Old Feb 19, 2012, 12:47 PM
fpsazerbaijan is offline
Find More Posts by fpsazerbaijan
FPV Noob
fpsazerbaijan's Avatar
United Kingdom, Scotland, Aberdeen
Joined Jun 2011
Hi again!
Your best option is to buy the ARF version that comes with a brushless motor pre-installed, servos and all of the necessary hardware like Y-leads etc.
Here you go: http://www.hobbyking.com/hobbyking/s...544&aff=464726
Then all you need is a 20-30A ESC (I use a 30A for peace of mind), and upgrade the propeller to a TGS 6x4E for some serious power
Very cheap and efficient 30A ESC (what I use): http://www.hobbyking.com/hobbyking/s...205&aff=464726
Prop: http://www.hobbyking.com/hobbyking/s...936&aff=464726
2200mAh 3s will be fine
I have a full setup/overview video of all the mods I used on my FPV Bixler:
HobbyKing Bixler Setup (16 min 30 sec)
In terms of FPV I think that it is the best beginner plane that you can buy if you are just getting into FPV- cheap, stable and very very durable (learnt from crash experience
Here's my FPV setup for the Bixler:
Super Simple FPV Setup (13 min 20 sec)
Anything else just ask
Cheers!
-Al
fpsazerbaijan is offline Find More Posts by fpsazerbaijan
Old Feb 19, 2012, 02:00 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by rsands2801 View Post
Good plane for FPV then? V1 it is. Maybe this motor?
http://www.hobbyking.com/hobbycity/s...idProduct=7993
with a 2200mah 3s lipo?
With that motor It looks like you would have to turn the shaft around.
Flypoppa is offline Find More Posts by Flypoppa
Old Feb 19, 2012, 02:13 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I like the cheap fpv setup!! But isn't your camera velcroed to the top of the plane going to be too wobbly??? It doesn't look real stable.
Maddmax is offline Find More Posts by Maddmax
Old Feb 19, 2012, 02:24 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Ahh! Bad hand launch resulted in ripping my LG out! Took a nice 6x1.5 inch chunk of foam out to the one side of my fuse spar, and some damage on the other side of it.
I already cut a new piece of foam to put in there, glued it in, and used 8 Popsicle sticks (4 in, 4 outside) as bracing and support for the LG. Luckily it was a pretty clean break out (I guess left hand wheel hit the ground first, as that side ripped out, then on the other side the bolts that hold LG on just ripped out!).
I was just getting ready to FPV
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Feb 19, 2012, 06:04 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
All ordered
order the ARF, ESC you suggested and then 2 x 2700mah Zippy Compact 25C batteries. They only 199g so not much of a sacrifice for weight compard to the 2200mah (about 20g difference) The compact range seem way more weight efficient
rsands2801 is offline Find More Posts by rsands2801
Old Feb 19, 2012, 06:45 PM
Joined Oct 2011
All ordered
Yeah that is why I got one, I have been FPVing with 2200 for motor and 1300 for fpv, so for me I will actually be saving about 40 grams (Using a zippy compact 500mah 3s for FPV)
Old Feb 19, 2012, 09:11 PM
Maddmax is offline
Joined Jun 2011
Does anyone know how to hook the video tx to a laptop??
Old Feb 19, 2012, 10:28 PM
Joined Oct 2011
The video TX? If you wanted to broadcast your laptop display you could but you would have to change the display resolution of the computer to match the vTX resolution or it wouldn't look right.
Old Feb 19, 2012, 10:33 PM
Maddmax is offline
Joined Jun 2011
What are you using for a cable from the tx to the laptop?? RCA to USB cable??
Old Feb 19, 2012, 10:44 PM
Joined Oct 2011
Are you talking about viewing FPV on laptop (Receiver not TX?)? It's called EasyCap
Old Feb 19, 2012, 10:45 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Easycap is what ur after?
sammyc is offline Find More Posts by sammyc
Old Feb 19, 2012, 11:02 PM
Maddmax is offline
Joined Jun 2011
Thanks. That's what I was thinking about but wasn't sure what the name of it was. I want to use my laptop as the viewing device when I fly fpv.
Old Feb 19, 2012, 11:55 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Just got my video goggles - these are great!!
http://www.ilovefpv.com/2012/02/fat-...esbox-opening/
ilovefpv is offline Find More Posts by ilovefpv
Old Feb 20, 2012, 02:54 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
From what I have read, there can be a delay in the transmission when hooking up the RX via Easycap to the laptop. So this could cause problems.
Old Feb 20, 2012, 10:13 AM
Maddmax is offline
Joined Jun 2011
Now my Gopro won't work on live video!!! One thing after another!!!
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
