Old Jul 02, 2012, 03:04 AM
bmsweb is offline
Find More Posts by bmsweb
bmsweb's Avatar
Australia, VIC, Melbourne
Joined May 2011
Originally Posted by Grazer View Post
. . .better than some crap the Mrs has ordered!
Well I got a delivery today and it was for the . . . . Mrs :'(
bmsweb is offline Find More Posts by bmsweb
Old Jul 02, 2012, 03:06 AM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
Nice Choice of plane . . I have a skywalker also but I'm pretty sure my one is a little smaller
Haha! Love the commentary from you son. I was p#%*^#% myself.
Must be great sharing your hobby with your offspring.
Grazer is offline Find More Posts by Grazer
Old Jul 02, 2012, 03:08 AM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
So where is the Bixler flight footage? I wanna see that!
Old Jul 02, 2012, 03:30 AM
bmsweb is offline
bmsweb's Avatar
Joined May 2011
Yes flying with the little man is pretty awesome. Last Thursday he maidened his first aircraft . . Micro EDF Red Arrow lol
The video before turbodriven crash is the only video I uploaded of the Bixler flight that day. It was getting dark and cold pretty quick so I didn't fly for long, but the sunset was nice
Old Jul 03, 2012, 08:58 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Hey Turbo, try adding a few mor ecf rods into your wings to get them stiffer. I would also recommend a film covering for your wings and stabilizer to avoid future disasters. I use a 3 mill thick clear laminate on the wings and a 1.7 mil thick on the elevator and stabilizer. Makes them rock solid and absolutely no flex. I got the film here: http://www.canuckengineering.com/new.../film-covering
Look at the pics of the last plane I built. It doubles as an fpv plane and a stunt plane!!!
Maddmax is offline Find More Posts by Maddmax
Old Jul 04, 2012, 02:54 PM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
The wing structure was fine until the glue holding on the spar cover let go. once that broke free the wing had no chance. I suppose an adhesive film covering over that cover may have helped prevent that. Or better glue
I wish the spar channel was built in like some other versions. May be it's harder to manufacture like that?
turbodriven is offline Find More Posts by turbodriven
Old Jul 04, 2012, 05:16 PM
Bhuwan is offline
Find More Posts by Bhuwan
United States, MA, Boston
Joined May 2012
Anyone have a picture or suggestions on hooking up the Keychain 808 Cam?
Bhuwan is offline Find More Posts by Bhuwan
Old Jul 04, 2012, 11:08 PM
Maddmax is offline
Joined Jun 2011
WHY??? The wing spar design is so much better now on the newer versions. You simply need to add more rods and stiffen your wings up more. I also use 2 3mm rods through the top of the plane thru the screw holes and down into the bottom of the plane. Monkey glue all that together and it will never break. I just broke a set of wings from the plane I crashed into the river but that joint did not fail!!! So stop whining and get to work!!
Old Jul 04, 2012, 11:39 PM
DragonFly711 is offline
Find More Posts by DragonFly711
Will try to fly anything.
DragonFly711's Avatar
United States, TX, Athens
Joined Dec 2011
On the subject of stiffening the wings, I filled the hollow CF spar that came with the plane with expanding foam and it stiffened it up quite a bit and doesn't really add any weight.
It could be stiffer but just by doing what I did cut the flex down in the wings at least in half and it flies beautifully.
Donnie
DragonFly711 is offline Find More Posts by DragonFly711
Old Jul 04, 2012, 11:48 PM
Maddmax is offline
Joined Jun 2011
You can shove more rods into each wing from the side, just make sure you stay perpendicular and don't punch a hole through the wing. I normally add a 3mm rod in front of the main spar towars the leading edge. I also add another 3mm rod behind the main spar towards the trailing edge. This will help take out a lot of flex.
Old Jul 04, 2012, 11:49 PM
Joined Dec 2011
You can buy this mount and velcro your camera to it. HobbyKing sells them for the Bixler for less than $4. Not the camera though, that's separate.
You can just velcro your keychain cam to the top of the plane anywhere actually, or even on the wing somewhere.
Donnie
Old Jul 04, 2012, 11:56 PM
Maddmax is offline
Joined Jun 2011
Or just cut a small slot in the canopy and stick it in there.
Old Jul 05, 2012, 08:11 AM
Bhuwan is offline
Joined May 2012
Donnie
Sweet thanks - I was actually thinking about buying that but I couldn't figure out the best way to mount the camera to it.
I tried that but thing isn't straight
Old Jul 05, 2012, 08:27 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
If you just want to mount a keychain cam, some velcro on the nose is the easiest way to do it.
I a good strip over the nose offered a good range of mounting angles, as you really want the camera pointing down slightly to see the ground, instead of the big old boring blue.
sammyc is offline Find More Posts by sammyc
Old Jul 05, 2012, 10:13 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I use Velcro and a snap swivel tied to the battery cable inside the plane.
I also have a rubber band as a third connection point.
Vince
Eagle202 is offline Find More Posts by Eagle202
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 06:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 05:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 10:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 11:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 07:08 AM
