Old Dec 11, 2012, 07:26 AM
Scorpio9999 is offline
Find More Posts by Scorpio9999
The only R/C pilot in the city
Scorpio9999's Avatar
Kazakhstan, West Kazakhstan Province, Aksay
Joined Sep 2012
New FPV-er needs advice
Hi everybody!
Components for FPV are arrived or on its way to me.
I come up with:
FatShark Dominators + 5.8GHz module
ArduPilotMega 2.5 + GPS + airspeed sensor + Arduino MinimOSD
Immersion VTx 5.8GHz 600mW
SpiroAntennas for VTx and VRx.
GPS located in nose at front of canopy inside fuselage.
APM2.5 located in bottom of fuselage right behind hole in belly.
Wing camera is mounted on canopy in slit.
Question is: where to locate OSD and VTx to get minimum interference?
Scorpio9999 is offline Find More Posts by Scorpio9999
Old Dec 12, 2012, 01:00 AM
Zangetsu57 is online now
Find More Posts by Zangetsu57
United States, CA, Camarillo
Joined Sep 2010
Has anyone managed to fit a Gopro plus a FPV camera, with the FPV camera on a pan/tilt (not necessarily the GoPro) on a Bixler? I'm trying to figure out a good way to accomplish this without obscuring the vision of either camera.
Zangetsu57 is online now Find More Posts by Zangetsu57
Old Dec 12, 2012, 10:15 AM
uavrat is offline
Find More Posts by uavrat
Joined Jan 2012
Check this out:
http://www.rcgroups.com/forums/showthread.php?t=1697449
I have one but have not built it yet. Just pulled from box and checked it out. Very nice design, I think you could cut the Bixler nose to fit this pod. Some other builders have suggested cutting the Bixler nose, shore up the inside with plywood and foam to strengthen the nose. If you did that I am pretty sure this mount would do well. Just mind your CG....
uavrat is offline Find More Posts by uavrat
Old Dec 12, 2012, 11:37 PM
Joined Sep 2010
Originally Posted by uavrat View Post
Check this out:
Thanks for the link, it looks pretty nice. Since the pan is direct drive, however, I worry how well the servo would hold up in a high-g maneuver or a crash given the weight of the cameras. That said, modding it to a gear-driven pan probably wouldn't be too difficult.
Old Dec 14, 2012, 06:58 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
Okay im going to change the stock servos and stock horns on my bixler v1 to something better, will the HTX900 servos work or should i go for some metalgrear digital servos? im using RVOSD and when autopilot is engaged im worried about the servos gears... due to much load on the servogears. any opinion here? also if i remove the stock horns i cant use the stock clevis because it will broke.. what to use instead? thank you
timtimtim is offline Find More Posts by timtimtim
Old Dec 14, 2012, 07:07 AM
farmertom is online now
Find More Posts by farmertom
My planes plow into the field
farmertom's Avatar
United States, TN, Taft
Joined Oct 2012
Hi,
Take a look at the Hitec HS-65MG (metal gear) and the HS-65HB (Karbonite gears)
I have had servo failure on several of the stock Bixler servos and have replace all with these. Use metal on elevator and aileron and karbonite on the rudder. I think the HXT-900 are OK for flaps. They are also just a little smaller that the stock servos and fit into the foam cut-out nicely.
Good Luck
farmertom
farmertom is online now Find More Posts by farmertom
Old Dec 14, 2012, 08:09 AM
Joined Apr 2012
Originally Posted by farmertom View Post
Hi,
Take a look at the Hitec HS-65MG (metal gear) and the HS-65HG (Karbonite gears)
Good Luck
farmertom
Thank you! i was looking at these HS-65MGs and i know they are very good but what do you think about these?http://www.hobbyking.com/hobbyking/s...dProduct=16342
Old Dec 14, 2012, 01:45 PM
farmertom's Avatar
Joined Oct 2012
I have no idea about those. Try them and give us a report. They sure are less expensive than the Hitec servos. Good luck..
farmertom
Old Dec 24, 2012, 10:02 PM
SU-4ever is online now
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
More progress with aerial "plane chasing" filming!
FPV CHASING FLIGHT HD (17 min 41 sec)
Enjoy!
SU-4ever is online now Find More Posts by SU-4ever
Old Jan 01, 2013, 06:24 PM
jaguar1126 is offline
Find More Posts by jaguar1126
Malaysia, Penang, Balik Pulau
Joined Feb 2011
hi, how did you mount your go pro here? i got my blitz sky surfer but having problem to place my battery. i cannot balanced the plane as my go pro creating a lot of weight on the plane nose. any tips on this. thank you
jaguar1126 is offline Find More Posts by jaguar1126
Old Jan 01, 2013, 06:56 PM
TwostrokeTimmy is offline
Find More Posts by TwostrokeTimmy
United States, WI, Baldwin
Joined Jan 2013
Anybody ever mount snow ski's on their Sky Surfer?
TwostrokeTimmy is offline Find More Posts by TwostrokeTimmy
Old Jan 01, 2013, 07:08 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
Here is what I did, not pretty, but one idea.
Mounted it on CG so I can have on or off with no CG changes.
It can be extended higher with the GP extensions.
Also a GP pic from the GP view.
Have the VTX all the way back and using coax for the video.
OSD and other FPV gear in the fuse up front.
I layed sand paper down on top of the fuse and then sanded the block down to fit the contour of the top. Then glassed it on and also made a bolt mount in the air channel to run a long bolt thru to attach the GP bottom mount besides the DS tape. It has to tear a chunk out to come off.
kilwein is offline Find More Posts by kilwein
Old Jan 02, 2013, 01:28 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
got all my FPV gear ready for my bixler
nightfox7 is offline Find More Posts by nightfox7
Old Jan 03, 2013, 10:49 AM
Huginn81 is offline
Find More Posts by Huginn81
Joined Mar 2012
Hi guys.
I have a Bixler and I want to ask you guys about flight times.
When I am flying with FPV equipment I only manage 10 minutes of flight time and
when I fly the bixler LOS I manage only 20 minutes
I have seen allot of people talk about 40 minutes flight time.
Now I want to ask you how long flight time are you getting when flying fpv.
This is my setup
Bixler 1
FPV camera and recorder Gopro hero2
Video Tx Immersion 5.8 ghz 600mw
Radio Rx Frsky
ESC: H-KING 20A Fixed Wing Brushless Speed Controller
Motor: 2620-1900kv Brushless Outrunner
Propeller: TGS Sport 6x4E
Battery: ZIPPY Flightmax 2200mAh 3S1P 20C Gives 10 minute FPV flight time
Battery: Turnigy 1300mAh 3S 20C Lipo Pack Gives 10 minute FPV flight time
Cyclops Storm OSD is in the mail and I think that should give me some idea of how much mah I am draining when I fly with the current sensor.
I usually fly with 35-50% Throttle
Huginn81 is offline Find More Posts by Huginn81
Old Jan 03, 2013, 02:34 PM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Originally Posted by Huginn81 View Post
Hi guys.
This is my setup
Bixler 1
Radio Rx Frsky
Peope who are getting that much flight time are using multiple flight batteries connected in parallel or one BIG battery, 2 2200mah or one 5000mah for example. It also depends on your setup. I'm running a rctimer 2200kv motor with 30a esc with a 7x4 prop, I'm getting upwards around 18-20 min flight time with a single 2200 flight battery. Thats including full Eagle Tree, HD recording camera and FPV gear.
I'm not to familiar with the Cyclops gear, or if it has data recording capabilities. If it does, this will help you out tremendously in figuring out where you mah is going. Whether its a throttle management issue or a power plant issue.
I also found this nifty little calculator to help me play with different power combo's without having to actually buy the components:
http://www.ecalc.ch/motorcalc_e.htm?ecalc
Good Luck!
Ryan
kokopropelli is offline Find More Posts by kokopropelli
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
