Old Mar 29, 2012, 06:07 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Originally Posted by rsands2801 View Post
Forgot to ask, is it normal for the Bixler to climb hard when throttle on, i am struggling to get a nice level flight. My CG is over spar
If trimmed and balanced very well, I find that this tendency nearly disappears.
First thing is check your thrust angle is not too extreme, if stock you shouldn't need to worry much about this.
Then balance so CG is 60mm.
When trimming, I start with glide, so its a gentle descend, not porpoising and trying to hold altitude and flying slow.
Then final adjustment is made at about 1/2 - 3/4 throttle, which should only need a few clicks if any. Should fly level from 1/4 to full throttle.
Remember, trimming to fly level while gliding is pointless and impossible, as you aren't powering to gain altitude. Took me a while to figure this out
sammyc is offline Find More Posts by sammyc
Old Mar 29, 2012, 06:14 AM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
Ye maybe I am trying to make it act like my gas powered edge plane, it flies level no problem but as you say trying to make it do something it isnt designed to do. Around 40% power it will stay steady enough. Will try move the CG forward a bit and see how it flies from there.
Going to build the PVC launch ramp as on calm wind days its proving near disaster to launch.
http://www.rcgroups.com/forums/showt...t=33639&page=2
Good idea or would it be too much for this wee plane?
rsands2801 is offline Find More Posts by rsands2801
Old Mar 29, 2012, 09:11 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Eh? Hang on, how can it be pointless? I suppose it depends on if you want it to be a high speed powered bullet, or a gliding thermal hunter.
If you have it trimmed as the former, then what will happen when your battery runs dry and you have to glide home?
I think you are confusing people that maybe want it to fly as the latter, as I do. That is why I trim for the glide and is not pointless or impossible.
Flypoppa is offline Find More Posts by Flypoppa
Old Mar 29, 2012, 02:02 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I believe what he is saying is you cannot make a gliding plane stay level, that IS impossible, if it's gliding it's loosing altitude, so no point in trying to TRIM it to STAY LEVEL because if it's gliding and you are trying to trim it level it's only going to start porpoising.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 29, 2012, 02:26 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Ah right. I think I misunderstood. It's the way they say it.
Old Mar 29, 2012, 06:06 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Yep exactly no thrust means no altitude gain. Well, we will ignore thermals etc for trimming
If you trim plane for an even descent with no thrust, when flying through a thermal, it should fly level or climb if thermal is powerful enough.
disclaimer: I am inexperienced at thermalling lol
Old Apr 02, 2012, 07:02 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Waiting for the SkyWalker 1650mm to get back in stock .. in the meantime I just ordered the SkySurfer from ToySonics (http://toysonics.com/sky-surfer-4ch-...ess-motor.html) - not bad for $49 with motor.
flyandi is offline Find More Posts by flyandi
Old Apr 03, 2012, 12:29 AM
Joined Oct 2011
I just got the call, the person who has my lost bix is bringing it back tomorrow!!! It took him a month to get around to looking in the plane and finding my name and address tag!
Old Apr 03, 2012, 12:32 AM
flyandi is offline
Joined Aug 2009
Very nice! At least you get it back
Old Apr 03, 2012, 12:58 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Maddmax View Post
I have 4 of these planes and none of them do that????
Late to the party, but me too, except I have just one Bixler. It actually doesn't change horizontal attitude with changes in power except at the two extremes. No power it points down slightly into a nice glide. Full power it points down slightly too, driven by the downward angle of the shaft I would guess. I all other throttle settings it flies straight and level. I has to do with wing/elevator/motor shaft incidence and COG.
erkq is offline Find More Posts by erkq
Old Apr 03, 2012, 01:04 AM
erkq is offline
Joined Dec 2010
But even if maintaining or gaining altitude in a thermal, it will still be pointing down a little to maintain forward speed.
Old Apr 03, 2012, 01:09 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Yes of course.
I have also decided that trimming FPV is very easy, usually I struggle to fine tune rudder LOS, but FPV is much better
Old Apr 03, 2012, 07:16 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Glad to hear your getting your plane back.
Maddmax is offline Find More Posts by Maddmax
Old Apr 03, 2012, 10:20 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
That's great news. It's funny that someone would pick up an RC plane and just not thoroughly check it out. I wonder if he fly's RC or just arbitrarily picks up stuff from the roadway without checking to see if it is worth anything or is dangerous.
Well whatever his reason's at least he is honest to return something to it's rightful owner.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 03, 2012, 10:28 AM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
Wow! I think in addition to my name and phone number, I would ask that they unplug the lipo too!
cactus is offline Find More Posts by cactus
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 06:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 05:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 10:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 11:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 07:08 AM
