12 prop will spin 5280 RPM which requires 1000 Watts-out. They are talking about 6Kg of thrust. Sorry, but no freakin' way.... Oh, and I just saw that they are calling this a 9-10S motor, so why did they show test data on 6S? This is either crazy, or they think we're just stupid.
Now if I change the volts to 38.67 (3.87v per cell), the 290Kv at 80% Kv efficiency will turn 8970 RPMs. That's 4630 Watts required to do that with a 19x12 (their test prop) at 80%, and 120A.
They state that this is a 78A max motor. Someone must have been using a calculator from Alibaba to figure this out.
Old May 25, 2012, 12:01 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
...struggling to cope with the 14" APC then possibly my similar kv hand wound Scorpion might also be feeling the strain...
Hello!
What is the KV on your hand wound Scorpion? I have the Scorpion SII 3020 890kv.
Stark is offline Find More Posts by Stark
Old May 25, 2012, 12:05 PM
Aberdeen
Joined Mar 2006
Originally Posted by Stark View Post
Hello!
750kv.. I wanted to be able to spin a 14" prop on 4s and it does that really well with fantastic power, but unfortunately it seems that the structure of the motor is not quite strong enough.
It started life as SII 3020 1110kv
Old May 25, 2012, 12:13 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
Thanks!
I'm using my Scorpion in a Sebart Katana S 30 E with 3 cells and a Xoar 13x7. It gives enough power to pull straight out of hover so I'm happy for now.
I've tried the APC 14x7 but I feel that it gives me slower reaction compared to the smaller Xoar for about the same vertical performance.
Old May 26, 2012, 07:18 PM
Subsonic Ken is offline
Find More Posts by Subsonic Ken
Omaha Nebraska
Joined Apr 2008
Sorry for the late reply
We have been doing this modification to all motors in the 28xx size factory built or not.
I would say the 750Kv is still a bit much with the 14x7 for hard 3D flight, precision flying would be fine.
There will be 950, 750, and 680Kv, in the 2820 serries, the 680Kv will be the 4s 14x7 set up, watts about 700.
Should have the 680 in about a month.
Ken
Subsonic Ken is offline Find More Posts by Subsonic Ken
Old May 26, 2012, 07:34 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Ken
Thanks to your fast turnaround, I should have my 680kv back in a few days!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old May 26, 2012, 09:33 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
All this talk about the hot 2820-750 spinning too fast to run the 14x7 prop, why not just trim down your throttle end points?
Tom does it apparently on the 60" with the 4315-480 motor so why not on this 2820-750 motor and trim it down to say 8000 or 8200 rpm at wot?
You can always use a lighter prop than the apc as well, Xoar or Vox are almost half the total weight of the APC and kinda effects the outcome of your angular momentum calcs significantly I think?
Who really needs 1000W on a 48" plane anyway?
bigroger is offline Find More Posts by bigroger
Old May 26, 2012, 09:41 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Ken
Ken,
is this modification to the 28xx range going to be ex factory or SubsonicRC only? ( I am referring to the set screw in the bearing hub being drilled further into the bearing tube)
Question RC kits for experimenting with flight control systems SubZer0 DIY Electronics 15 Feb 25, 2015 03:15 PM
Wanted left wing for extreme flight yellow and black 74 yak hondaboy92hatch Aircraft - Fuel - Airplanes (FS/W) 0 Sep 29, 2011 10:18 AM
Discussion Extreme power systems & Royal Evo 12 rbehrends Radios 5 Oct 11, 2007 05:55 PM
Discussion Battery for Logo 10 - Thunder Power "eXtreme" 5S 4600 or Flight Power 5S 3700? WeatherB Electric Heli Talk 6 Jan 25, 2007 10:29 PM
