Old Jun 15, 2012, 09:07 AM
lanty is offline
Find More Posts by lanty
United States, MA, Nantucket
Joined Dec 2011
Originally Posted by cactus View Post
Sounds like the ESC is not seeing 0 throttle and is not initializing. Couple of things to check:
1. Is your Throttle channel reversed?
2. Do you have the trim moved up on the Throttle channel?
Throttle is not reversed and there is no trim on the Throttle.
The plot thickens.
lanty is offline Find More Posts by lanty
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Originally Posted by lanty View Post
I'm new to the world of R.C. and I have a question about setting up my DX7. I'm currently using the Dx7 set on helicopter for my quadcopter. How do you go about setting it up to use for both quad and skysurfer?
I'm not too sure if the settings I have it on now are causing the esc to beep continuously.
thanks.
You need to create 2 separate models in the radio. One airplane and one helicopter. For a quadcopter, you can actually use airplane mode on the Dx7. Helicopter mode adds a few things you don't need for flying a quad, but it will still work. One nice thing it does add is Throttle Hold. This facilitates an instant stop on the motor regardless of the position of the left stick. Helpful on Collective Pitch helicopters when you are about to crash.
So, crack open your manual and read up on how to create new models of each type. Let us know how you do. I had a Dx7 for a while. Great radio.
cactus is offline Find More Posts by cactus
Old Jun 15, 2012, 09:09 AM
cactus is offline
Joined Sep 2001
The plot thickens.
What Rx are you using? Where did you get your SS? Do you have a picture of your setup?
Old Jun 15, 2012, 09:11 AM
DragonFly711 is offline
Find More Posts by DragonFly711
Will try to fly anything.
DragonFly711's Avatar
United States, TX, Athens
Joined Dec 2011
thanks.
You need to set up a completely new model separate from the quadcopter with a new receiver bound to the trans for the new plane. I have a DX6I but it shouldn't be much different from the DX7 when setting up new models.
The transmitter is beeping because it's not recognizing your new plane until you create the new model and bind the new receiver to the DX7.
You won't be able to use the same receiver for both the quad and the plane if that's what you are talking about. It would never work. The settings are too different from plane to heli and just swapping the receiver from one to the other isn't feasible. I don't think that's what you mean but thought I'd throw that out there.
Donnie
DragonFly711 is offline Find More Posts by DragonFly711
Old Jun 15, 2012, 09:14 AM
lanty is offline
Joined Dec 2011
Donnie
So when I set up a new model will it save my settings for my quad?
Last edited by lanty; Jun 15, 2012 at 09:16 AM. Reason: terrible english from an english man.
Old Jun 15, 2012, 09:22 AM
cactus is offline
Joined Sep 2001
Yes, but like he said you can't share the rx with both models.
Old Jun 16, 2012, 07:14 AM
lanty is offline
Joined Dec 2011
fixed.
Fixed the problem. I just added a new model on the DX7 and she was ready to go.
All I have to do now is drill out my new prop so it will fit and she will be ready for her 1st flight.
Thanks for all of the help.
Old Jun 16, 2012, 04:56 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Don't use a drill!!! It will most certainly cause an imbalance, get a prop reamer .
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jun 17, 2012, 11:02 AM
lanty is offline
Joined Dec 2011
I followed your advice and she is ready for take off.
The only problem now is my destination. I'm in Nantucket for the summer and its windy a lot of the time. Its been really windy most of the month i've been here.....my wife is not willing to change our summer vacation based on how windy the beach is.
Today its gusting around 14 mph.
What's the most wind you guys are comfortable flying in?
Old Jun 17, 2012, 01:46 PM
Joined Oct 2011
That really depends on one's skill level... I have flown with winds 15 to 20 on the ground, and I am sure a bit higher up in some altitude... But I also use an autopilot with stabilisation at the same time... LANDING in those sorts of winds is where it becomes a real challenge .
Old Jun 17, 2012, 02:16 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I have flown in winds of 25-30mph. Gets challenging but it's a lot of fun. Puts your skill level to the test. Landing is fairly easy if you do it against the wind. You can get it to basically stand still before touching down.
Maddmax is offline Find More Posts by Maddmax
Old Jun 17, 2012, 03:01 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
I find there is a direct relationship between how windy it is and how much glue I will need LOL.
idletime is offline Find More Posts by idletime
Old Jun 17, 2012, 06:33 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Max
I agree it is easier to land against the wind. Although when you want to get down fast I sometimes forget that and end up coming in too fast then begin spinning and tumbling on impact.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 17, 2012, 06:44 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by Eagle202 View Post
Max
You do that every Sat night after one of your drinking binges too.
2500GENE is offline Find More Posts by 2500GENE
Old Jun 17, 2012, 07:04 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
If it ain't on film it never happened. That's my story and I'm sticking to it.
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
