Old Nov 08, 2011, 04:10 PM
Wirewolf903 is offline
Find More Posts by Wirewolf903
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
Originally Posted by Arck View Post
WOW, thanks, I will do that, I ordered the 17 dolar sony Camera for the FPV, which is better,,,,and for the range, is mandatory for the 5.8g 200mw FPV Wireless AV to change the antenna? which one do you suggest,,,,
I'm currently using a 900 MHz system with the Vee antenna on the plane and BiQuad and Omni diversity at base. This system will get you out past your standard/stock transmitters 1 mile to 1.5 mile range. I built both myself using ibcrazys DIY.
From what I'm seeing his new designed antennas are rock solid. I just read on one of his threads a guy with his system went out to 30km with solid video!
Here's his blog which has links to all his DIY...he also sells the antennas if you just wanna buy em.
http://www.rcgroups.com/forums/member.php?u=103113
Ibcrazy newly designed antennas; for plane Cloverleaf and Helical antenna for ground station. Some are also using another cloverleaf for the second diversity antenna. This is one of my next builds.
Wirewolf903 is offline Find More Posts by Wirewolf903
Old Nov 08, 2011, 05:29 PM
Arck is offline
Find More Posts by Arck
I land with enthusiasm
Arck's Avatar
Lima-Peru
Joined Aug 2004
Thanks. What kind of the HK 900 mhz for the bixler do you suggest. I can change my order up today.
Arck is offline Find More Posts by Arck
Old Nov 08, 2011, 11:49 PM
FPV ADDICT
Joined Jan 2011
The system you ordered will do FPV just fine. IMO the 900mhz has less interference, at least in my area. A 200mW system would be fine to use as long as you stay within the control range of your stock transmitter and upgrade the two antennas to at least a Vee and patch or BiQuad. If you plan on going further then that look at a 500mW or 800mW for medium range from 2 miles to about 4 with a hacked radio.
Old Nov 09, 2011, 08:39 AM
Arck is offline
Arck's Avatar
Lima-Peru
Joined Aug 2004
Thanks, Hummm,,,I was thinking to change to 900 MHZ 200mW, because of the great information I a found here and antenna constrution,,,,,,,,my order was cancelled and is pending for a desicion, the airframe will be the blixer, so I need what fits in it and is the best from HK, up to 2 miles range is sufficient for me with 9CAP futaba radio and PCM receiver,,,,,
What to do,,,,,
Old Nov 09, 2011, 07:52 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Nice video! How u like that HK Wing Cam? I really like mine, did u know it can do live view and record...it's very good for FPV with that 120 FOV. I'm gonna set it up in a mini Skywalker in the future.
Can you post a link to the wing cam? I'd like to see this...
ilovefpv is offline Find More Posts by ilovefpv
Old Nov 09, 2011, 07:54 PM
ilovefpv is offline
Joined Jun 2011
Hi Steve, only with velcro and packing tape for extra secure on the top of the rigth wing, Im thinking it will be better on top of the nose?,,,,,,
I think the angle you have it mounted at was throwing me off a little.
You'll might like the results better if you put it on the nose..
Old Nov 09, 2011, 08:27 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I believe this will get you to the HK wing cam.
Vince
http://www.hobbyking.com/hobbyking/s...dproduct=17200
Eagle202 is offline Find More Posts by Eagle202
Old Nov 09, 2011, 08:29 PM
ilovefpv is offline
Joined Jun 2011
Thanks Vince!
Old Nov 09, 2011, 10:57 PM
FPV ADDICT
Joined Jan 2011
Ya you can get it at HobbyKing...the video I posted on page one was recorded with the Wingcam. The FOV is 120 which is great for FPV. The only thing better is the GoPros 170 FOV!
Old Nov 10, 2011, 07:06 AM
ilovefpv is offline
Joined Jun 2011
FOV = Field Of View?
Old Nov 10, 2011, 07:37 AM
Arck is offline
Arck's Avatar
Lima-Peru
Joined Aug 2004
Thanks, yes I think so,the nose will be better,,,,,,
Old Nov 10, 2011, 07:42 AM
Arck is offline
Arck's Avatar
Lima-Peru
Joined Aug 2004
Vince
Thats my cam, is really good for the price, I noticed that to see like HD, is better to copy the video to the PC and not direct from the Micro SD into the camera, the videos are big in AVI so go for 4gb SD and up.
Old Nov 10, 2011, 12:33 PM
Arck is offline
Arck's Avatar
Lima-Peru
Joined Aug 2004
And for the motor, should I change the motor due the extra weight? if so some people recommended the Turnigy 2835-3900KV with 6x4 APC but is inrunner, I think the stock motor is outrunner, more power is a must in FPV for the Bixler? should I need to separate the frames to installing it? or the stock motor with 6x4 APC ist OK. , what motor do you have in your Bixler,,
werner
Old Nov 10, 2011, 12:37 PM
FPV ADDICT
Joined Jan 2011
Yes sorry FOV= Field of View in degrees
Old Nov 10, 2011, 12:44 PM
FPV ADDICT
Joined Jan 2011
werner
I'm still running the stock motor with a 6x4 APC and its a little under powered for all the FPV gear IMO. I fly around a lot of trees and need that extra thrust at time just to get up and clear em. My current set up take some space to get up off the ground. I'm wanted to try a 3900kv and put my GOPro without the hard case and see if it will work.
I have this motor mount. I haven't tried it yet but from what I hear it works well and allows easy on off of motor.
http://www.readymaderc.com/store/ind...products_id=13
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
