Old Apr 03, 2012, 08:46 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by Maddmax View Post
That's still repairable. I've crashed worse and rebuilt them again. Glad you got it back.
Yeah, it's really not that bad! I should have her repaired tonight and ready to go by tomorrow morning, though we are supposed to have rain until Friday...
All electronics checked out. the 2200mah battery was lower then I would like but it took some charge, I have it sitting at 3.8 per cell, gonna monitor it for any changes before I give it a full charge. The end of it got kind of smooshed up slightly, I dunno if this will effect the battery at all...
The 1300mah was unsaved except for being down to 5.6 volts TOTAL, so I used nimh setting on charger to get it up to a point it would recognize it as a 3s lipo, and also put it to 3.8 per cell.
Camera seems like it tumbled to the ground and scuffed the corner of the metal casing, but otherwise it works fine, vTX transmitted fine (though my antenna seems to have picked up some oxidation, so I am going to clean it), radio RX and servos all worked fine, and the ESC and BEC .
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 03, 2012, 09:12 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I crashed my fpv plane today about 200 yards out. Lost video signal and was flying blind. Could not see it in time when I lifted from the goggles.All the gear survived but the plane looked like crap. I was going to toss it but got it rebuilt. The only part the was unscathed was my plastic bottle nose mod. Go figure???
Maddmax is offline Find More Posts by Maddmax
Old Apr 03, 2012, 09:15 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Foam is such a beautiful material ...
flyandi is offline Find More Posts by flyandi
Old Apr 04, 2012, 10:02 AM
jcooksey is online now
Find More Posts by jcooksey
jcooksey
jcooksey's Avatar
west tn
Joined Feb 2010
Is there a better way then super glueing the elevator and aleron horns on . Two of mine broke loose the other day . I glued back but now I dont have any confidence in them.
jcooksey is online now Find More Posts by jcooksey
Old Apr 04, 2012, 10:54 AM
flyandi is offline
Joined Aug 2009
Use plastic hinges .. cheap and extremely reliable .. get them from your local hobby shop - the Dubro hinges are only about $2 for 10 ..
http://www.hooked-on-rc-airplanes.co...ned-hinges.jpg
Old Apr 04, 2012, 11:02 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
He was asking about horns.
erkq is online now Find More Posts by erkq
Old Apr 04, 2012, 11:07 AM
flyandi is offline
Joined Aug 2009
uhh my bad .. it's early here and I had no Coffee yet :-)
For the horns you should use the ones that come with the back-plate which allows you to connect them via screws. You still should put some glue under them, just for double protection.
For example: http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
Old Apr 04, 2012, 11:15 AM
LiutaS is offline
Find More Posts by LiutaS
LiutaS's Avatar
Ireland, County Louth, Dundalk
Joined Aug 2010
finally done some video from My bixler fpv flights in Ireland
IRELAND Co Louth from birds eye view (4 min 21 sec)
LiutaS is offline Find More Posts by LiutaS
Old Apr 04, 2012, 11:25 AM
flyandi is offline
Joined Aug 2009
Very nice! Gotta love these GoPro's...or?
Old Apr 04, 2012, 12:39 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
RD32II now selling for 87 http://www.ebay.co.uk/itm/1080p-Spor...item3a72925089
Legit version? Seems so, but..
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Apr 04, 2012, 02:20 PM
Joined Oct 2011
Bah, as I was putting my plane all back together last night I found out my camera's 4 pin connector broke! I can't find a connector at aLL that will fit this, now it looks like I will need to wait for an order from readymade before I can FPV
Old Apr 04, 2012, 02:57 PM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
Why not solder the wires to the pins directly ?!
guy1a is offline Find More Posts by guy1a
Old Apr 04, 2012, 03:27 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
What again. Like I said Max you do like to push the envelope more than some.
Nice to know the bottle nose guard worked somewhat.
Care to post some before and after pix?
Eagle202 is offline Find More Posts by Eagle202
Old Apr 04, 2012, 03:52 PM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Great video LiutaS!
road_rascal is offline Find More Posts by road_rascal
Old Apr 04, 2012, 04:08 PM
Joined Oct 2011
My hands are a little too shaky and my soldering iron doesn't have a fine enough tip to get in THAT tight, I had to use a 60x to 100x microscope to even see how the pins where sitting in the connector let alone try to solder it!
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
