Old Jun 11, 2012, 01:03 PM
R2276B is offline
Find More Posts by R2276B
Joined Feb 2006
Mix some up elevator with the throttle on a switch. Full throttle= full up elevator.
Hand launch plane. It will dip, then climb and you'll have time to get back to the sticks.
Make it a linear mix, so as you throttle back the elevators return to level.
Use the switch to return to normal flight control.
R2276B is offline Find More Posts by R2276B
Old Jun 11, 2012, 01:26 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I agree using a programmable transmitter to improve the launch capabilities of these type of planes will help but mine originally came with a very simple 4 channel transmitter without any mixing abilities.
Unless the plane has been modified to something totally different from it's original format you shouldn't need a sophisticated transmitter to fly it. Just make sure the CG is correct, then throttle up to 70%, toss it straight and then pull back on the elevator. She will fly.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 11, 2012, 02:12 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Yup. Of course I haven't loaded mine down with anything... yet...
erkq is online now Find More Posts by erkq
Old Jun 11, 2012, 03:25 PM
Reegor is offline
Find More Posts by Reegor
USA, CA, San Diego
Joined Apr 2007
Starting at hand-launch speed with full up-elevator is a recipe for a stall.
Remember that at the start the goal is more speed, not more altitude. It takes several seconds for the motor to accelerate the plane, even at full throttle. During those seconds, high angle of attack guarantees a stall.
You could always add LG, and accelerate down the runway. Then you can zoom up in the usual RC non-scale way.
Reegor is offline Find More Posts by Reegor
Old Jun 11, 2012, 04:34 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Here's my two crashes for the weekend:
First one wasn't very bad damage at all.
Bixler is totalled from mid-air breakup (0 min 49 sec)
sammyc is offline Find More Posts by sammyc
Old Jun 11, 2012, 04:52 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
http://youtu.be/zRtGO8pC0kQ
Looks like the first crash caused some weakness in the airframe which failed causing the second crash.
Old Jun 12, 2012, 08:20 AM
Hayvosh is offline
Find More Posts by Hayvosh
Sweden, Piteå
Joined Jan 2012
Hello,
I recently bought a Bixler plane, and would like to add flaps to the plane. Which servos would be recommended to use?
Hayvosh is offline Find More Posts by Hayvosh
Old Jun 12, 2012, 09:09 AM
DragonFly711 is online now
Find More Posts by DragonFly711
Will try to fly anything.
DragonFly711's Avatar
United States, TX, Athens
Joined Dec 2011
Originally Posted by Hayvosh View Post
Hello,
Doesn't really need flaps. It can almost stop mid air without tip stalling. But if you want to add flaps I'm sure someone on here can give you some tips.
Donnie
DragonFly711 is online now Find More Posts by DragonFly711
Old Jun 12, 2012, 10:26 AM
wic is offline
wic
Find More Posts by wic
wic
Finland, Uusimaa, Porvoo
Joined Apr 2012
I use the HXT900 for my flaps. They have the same size how the Ailerons.
Best regards from finland
Andy
wic is offline Find More Posts by wic
Old Jun 12, 2012, 01:21 PM
R2276B is offline
Joined Feb 2006
Normally I'd agree. Works flawlwessly on mine. I don't use full up btw, and it's variable with throttle position.
YMMV
Old Jun 12, 2012, 02:44 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Good advice. I actually was able to take off from a dirt field without landing gear one time. My SS is covered in colored packing tape and slides nice. I put it on top of a weed and hit full throttle and it slide right down the runway and into the air.
cactus is offline Find More Posts by cactus
Old Jun 12, 2012, 08:24 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
If you use a big enough motor, you can use full up and this thing will go straight up with no problems.
Maddmax is offline Find More Posts by Maddmax
Old Jun 13, 2012, 03:42 AM
PinDuke is offline
Find More Posts by PinDuke
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
Or if the plane is light enough the stock motor with TGS 6x4 will also manage full up elevator on hand launch without stall.
Not that it is needed normally to get airborne but I have actually tried it a couple of times when the "runway" was very short.
PinDuke is offline Find More Posts by PinDuke
Old Jun 13, 2012, 11:58 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Or we could just overpower it with a 1.5-2.0 Thrust to Weight ratio and just point it up like a 3D foamy!
Old Jun 13, 2012, 07:30 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Ah..... nothing some hot water and glue wont fix.
Enter that clip in the aussie FPV thread Landing comp.
Looking forward to seeing what the Bixler2 brings to the table. Sounds like its a while off though.
How does your D8R-II go for range? are you using a patch or amp? and what OSD are you using and can you get RSSI on the OSD?
nogas is offline Find More Posts by nogas
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
