Old Feb 29, 2012, 04:43 AM
shaprap is offline
Find More Posts by shaprap
Videography and stuff
shaprap's Avatar
Joined Oct 2009
HOLY CRAP!
Steve, take a look at the new DIY Bixler FPV Camera Mount from Hobbyking
Reminds you of anything???
http://www.hobbyking.com/hobbyking/s...ra_Mount_.html
shaprap is offline Find More Posts by shaprap
Old Feb 29, 2012, 04:56 AM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
wow....I wonder where they got THAT idea.
kokopropelli is offline Find More Posts by kokopropelli
Old Feb 29, 2012, 05:40 AM
hooligan russ is offline
Find More Posts by hooligan russ
me, right now.
hooligan russ's Avatar
United States, NC, Clayton
Joined Nov 2009
I also plane to use one battery to power the plane and video system, but I'm not exactly sure which filter to get.
Could someone possibly provide me with a link to a specific LC filter that I could use.
hooligan russ is offline Find More Posts by hooligan russ
Old Feb 29, 2012, 06:04 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Lucky im feeling nice lol
http://www.rcgroups.com/forums/showp...34&postcount=4
sammyc is offline Find More Posts by sammyc
Old Feb 29, 2012, 10:53 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Thanks for posting about the cap and ring.
Maddmax is offline Find More Posts by Maddmax
Old Feb 29, 2012, 12:12 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
If you don't want to make one you can get this unit. I use this one as well as making my own in the past.
http://www.readymaderc.com/store/ind...roducts_id=138
cactus is offline Find More Posts by cactus
Old Feb 29, 2012, 01:13 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Woohoo I got FY31AP and Hornet OSD on the way, I can't way to get that installed and setup
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Feb 29, 2012, 03:24 PM
me, right now.
Joined Nov 2009
Originally Posted by sammyc View Post
Well, I am Irish. -thanks sammy
ah, good to know, thanks for the link.
Old Feb 29, 2012, 04:13 PM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
guys
the Bixler is fixed and ready for test !
also ..
here is the current status of my ground station
ground station (1 min 44 sec)
guy1a is offline Find More Posts by guy1a
Old Feb 29, 2012, 05:47 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
Originally Posted by Wirewolf903 View Post
Heres my third SkySurfer build. It's a V1 that I wanted to build as a portable FPV TANK to backpack around that could carry my Hero2, FY-21AP with OSD. The fuse is not glued but taped together with fiber tape. I just maiden it a couple days ago without a crash. The motor prop and ESC combo works great and I need the two 2200 lipos in parallel all the way up front to get the CG right. I'll be posting build pics on my blog if anyone's interested in checking it out.
Here's the spec in my build and FPV equ:
SkySurferPRO FPV
Skysurfer Version 1 Portable with ACU Camo Armored Skin
Turnigy D2826/6 2200KV Motor
Readymade Outrunner Brushless Motor Mount for EasyStar/Sky Surfer
40Amp Birdie ESC with 50amp Burst
APC-E 7x4 Prop
9g Metal Gear Servos x6
2 Turnigy 30C 2200 mAh in parallel all the way in the front powering everything
FY-21AP and FY-117OSD
Futaba T10CHG 2.4G Transmitter
Orange FASST 8ch TFR8S Receiver
Weight: 1960 grams/4.3 lbs
FPV Gear
900 MHz Wireless Video Systems
900 MHz FM Wireless 500mw A/V Transmitter
Tiny 1” wide X 1.99” high X a very slim
.33” thick and weight is only 3/4 ounce
12 volts at 250mA
Ibcrazy DIY Vee Antenna mounted to the tail
GoPro Hero2 with video out to OSD
Ground station
This is still a work in progress.
Two 900 MHz receivers
RangeVideo Micro Diversity controller
Ibcrazy DIY BiQuad Antenna and an Omni Antenna
15in LCD TV
Head play goggles
SuperCircuits Portable DVR/Receiver with 2in display( it's an older one and looking to upgrade)
All mounted in 1550 Pelican Case
http://www.youtube.com/watch?v=EJ07L...e_gdata_player
I LOVE this skin idea and makes the plane much better looking and durable for the rough terrain we have here in Colorado. Do you have more photos of the type of tape you used and how you applied it? Did it add allot of weight? I get my RMRC V1 Brushless combo this weekend and was going to paint it, but I like this idea better.
Old Feb 29, 2012, 09:25 PM
Maddmax is offline
Joined Jun 2011
That's a cool bird, but 4.3lbs!!! I thought mine was heavy at 2lbs and my Himax 2815-2000kv was struggling a bit. I've since swapped that motor out for a 2815-3000kv with a 6.4e prop. I'll test it this weekend with all the weight.
Old Feb 29, 2012, 11:26 PM
patfly is offline
Find More Posts by patfly
Lifelongflyer
patfly's Avatar
United States, NM, Silver City
Joined May 2005
First Sky Surfer Video
Here is my first published FPV video. I have only 3 FPV flight (attempts) including one costly crash. I am Taking off and landing LOS and using a spotter while trying to figure it all out.
Thanks to all on this forum for your info and answers.
Check it out.
Sky Surfer in New Mexico (2 min 53 sec)
patfly is offline Find More Posts by patfly
Old Mar 01, 2012, 04:17 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
very nice patfly
i don't like the pan/tilt stuff .. can't find any use for it.
good job !
Old Mar 01, 2012, 07:06 AM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Originally Posted by shaprap View Post
HOLY CRAP!
Now that's a sharp looking design! ;-)
ilovefpv is offline Find More Posts by ilovefpv
Old Mar 01, 2012, 09:58 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Check it out.
http://youtu.be/Zs8OMGjrLxg
Nice flight. My Sky Surfer is being delivered today! Is your COG off a bit? Seems like you where porpoising a bit. I like your pan tilt. I am doing the same with a mechanical head tracker soon.
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
