Old Oct 07, 2012, 11:42 PM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Originally Posted by wavekatcher View Post
I went ahead and pulled the trigger on the SS from Readymaderc.com.
I will be installing the cnc motor mount so I can swing a bigger prop and run a bigger motor than stock.
Any suggestions? I'm thinking the firepower 450 sport from Headsuprc.com with a APC 8X5E. The numbers from Headsup show 24 ounces of thrust @ 17 amps w/ APC 8X6 w/ 3s battery.
If the SS AUW is 39 ounces will 24 ounces of thrust be enough?
Enough for what?
kokopropelli is offline Find More Posts by kokopropelli
Old Oct 07, 2012, 11:53 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Originally Posted by geminiryan View Post
Enough for what?
Blending margaritas?
Or, maybe....... efficiently pushing around a heavy model up in the air while looking at a tv screen through a camera mounted on said model?
wavekatcher is offline Find More Posts by wavekatcher
Old Oct 08, 2012, 12:08 AM
Joined Jan 2012
People are doing crazy things with the SS these days...so ya never know what kind of strange franken-surfer will come along.
Looks like a good motor, I would be curious to hear how it does.
I do like the idea of a portable Margarita blender...
Old Oct 08, 2012, 09:25 AM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
SS limbo FPV!
2012-10-07 FPV Flight 1 (RAW) "Limbo Edition" (9 min 37 sec)
ToxicToast is offline Find More Posts by ToxicToast
Old Oct 08, 2012, 09:47 AM
Joined Mar 2011
Nice flying. Do your friends have baseball cups in place?
Good place to fly. What do you have to protect your SS on the landings?
Old Oct 08, 2012, 09:58 AM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Haha, thanks. I use zip-ties with the nubs cut off and glued to the taped fuse bottom as skids. Works well but needs to be replaced after 20 or so flights.
Old Oct 08, 2012, 01:58 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by ToxicToast View Post
Fantastic video dude :-)
Could you post some close ups of yr SS set up?
what motor/prop are you using?
nakelp86 is offline Find More Posts by nakelp86
Old Oct 08, 2012, 06:17 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
After replacing my defective 5.8GHz Tx, This sunday I was able to fly for first time this plane in FPV mode! (3rd fllight) and even landed googles-on!
Wow, this is such an amazing feeling...
It's going to become a nice addiction!
Cheers!
Jandro.
SU-4ever is offline Find More Posts by SU-4ever
Old Oct 08, 2012, 06:47 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
careful, i tried a bigger prop on my easystar (with ailerons of course) and the results have been "interesting", in that it is unable to turn left because of all the motor torque.
then again, i am using a 9x5 prop on a 680 watt motor that i originally put in my funcub... no idea of the thrust, but draws 55 amps at 12 volts... and it still won't climb vertical (not exactly a light plane =P )
baconflyer is offline Find More Posts by baconflyer
Old Oct 08, 2012, 10:45 PM
Joined Mar 2011
thanks Bacon,
I went ahead and ordered 3 different motors to try. Exceed Rocket 2215.
1500kv, 1700kv and a 1950kv. I'll try the 1950kv 1st. They have test numbers posted with a 6X4 prop....showing 265 watts @ 22 amps.
Old Oct 09, 2012, 09:43 AM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Thanks! BP hobbies 2212-6 (2200kv), 30A ESC, with a 6x5 APC prop. About 45mph on a flat WOT run, just about 3lbs AUW with GoPro. Not very good climb, but good for down-low flying.
Link to some setup photos: http://www.rcgroups.com/forums/showp...8&postcount=88
Pretty much the same as the photos, but a lot more beat up after 9 hours on the airframe!
Old Oct 13, 2012, 10:49 PM
Joined Mar 2011
glue for build
delete
Old Oct 14, 2012, 12:08 AM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Is Beacon Foam Tac the best stuff to use with the SkySurfer foam?
You should ask this in the primary Bixler/SS thread. I prefer Welders, Goop, and regular CA on EPO planes like the SS.
Old Oct 14, 2012, 03:24 PM
polyfractal is offline
Find More Posts by polyfractal
polyfractal's Avatar
United States, SC, Charleston
Joined Jun 2012
Cheers!
Jandro.
Pretty awesome feeling isn't it! I'm brand new to both RC flying and FPV, but I personally found flying FPV a lot easier. For me, it was easier to correct mistakes before they happened. Starting to bank the wrong way? Easy to apply corrective measures since I'm looking through the plane's eyes, rather than trying to figure out orientation on the ground.
I thought landing was a lot easier too. Just bring it in low and slow. Although I found that it is easy to misjudge how much runway you have left while coming in for an FPV landing...almost skidded into a tree
polyfractal is offline Find More Posts by polyfractal
Site Sponsor
Old Oct 15, 2012, 12:55 PM
SU-4ever is offline
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Aaah, ya know...
I started with a wrong FPV setup and lost a plane with everything inside.
Now I'm doing it from lesson 1, step by step and everything is easier!
I thought landing would be troubling but the bixler has proven easy to bring back.
I aim to fly an EDF90 L-39 Albatross with FPV, but still I have lots to learn before that!
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
