Old Nov 11, 2012, 06:30 PM
TimeTrave1er is offline
Find More Posts by TimeTrave1er
United States, CT
Joined Oct 2012
Ok I broke my stock Sky Surfer wing spar. It was the first part that broke on my plane... so I ordered a couple replacement wing spars from readymade and just went out and flew with a new spar.
Broke it on the first flight on landing. Now I'm down to 1 more wing spar and I'm starting to get worried that I'm going to need a new wing spar everytime I want to fly. Does anybody know where to buy a stronger wing spar that fits the sky surfer online? This would be very much appretiated because I don't want to keep paying $5 for thin plastic rods.
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Nov 11, 2012, 07:02 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Wow, that was a badass cloverleaf antenna...
Huge!
SU-4ever is offline Find More Posts by SU-4ever
Old Nov 11, 2012, 07:24 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
There is a modification that strengthens the stock 4mm spar by adding to smaller 2mm solid spares inside the bigger one. Be sure to roughen up the surface of the smaller spares with sand paper then you can use hot glue or CA to glue the 2 smaller ones inside.
Another way to help you not break your spar would be to power down at the top of a loop. Let gravity take it back around. If you power through the loop you will stress the spar trying to pull out of the dive which could fold your wings.
Eagle202 is offline Find More Posts by Eagle202
Old Nov 11, 2012, 11:55 PM
antennahead is online now
Find More Posts by antennahead
antennahead's Avatar
Joined May 2007
Originally Posted by polyfractal View Post
To play devil's advocate:
I've spent many, many hours crawling through these forums looking for information. Not everyone has time to read the whole 1000+ page Bixler thread, or 150 pages in this thread. I had a banking problem on my Sky Surfer which took days to hunt down. I asked and no one responded, so I was left to digging through years of posts here at RCGroups. I eventually found the problem in some old post, buried in the middle of the massive thread.
Don't get me wrong, I think the forums are a great resource. But there is something to aggregating all the hard-won knowledge, removing all the myths, superstitions and misinformation, and packaging it into a friendly format.
I think it would be a great resource personally.
I'm very curious as to your problem and the solution?
antennahead is online now Find More Posts by antennahead
Old Nov 13, 2012, 10:33 AM
United States, CT
Joined Oct 2012
God d*mnit!! I lost the prop adaptor thing on my stock sky surfer today. I flew it up like 45-50 feet in the air and it was slightly windy out. All of a sudden I try and turn using the alerons and some wind comes at the same time and rips both wings right out of the fuselage. Then somehow the prop adaptor came off and the prop flew off too. I found the prop no problem but couldn't find the prop screw thingy after an hour or two of searching.
Does anybody know where I can buy a stock sky surfer prop adaptor?
Old Nov 13, 2012, 12:32 PM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
Buy this CF tube (or equivalent size somewhere else) and insert it inside your stock spar. It fits perfectly, although you may need to gently tap it with a hammer to slide it all the way in.
It was a pretty rookie mistake, which most people probably would have noticed immediately. But since I'm new to RC planes in general I didn't think to look for it.
Basically, my tail feathers were not straight. They were angled to one side, which was causing my plane to gently bank. I glued a thin CF rod to the tail feathers and the whole assembly returned to being parallel to the wings. Banking fixed
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Old Nov 13, 2012, 04:39 PM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
There are many solutions to this ongoing problem. I chose to go to walmart and buy a CF arrow. These are extremely strong, built NOT to break and made to withstand huge amounts of force. To make it fit into the stock spar hole, I took a small piece of coarse grit sandpaper, wrapped it once around the end of the arrow and glued it. Then slowly reemed out the hole until it fit the arrow. You might have to trim down the arrow, use a band saw or cut off wheel on a dremel.
kokopropelli is offline Find More Posts by kokopropelli
Old Nov 13, 2012, 06:49 PM
Joined May 2007
[QUOTE=polyfractal;23258681
Basically, my tail feathers were not straight. They were angled to one side, which was causing my plane to gently bank. I glued a thin CF rod to the tail feathers and the whole assembly returned to being parallel to the wings. Banking fixed [/QUOTE]
Your not alone, on my first one, I didn't have the horizontal stab square to the wing, And since the rudder is glued to the h stab, The rudder was crooked and caused the plane to the go left all the time. Took me a long time to fiqure out what was wong!! and after having to cut both the rudder and H stab off twice to get it right, I then started to mod all of my planes to have bolt on tails so that I can easily add shims if needed to cure any alignment problems.
Old Nov 14, 2012, 04:44 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Chasing Dad's MX2 with the SS
greedyg76 is offline Find More Posts by greedyg76
Old Nov 16, 2012, 07:30 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
My Bixler was my first REAL RC Airplane, first FPV experience, and really has a lot of centimental value to it, but it appears my Bixler will be being retired quite soon as an FPV ship. My Super Skysurfer is quite close to maiden, and once I have it dialed in how I like and get all my test and dial in flights out of the way all FPV gear will be transfered over.
I will still fly my bixler, but not FPV anymore. I will use it as my testbed for ideas or quick and easy grab and go flyer.
However I do plan to squeeze in a few more FPV flights on her before that of course .
Here is the last FPV flight I did, video is from my new 808 #16 v2 (For $40 you cannot beat this camera!), the flight was pretty tame and close just to test out the 808 cam, I can't wait to get a bit more flights in on this camera.
FPV Over King Salmon, CA - 11/10/2012 (15 min 11 sec)
For anyone interested in my Super SS build you can visit the build log at http://fpvlab.com/forums/showthread....urfer-Buildlog
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Nov 23, 2012, 07:50 PM
Joined Oct 2011
This is the final FPV flight of my Bix, FPV gear will now be moved to the SSS now that I have maidened it!
Final FPV Flight of the Bixler (13 min 5 sec)
Old Nov 23, 2012, 09:30 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Parlin park (5 min 25 sec)
nakelp86 is offline Find More Posts by nakelp86
Old Nov 23, 2012, 09:32 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Made it to the shore after hurricane (4 min 50 sec)
Old Nov 23, 2012, 10:07 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Originally Posted by nakelp86 View Post
Hope you and your family are doing ok after that storm. I have see pictures and video showing the Seaside Heights boardwalk and can't believe how many times I have been there while I lived in NJ and now see the destruction that Sandy did to it.
Thanks for the video. Take care.
Vince
Old Nov 23, 2012, 10:17 PM
Joined Oct 2011
I lived in Seaside until I was 18 years old (live in Cali now), it's quite odd to really see it like that...
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
