Old Feb 20, 2012, 10:55 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
OK, managed to get everything working. Next step is to get the Remzibi OSD programmed and working.
Maddmax is offline Find More Posts by Maddmax
Old Feb 20, 2012, 11:13 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by Flypoppa View Post
From what I have read, there can be a delay in the transmission when hooking up the RX via Easycap to the laptop. So this could cause problems.
From my experience with using the EasyCap and laptop as a viewing device is that the delay is not noticeable unless you have a screen and it side by side, and even then it's only going to be a few frames off (milliseconds).
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Feb 20, 2012, 11:39 AM
Maddmax is offline
Joined Jun 2011
Cool, thanks. I'm going to try this before I commit to getting the goggles.
Old Feb 20, 2012, 01:54 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
What sort of weight are most running with the FPV gear? I will have Sony camera, OSD, GPS and then seperate battery. My FPV battery is 165g so quite heavy!
How are the HK weights on website showing? Are they accurate to a finished plane?
rsands2801 is offline Find More Posts by rsands2801
Old Feb 20, 2012, 02:07 PM
HiFlyer371 is offline
Find More Posts by HiFlyer371
Bill
HiFlyer371's Avatar
United States, NE, La Vista
Joined Jul 2007
The HK website does not include FPV gear and only a 1,300 mah battery in the Bixler's weight.
My Bixler is 1.3kg (42 ounces) with GoPro, 3,000 mah flight battery, 1,000 mah FPV battery, eLogger/OSD Pro and FPV transmitter. The nose and bottom has fiberglass cloth applied with water based poly. Other users have listed the same setup at 1.2kg.
HiFlyer371 is offline Find More Posts by HiFlyer371
Old Feb 20, 2012, 02:19 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
I'll bring the goggles when we go flying this weekend...
Might change your mind..
-Steve
www.ilovefpv.com
ilovefpv is offline Find More Posts by ilovefpv
Old Feb 20, 2012, 03:37 PM
Joined Dec 2007
im thinking a 2200mah FPV battery is a bit much for the FPV gear and receiver
Old Feb 20, 2012, 03:45 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Yeah... that's a good size for the motor.
erkq is online now Find More Posts by erkq
Old Feb 20, 2012, 08:14 PM
Maddmax is offline
Joined Jun 2011
Thanks Steve. Go ahead, rub it in!!! And I'll bring the Zephyr, so maybe you'll change your mind!!!
Old Feb 20, 2012, 11:38 PM
Joined Oct 2011
I fly with a 2200mah for motor, 1300mah for FPV, 140 grams of landing gear as well... the plane can handle it .
Old Feb 21, 2012, 04:56 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
guys .. maxi swift is ready
now i have time to start working on my bixler
i have a 5.8 system for it. plan is to use it for short range high adrenaline bad ass FPV
Caesarea night FPV 2 (0 min 46 sec)
guy1a is offline Find More Posts by guy1a
Old Feb 21, 2012, 07:08 AM
Joined Dec 2007
well after a weigh in last night I got 460g of FPV gear. Then extra 50g for a larger flight battery so I am looking like the 1.2kg is going to be about right for the weight
Old Feb 21, 2012, 08:51 AM
Maddmax is offline
Joined Jun 2011
Hey Guy, What's the tall tower in the video?? What OSD are you using?
Old Feb 21, 2012, 10:10 AM
guy1a is offline
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
The tower is not a tower... it is the exhaust of the power plant.
The osd is cl-osd
Old Feb 21, 2012, 11:01 AM
ilovefpv is offline
Joined Jun 2011
I definitely want to see the Zephyr... Have you flown it yet?
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
