Old Apr 08, 2012, 02:33 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Wow am I glad I took my motor out... I discovered the motor mount was somewhat loose, and one bolt was completely out!
I was having vibration issues messing with my FY31AP, at about 45% throttle the red blinking light would come on (indicating too much vibration), I was really thinking it was my motor bell but when I took it out to bench test I noticed the motor is perfectly balanced, so I shifted my attention to the prop and got it to go to full WOT with hardly any vibration.
This time I glued that mount in where it is NOT going to loosen up :P Now to wait for the glue to dry so I can test and see if the AP is satisfied .
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 08, 2012, 05:38 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
How do I remove the motor mount? Do I pour hot water all over it to melt the hot glue? I seriously need to trash the motor or at least cut off the prop adapter. The motor vibrates far far too much, it's crazy. Why do I always have such bad luck with the bloody awful chinese QC?!
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 08, 2012, 06:11 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
The Sky Surfer is my first FPV platform that does not have landing gear or is a quadcopter. My first attempt to launch by hand with goggles up on my forehead ready to pull down resulted in a nose dive right into the dirt ejecting my camera pod 15 ft! I tried ROG and it worked, but I may not always be at a location where I can do that. Colorado is very harsh. Any tips on how to hand launch with goggles on?
cactus is offline Find More Posts by cactus
Old Apr 08, 2012, 06:50 PM
Joined Oct 2011
Hot water would help in getting it off, I just carefully pulled mine off today by hand because I thought mine was out of balance too (having issues with vibes and my FY31AP), but when I got the motor out and on the bench I found it was actually very well balanced, and I then worked on getting my prop as balanced as I could, and now there is hardly any vibration I can detect at all... waiting on the 'glue' to dry so I can fly it, probably not till tomorrow.
Old Apr 08, 2012, 06:54 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I'm sure my motor is fine, but the prop adapter at the end of the long shaft isn't mounted straight. You can see it move from side to side if you spin it around and if you spin up the motor the whole plane vibrates. It's pretty bad. And because they use some stupid 2.5mm shaft I have to ditch the whole thing since I only have 2 and 3mm collet adapters. So I have to settle for a 1240kv motor until I can replace it with something better.
I'll try hot water tomorrow and see if that works.
Old Apr 08, 2012, 06:56 PM
Joined Oct 2011
Ahh yeah, that will mess it up :P I think a 6x4 is too small for 1450kv...
Old Apr 08, 2012, 09:45 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Anyone can recommend a GoPro cockpit / hints to build it myself for the SkySurfer?
flyandi is offline Find More Posts by flyandi
Old Apr 08, 2012, 09:57 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I used a hairdryer to loosen glue, works alright, easier then using hot water.
sammyc is offline Find More Posts by sammyc
Old Apr 08, 2012, 10:32 PM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
I bought a pan/ tilt pod (without the pan/tilt mounts) from ReadyMadeRC for around $23. So basically it's just the shelf. I'm going to put some photos of it tomorrow in my blog along with some mods I did to it. I would have made one myself but my scroll saw needs new blades.
road_rascal is offline Find More Posts by road_rascal
Old Apr 08, 2012, 10:33 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I'm using a Microdan 2535kv outrunner 7x5 prop and 40A esc on first plane, Microdan 2800kv outrunner 6x4 prop 36ESC on second plane and Himax 3000kv inrunner 6x4 prop 36 A esc on the third plane. Microdan's motors are sweet!!!
Maddmax is offline Find More Posts by Maddmax
Old Apr 08, 2012, 10:45 PM
Joined Oct 2011
I wish I had enough channels for tilt! As it is now I have:
Throttle
Rudder
Elevator
Ailerons
Pan
Autopilot Switch x2
OSD Switch
That is 8 channels, all I have.
I have been thinking about Y'ing the OSD switch, I could then hook up an auxiliary control like a bomb drop or something (Well actually I want to do a bomb bay :P)... although now that I think about it, I could use the pan as an auxiliary too if I thought it out right :P
At either rate I think my bix is not going to get a tilt, just pan. Eventually I will upgrade to a bigger airframe and more channels .
Old Apr 08, 2012, 11:15 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Throttle
Rudder
Elevator
Ailerons
Pan
Autopilot Switch x2
OSD Switch
Time to get yourself a 10 or maybe a 12 channel. LOL.
I have seen some of the very large planes flown using two transmitters in tandem. The main one was used to fly the other for specific control functions like landing gear control or payload release, etc.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 08, 2012, 11:17 PM
flyandi is offline
Joined Aug 2009
Honestly I have Pan/Tilt right now and I barely use it ... I actually fly without because it's a lot easier... if the headtracker gets confused you are in real trouble with it...
anyway the bixler canopy is now 43 bucks at ReadyMadeRC :-)
Old Apr 09, 2012, 12:53 AM
Joined Oct 2011
Yeah I actually thought about that idea... There is a repeater system someone here on rcg is selling that accepts 12 channels input which could come from multiple rxs.
Old Apr 09, 2012, 01:23 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
I have given up a little on pan/tilt, the novelty wore off a bit for me. Still good when doing slow, scenic flying, but I have started to get a bit more aggressive with the bixler
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
