Old Oct 29, 2012, 05:35 AM
Wirewolf903 is offline
Find More Posts by Wirewolf903
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
Originally Posted by SU-4ever View Post
And now I'm proud to present you...
My first FPV recording:
https://vimeo.com/52328054
Hope you really enjoy it!
Great video very well done!
Wirewolf903 is offline Find More Posts by Wirewolf903
Old Oct 29, 2012, 07:39 AM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Thanks!
I have to work a bit on the video quality for a better result, keep on tuned!
SU-4ever is offline Find More Posts by SU-4ever
Old Oct 31, 2012, 08:19 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
ilovefpv is offline Find More Posts by ilovefpv
Old Nov 02, 2012, 12:53 AM
krise is offline
Find More Posts by krise
also known as ke123
krise's Avatar
Canada, AB, Edmonton
Joined Dec 2007
You want to sell back the knowledge you gleaned from the forums? Dude..
krise is offline Find More Posts by krise
Old Nov 02, 2012, 01:23 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Interesting post .. didn't even think about that. If that's the case, it will create a lot of bad blood...
flyandi is offline Find More Posts by flyandi
Old Nov 02, 2012, 01:47 AM
krise is offline
also known as ke123
krise's Avatar
Joined Dec 2007
Yeah... There are many others that have far more FPV experience sharing all this knowledge for free..
This guy has been using all the tricks to make money - harvesting emails from forum users, mass emails with affiliate marketing links, and now selling ebooks of freely available information.
It has reached the point of ticking me off.
Old Nov 02, 2012, 07:03 AM
ilovefpv is offline
Joined Jun 2011
Sorry guys - didn't think of it that way - I'm dropping the project...
Old Nov 02, 2012, 10:30 AM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
To play devil's advocate:
I've spent many, many hours crawling through these forums looking for information. Not everyone has time to read the whole 1000+ page Bixler thread, or 150 pages in this thread. I had a banking problem on my Sky Surfer which took days to hunt down. I asked and no one responded, so I was left to digging through years of posts here at RCGroups. I eventually found the problem in some old post, buried in the middle of the massive thread.
Don't get me wrong, I think the forums are a great resource. But there is something to aggregating all the hard-won knowledge, removing all the myths, superstitions and misinformation, and packaging it into a friendly format.
I think it would be a great resource personally.
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Old Nov 02, 2012, 10:59 AM
krise is offline
also known as ke123
krise's Avatar
Joined Dec 2007
Mine is but a single opinion, let's keep in mind.
Old Nov 02, 2012, 02:06 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Ilovefpv, I'm not gonna buy your ebook but don't let it down.
If someone doesn't want to read it, then just don't buy it.
But there's no reason to just drop it. It's really nice that someone takes the time to do the hard information gathering work. It's even nicer if he or she makes it for free but you are in your right to sell it.
In any case, always remember to quote your sources
Cheers!
Jandro.
Old Nov 07, 2012, 02:11 PM
mandevil is offline
Find More Posts by mandevil
mandevil's Avatar
Joined Jun 2011
I'm researching my future FPV setup and I'm rather unclear about one thing: how should I power the transmitter. Should I use second auxiliary battery or is it enough to power the TX from the main battery the plane is flying on? I worry about adding too much weight and hassle -- the plane is already fairly heavy with just my GoPro.
mandevil is offline Find More Posts by mandevil
Old Nov 07, 2012, 02:46 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I'm using the main battery without trouble
Old Nov 07, 2012, 03:04 PM
Joined Jun 2012
People do both. The advantage of using a separate battery (usually something small, like a 400mAh) is that the video system is isolated from the noisy ESC/Motor circuit. You can get a clearer picture with less effort (don't have to shield cables, add ferrite rings, etc)
The downside is extra weight and another battery to charge.
I think the majority of people power their transmitter straight from the main flight battery. It introduces a bit more interference that you may have to clean up, but simplifies the setup. A VTx only eats around 0.3-0.7 Amps so the effect on flight time in negligible.
Site Sponsor
Old Nov 07, 2012, 04:01 PM
mandevil is offline
mandevil's Avatar
Joined Jun 2011
Thanks for your reply.
I'm not good with electronics, so the idea of trying to suppress ESC interference scares me. I checked HK and 300 mAh 3-cell battery weighs 38 g. My planned TX draws 300 mA, so it should definitely last half an hour.
Old Nov 07, 2012, 05:37 PM
Joined Jun 2012
I'm not good with electronics, so the idea of trying to suppress ESC interference scares me. I checked HK and 300 mAh 3-cell battery weighs 38 g. My planned TX draws 300 mAh, so it should definitely last half an hour.
No problem
I started with a second battery as well. I liked that route because I could verify that everything was working before trying to integrate.
Luckily, removing interference from the ESC is pretty easy. You'll know you have interference from the ESC because it is connected to throttle changes. When you increase your throttle, if the video gets more interference...it's a sure sign of your ESC.
The easiest solution is to add a ferrite ring on the cable going from your ESC to receiver. If that doesn't fix it, an LC filter will take care of the rest.
Site Sponsor
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
