Old Nov 11, 2011, 10:46 PM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
Originally Posted by ilovefpv View Post
Why are you considering 2 X 2200 mah packs instead of 1 5000mah pack?
Because I already have 2 2200 mah packs good point tho, I'll try to make an adjustable mount.
rogueqd is offline Find More Posts by rogueqd
Old Nov 11, 2011, 10:55 PM
rogueqd is offline
Joined Apr 2011
Originally Posted by noobee View Post
about 3m extreme tape: i don't think it is uv resistant. i've seen mine become brittle and non sticky after being exposed to sunlight for long periods
yeah, I've seen that too, although I had some on a slope glider that was covered with a layer of colored tape, that lasted forever.
Some people put a layer of clear tape underneath it, so the extreme tape can be removed easily and replaced.
Old Nov 12, 2011, 08:54 AM
fpsazerbaijan is offline
Find More Posts by fpsazerbaijan
FPV Noob
fpsazerbaijan's Avatar
United Kingdom, Scotland, Aberdeen
Joined Jun 2011
Al - is there some kind of tape you've put on the fuselage?
Hi, yes I reinforced the fuselage with cross weave extreme fibre tape, like this stuff: http://www.ebay.co.uk/itm/3M-CROSSWE...#ht_1191wt_952
It's really good at keeping the foam in shape if you have a bit of a mishap, I ran a long length of it under the bottom of fuselage to protect the foam while landing and then put lots on the nose to give it a bit more strength...
Happy flying,
Al
fpsazerbaijan is offline Find More Posts by fpsazerbaijan
Old Nov 12, 2011, 03:32 PM
rogueqd is offline
Joined Apr 2011
Something IBCrazy said was that the best antenna position was under the battery. The battery blocks the signal, so a lot of antenna placement is about getting the signal around it. Since the plane is usually above you, having the antenna under the battery means that you always have a clear path between your two antennas no matter which way the plane is facing.
Here are pictures of the two antenna placements I am considering.
The standard placement is pretty far away from the battery, but the battery blocks some of the path directly in front of the plane. It's also rather exposed in the case of a crash.
The inverted placement the battery blocks a much larger area, but that area is usually towards the sky. It also has much better crash protection. The only downside I can see is that if you are diving while flying towards yourself the battery could be a big problem, although hopefully that will only be when you are lining up for landing and therefore close enough to the receiver that the battery doesn't block the signal.
Standard
Inverted
Which placement does everyone think is better?
Old Nov 12, 2011, 03:43 PM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
Originally Posted by rogueqd View Post
Something IBCrazy said was that the best antenna position was under the battery. The battery blocks the signal, so a lot of antenna placement is about getting the signal around it. Since the plane is usually above you, having the antenna under the battery means that you always have a clear path between your two antennas no matter which was the plane is facing.
Standard
Inverted
since you have not joined the fuselage halves yet, you could consider placing the antenna inside or just above the fuselage but located behind the prop. it's relatively protected from crashes, and even inverted landings.
noobee is offline Find More Posts by noobee
Old Nov 12, 2011, 10:58 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Here's something a little different from me...
iLoveFPV.com 5x5 - Hobby King Bixler + GoPro (0 min 24 sec)
ilovefpv is offline Find More Posts by ilovefpv
Old Nov 13, 2011, 12:07 AM
Wirewolf903 is offline
Find More Posts by Wirewolf903
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
http://www.youtube.com/watch?v=pGgcZJK5WpQ
Thats was cool...what was the crash looks like your wings separated?
Wirewolf903 is offline Find More Posts by Wirewolf903
Old Nov 13, 2011, 07:23 AM
ilovefpv is offline
Joined Jun 2011
Actually that was a scene from my HK Kinetic.. Yes - the wing broke...
Old Nov 14, 2011, 02:12 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
My build.
Never glue an FPV plane - I use Fiber Tessa - Very strong and can be removed many times for service inside the body.
sharonx is offline Find More Posts by sharonx
Old Nov 14, 2011, 03:49 PM
FPV ADDICT
Joined Jan 2011
Originally Posted by sharonx View Post
My build.
Looks good! What's your flying weight and what motor are you using? Thanks
Old Nov 14, 2011, 04:02 PM
sharonx is offline
sharonx's Avatar
RC TIMER 2212-6 2200KV 6X5 aero-nut prop . AWU : 1000g, 1400g with 5000 3s and gopro + case
Old Nov 14, 2011, 04:17 PM
FPV ADDICT
Joined Jan 2011
Awesome...looking forward to the video!
Old Nov 14, 2011, 04:21 PM
sharonx is offline
sharonx's Avatar
http://www.rcgroups.com/forums/showp...57&postcount=2
Old Nov 14, 2011, 11:33 PM
FPV ADDICT
Joined Jan 2011
I like it very cool!
Old Nov 15, 2011, 12:17 PM
FPV Noob
Joined Jun 2011
Osd?
Hi everyone, Im a complete newbie to FPV and just received my Bix for HobbyKing, awesome plane for a beginner , but I also ordered HKs 5.8ghz FPV system and a board camera with a couple of Lipos to power the whole lot, but having watched some of BMSWEBs awesome videos, Id love to have an OSD system, HKing has one http://www.hobbyking.com/hobbyking/s...dProduct=17140 Ive also heard of the Remzibi OSD (thanks BMSWEB!). Anyone got any ideas? The only function that is a definite requirement is the GPS with return to home arrow, so are there any cheap and easy to setup systems out there?
Thanks for any help and happy Bixling,
FPS
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
