Old Apr 09, 2012, 03:26 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I have to agree with some about the 'pan'. I hardly use it now. It was a novelty at first.
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 09, 2012, 04:13 AM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
Does anyone know if the new gopro turns off its live output feed if the memory card fills up?
rsands2801 is offline Find More Posts by rsands2801
Old Apr 09, 2012, 05:08 AM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Originally Posted by flyandi View Post
anyway the bixler canopy is now 43 bucks at ReadyMadeRC :-)
It's actually $18.99 if you order it without the pan/tilt module.
road_rascal is offline Find More Posts by road_rascal
Old Apr 09, 2012, 09:08 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I can't find it .. can you post a link?
flyandi is offline Find More Posts by flyandi
Old Apr 09, 2012, 09:42 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
You put your osd on a switch???
Maddmax is offline Find More Posts by Maddmax
Old Apr 09, 2012, 11:49 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
OSD screen change
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 09, 2012, 12:27 PM
Maddmax is offline
Joined Jun 2011
Really!!! What channel did you use? I have the Hornet also.
Old Apr 09, 2012, 01:35 PM
Joined Oct 2011
I would imagine you could use whatever channel you like It uses a two position switch.
Old Apr 09, 2012, 01:41 PM
Wirewolf903 is offline
Find More Posts by Wirewolf903
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
The gopro Hero2 always gives live feed as long as battery holds out.
Wirewolf903 is offline Find More Posts by Wirewolf903
Old Apr 09, 2012, 02:21 PM
Joined Dec 2008
On the link I posted you can select what options you want on the drop down menu- the very bottom is the 'no pan/tilt module -$25'.
Old Apr 09, 2012, 05:10 PM
flyandi is offline
Joined Aug 2009
Ahh got it :-) thanks man!
Old Apr 09, 2012, 11:22 PM
Joined Oct 2011
Well I just discovered my Genius CP servo connectors fit my camera just perfectly, so I sacrificed a connector from a stripped servo and now my FPV cam is back up again! So this means tomorrow I can get my first FPV flight in since the crash and loss over a month ago!
Plus I have a 1 watt 2.4Ghz booster coming too .
I still am having vibration issues however which makes my FY31AP not function properly... So my next purchase will probably be a 2200kv motor and a new 6x4 prop, anyone have a good budget recommendation for motor/prop/adapter and preferably from a source known to have everything in good balance?
I also tested my pan mount finally, works good however physically the servo has roughly 180 degree total rotational capability from center (I.E. 90 degrees in either direction), however even with my radio set to 150% travel it only goes about 60 degrees.... anyone have an idea how I can get it to do full travel?
Old Apr 09, 2012, 11:26 PM
Joined Oct 2011
I guess this depends on what you are doing with your setup... I can only see it as an asset honestly... one of my main goals is aerial videography, so having pan is quite handy, espailly when I get set my AP to do a circle around something and just keep the camera focused on what I want, which I plan to do for a few upcoming events in my area (Of course from safe distances :P)
Old Apr 10, 2012, 12:30 AM
Joined Oct 2011
Bah, after doing bench tests with everything I have found out my display totally chops off half of the bottom line of info of my hornet osd... That really sucks because mah used, and home distance are going to be a pain to tell easily... I am sure it's my display to blame... Actually I should hook it up to my ezcap and see how it looks on there...
Assuming weather is OK tomorrow I am going to do an FPV flight which I will record. Will be first FPV flight since crash a month ago, as well as first flight with OSD, and first with camera pan . I have no intention of going much farther then 1500 ft ground distance, and only over open land :P. I think my vibes are still too high for AP to work properly, though I will do a test flight before my FPV flight to see how well it will behave. From what I have noticed thus far with my AP tests is that RTH will probably work fine as long as throttle is fairly low and will more then likely either gain or loose altitude slightly, or bank a little too much, but still would come back towards me enough to regain control, hopefully... but I don't plan to test that tomorrow anyway :P.
At either rate too I should have my 1 watt 2.4Ghz booster in a day or two which should really boost my range.
Old Apr 10, 2012, 07:24 AM
Maddmax is offline
Joined Jun 2011
NorCal,
If you're looking for a good motor, try this one: http://www.gobrushless.com/shop/inde...=MD2505-C-2535
I have 2 different Microdan engines and they are awesome. I'll be buying another one later today for my Skywalker that just came in.
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
