Old Apr 11, 2012, 02:51 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Thankfully, I no longer have to worry about this. I found a 2.3mm prop collet at the local rc store and I was able to push it on. The motor is now glued back inside, the fuselage has been glued together and all seams have been taped up with glass-fibre lined tape. Now I just need to grab some sandpaper at work so I can roughen up the CF rods before gluing them to the fuselage and whatnot. Should have this thing up and running in no time!
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 11, 2012, 07:14 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I have had my bix all setup for FPV for 3 days, but the weather has not cooperated at all! It's sunny now but winds are 20+ Hopefully tomorrow.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 11, 2012, 10:12 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
It's been like that here as well. Too windy for FPV. Did manage to get my other planes up yesterday with gusts to 30+mph. Quite challenging. Heading back out in the morning.
Maddmax is offline Find More Posts by Maddmax
Old Apr 11, 2012, 10:13 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
The Bixler loves the wind :-) Go on a slope and you don't even have to use any power... can be in the air for hours :-)
flyandi is offline Find More Posts by flyandi
Old Apr 11, 2012, 10:16 PM
Maddmax is offline
Joined Jun 2011
No slopes around here. You have those nice CALI winds out there.
Old Apr 13, 2012, 05:52 PM
Joined Oct 2011
First Post Crash FPV Flight - 4/13/2012 (4 min 44 sec)
First FPV flight since the crash and 1 month absence... My video RX was NOT this bad, my EZCap is messing up on the horizontal sync for some reason which I need to try to see what I can do to fix that. Also 15 to 20mph winds so it was a bit of a bumpy ride
Old Apr 13, 2012, 07:45 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by NorCalMatCat View Post
http://www.youtube.com/watch?v=lrYow-3IGnM
Glad you were finally able to get it back up.
That must have been hard to fly with the video breaking up like that.
Unless that's normal for you.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 13, 2012, 07:51 PM
Joined Oct 2011
It was just like that on recording, my live display was very crisp and clear the entire flight.
Old Apr 13, 2012, 10:54 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I posted on your youtube video about horizontal sync, I had a similar issue with my nova osd and easycap. Fix is to install a potentiometer/resistor on video wire between rx and easycap.
sammyc is offline Find More Posts by sammyc
Old Apr 13, 2012, 11:19 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Hey mate, potentiometer info as requested. This is the one I used: http://www.jaycar.com.au/productView...SUBCATID=968#1
But I would use a 500ohm pot for more precision: http://www.jaycar.com.au/productView...SUBCATID=968#1
Very simple use a multimeter to find resistance and check wire order to find preferered direction of rotation.
Old Apr 13, 2012, 11:30 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Latest FPV video with bixler some tree dodging fun
FPV fun! Easter 2012 (5 min 10 sec)
Old Apr 14, 2012, 12:13 AM
Joined Oct 2011
Awesome!
Old Apr 14, 2012, 12:19 AM
Joined Oct 2011
Your only using 2 legs of the pot?
Old Apr 14, 2012, 02:13 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
That's all you need. One wire in and one wire out.
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 14, 2012, 02:59 AM
Joined Oct 2011
I'm going to see if radio Shack has one when I go there in the morning to get an rp-sma-sma connector for my 1 watt 2.4Ghz amp
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
