Old Nov 30, 2011, 01:45 PM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
I finally glued the tail of my Bixler last night. I glued the tail only, to a couple of cm past the vertical stab. I'll tape the rest so I can still access the insides.
I found that the left half (viewed from rear) of the fuse was molded 1mm lower than the right where the hori stab connects. I'll post a pic when I have time tomorrow. So the stab would have leaned to the left if I'd just stuck it on and trusted the joins to line up correctly. I put a tower of coins under the stab to keep it level with the main wings while the glue dried.
I also replaced the motor with this one. It fit on to the stock wooden mount but I had to cut the "ribs" out of the inside of the motor hole to allow it enough room to spin freely.
Just a few small mods to go and I'll finally be up and flying.
rogueqd is offline Find More Posts by rogueqd
Old Dec 01, 2011, 02:57 AM
guy1a is online now
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
crashed mine today.
the CF rod in the wings that i reinforced with another rod CAed in it.
broke like it was made of butter ...
i was runing very fast ( full speed ) and very low ( i hit a water sprinkler in a field )
the damage is mostly moral
i will upload a video later.
guy1a is online now Find More Posts by guy1a
Old Dec 01, 2011, 04:39 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Anyone know any good and available landing gear?
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Dec 01, 2011, 05:30 AM
guy1a is online now
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
have you tried asking google ?
http://www.airscaperc.com/Landing_Gear.php
http://diydrones.com/profiles/blogs/...rfer-and-other
and more..
Old Dec 01, 2011, 06:24 AM
Joined Oct 2011
Originally Posted by guy1a View Post
Yeah I already had found that but they are not currently available, I was hoping someone had a good suggestion for something else they know would work well.
Old Dec 01, 2011, 06:55 AM
guy1a is online now
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
it is not one of the best things happened to sky s / bixler / easy start / ....
they are ment to be wheel-less ...
imho
Old Dec 01, 2011, 09:33 AM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
crashed mine today.
Ouch!
ilovefpv is offline Find More Posts by ilovefpv
Old Dec 01, 2011, 03:34 PM
guy1a is online now
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
1 12 2011 Bixler FPV & crash Large (4 min 36 sec)
Old Dec 01, 2011, 03:46 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Am I the the one that can't open the video?
Flypoppa is offline Find More Posts by Flypoppa
Old Dec 01, 2011, 03:58 PM
Joined Oct 2011
Apparently the video is no longer available. Yeah they are designed to be wheelless but it doesn't hurt to have them
Old Dec 01, 2011, 04:00 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Get it sorted Guy.
Old Dec 01, 2011, 06:06 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Yes.
2500GENE is offline Find More Posts by 2500GENE
Old Dec 01, 2011, 08:05 PM
ilovefpv is offline
Joined Jun 2011
Looking better now.. ouch...
I forget - which OSD do you use? Are you really 400 feet below sea level?
-Steve
Old Dec 01, 2011, 08:31 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
crashed mine today.
guy1a
I had plans on installing a 4 mm rod into the stock 6 mm to reinforce the wings. But I heard others that did that also had both split on them in a crash.
So instead of a carbon tube i found out that others have used a metal tube or wires to reinforce the main carbon tube. I cut a piece of #20 awg wire a little longer than 5 times the length of the rod. I then folded it 4 times and twisted them a couple of times. I then used the extra length (about 4 inches) on both ends to wrap the larger wires together. This got me a flexible stranded wire tube. I made sure the diameter of the wire tube was less than the ID of the 6 mm rod. Slide it into the rod and glued one end so it would stay.
It might not increase the rigidness of the wing support but if that should crack the stranded wire should maintain its form and not allow the wings to fold up.
The good/bad news is that i haven't crash tested it yet but i have high hopes it will not allow my planes wings to fold coming out of a loop.
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Dec 02, 2011, 01:00 AM
Joined Oct 2011
Anyone using flaperon setup? If so what do you recommend, and do you do elevator mixing at all with it? Any benefits to it with this plane?
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
