Old Aug 01, 2012, 09:19 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by flyandi View Post
New Bixler V2 in stock now at HK:
http://www.hobbyking.com/hobbyking/s...laps_ARF_.html
with flaps .. but a lot more expensive.
Yeah but they added clevis on the push rods and looks like the wings have an overlapping connection. The fuse has what looks like a access panel under the cockpit, air hole in the front and a grove for a carbon spar for strength. For $70 that is a sweet looking kit.
Eagle202 is offline Find More Posts by Eagle202
Old Aug 01, 2012, 11:40 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Originally Posted by timtimtim View Post
Can anybody verify if the stock bixlermotor shaft is 2.3mm?
Just measured my shaft at 2.5 mm
greedyg76 is offline Find More Posts by greedyg76
Old Aug 02, 2012, 06:02 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
are you using the stock prop and adapter?
timtimtim is offline Find More Posts by timtimtim
Old Aug 02, 2012, 11:04 AM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
Yes, stock adapter. It's the one that is pressed on to the shaft, no collet or set screw. On my stock motor, the shaft is 3mm right were it exits the bell then necks down to 2.5mm before the prop adapter. My calipers are cheap ones so maybe the measurement is off by a bit?
Old Aug 03, 2012, 06:38 PM
bmschulman is offline
Find More Posts by bmschulman
VP of Policy & Legal at DJI
bmschulman's Avatar
United States, NY, New York
Joined Oct 2006
Also they say they changed the boom design to allow clearance for larger props. That might be helpful.
bmschulman is offline Find More Posts by bmschulman
Old Aug 03, 2012, 11:29 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Bixler Maiden
It took forever to get this in the air. My first maiden I had a pan servo mounted on the nose, purchased from Hobby wireless the FPV 180* servo. Worked fine in the shop many times. Took it to the field turned on my radio then the plane, checked the pan and it continuously rotated in a clockwise direction, winding up all the camera wire and ripping it out of the fuse "looked like spaghetti rolled up on a fork"
So for now I glued the camera to the fuse. I also took my ESC out of the fuse and mounted it on top.
I ended up putting 3 mill NS out to the center of the ailerons to stiffen the wings.
FPV BIXLER MAIDEN (3 min 6 sec)
Eternalflight is offline Find More Posts by Eternalflight
Old Aug 04, 2012, 02:41 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I haven't posted a video in here in a minute! So I think I shall...
A cloud surfing flight from the other day:
Nice Summer Cloud Surfing (2 min 17 sec)
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Aug 04, 2012, 01:03 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
i won't take that out of context.
baconflyer is offline Find More Posts by baconflyer
Old Aug 04, 2012, 01:04 PM
Joined Jul 2011
so, what do you guys think, should i get a bixler v1, a bixler 2, or an axn floater?
Old Aug 04, 2012, 07:18 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I was looking at the v2 Bix, but decided to stay with the v1 because of the high winds here. I seems smaller wings are better in my circumstances so I guess I should say "it depends". I don't know anything about an "axn floater".
erkq is online now Find More Posts by erkq
Old Aug 10, 2012, 04:55 AM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
http://www.youtube.com/watch?v=cC6Rb4JHVHk
Very nice - what OSD are you using?
Great paint job too...
-Steve
www.ilovefpv.com
ilovefpv is offline Find More Posts by ilovefpv
Old Aug 10, 2012, 05:39 PM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
anyone tried flapperons with this or would dedicated flaps closer to the fuselage work better?
Lpbug is offline Find More Posts by Lpbug
Old Aug 10, 2012, 07:06 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
I tried flaperons but didn't like how the plane handled during landing approach with the extra drag out near the wing tips. Felt very "mushy" which doesn't feel good as you get closer to the ground. Use all the area you have from the inside edge of the aileron to about 1/2" from the fuselage for cutting flaps. Flaps alone will slow the approach speed considerably and you'll still have full range use of the ailerons.
I wanted to try a Crow or Butterfly set up, but couldn't figure out the mixing.
Old Aug 10, 2012, 07:18 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
We might be a little partial in this thread...
Old Aug 10, 2012, 07:54 PM
bmsweb is offline
Find More Posts by bmsweb
bmsweb's Avatar
Australia, VIC, Melbourne
Joined May 2011
I thought I would share my Bixler Setup that I'm currently using. Hope you find it helpful.
PART 1
HK FPV 5.8Ghz Bixler RC Glider Setup - Basic FPV Gear and Layout on Aircraft - Part 1 (4 min 46 sec)
PART 2
HK FPV 5.8Ghz Bixler RC Glider Setup - Basic FPV Gear and Layout on Aircraft - Part 2 (9 min 1 sec)
bmsweb is offline Find More Posts by bmsweb
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 06:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 05:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 10:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 11:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 07:08 AM
