Old Jun 02, 2012, 08:38 PM
Joined May 2012
Another beginner question....does the red antenna coming off the receiver ride inside the fuselage, or should it be routed outside, maybe thru the small hole in the bottom?
Mikeamondo is offline Find More Posts by Mikeamondo
Old Jun 02, 2012, 09:42 PM
United States, NY, Wappingers Falls
Joined Jun 2011
Inside is fine
Maddmax is offline Find More Posts by Maddmax
Old Jun 03, 2012, 07:20 AM
Joined May 2012
I couldn't figure out how to get rubber bands on my hooks without building a stand or bracket, or putting dowels in the sides.... Which i was not ready to do yet. So I went with zip ties.... This makes a semi-permenant wing attachment, which is perfect for me. Most of my flying will be a mile down the road, and i will hang the plane on the wall when not flying... But i can cut the zip ties for longer transport or storage.
Do you guys normally put some packing tape on the bottom to keep the foam in decent shape on landing? Hope to test fly her later today!
Old Jun 03, 2012, 07:46 AM
wic
Finland, Uusimaa, Porvoo
Joined Apr 2012
YES!
Andy
wic is offline Find More Posts by wic
Old Jun 03, 2012, 10:31 AM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Yes. The packing tape not only protects from scuffing on landing it also improves the fuse structure along the dividing lines. For that matter using the tape along the leading edge of the wings will help prevent deep dents from impacts.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 03, 2012, 11:16 AM
Joined May 2012
Excellent.... I think i will pick up some tape today.... Too windy to fly her today anyway.. Thanks for all the help and advice! Since i habe a little more time.... Any advice for not only the maiden flight of this plane, but also my first 3 axis control plane?
Old Jun 03, 2012, 11:51 AM
Eagle202's Avatar
Joined Aug 2011
The plane is pretty easy to fly. Before you fly it under power try to see how it glides by tossing it forward like you were going to fly it. That will tell you if your CG is good. It should glide for a good number of feet and then slide to a landing. If it noses up or down the CG is not correct.
When you are ready to really fly it make sure you have the throttle about 70 to 75% then throw it forward with a little up nose.
Get it up about 60 feet (high enough to recover from a mistake) then you can power back to 50%. Practice making gentle turns. It will nose down due to drag so gently pull back on the elevator to compensate.
Remember it is a glider. If you go into a stall just drop throttle to 0% and let go of the control sticks. It should level out by itself. Then take control again.
Take your time and enjoy. If it crashes it can be fixed.
If you have a buddy then take videos. You will enjoy watching them again or learn from possible mistakes.
Good luck with the maiden.
Vince
Old Jun 03, 2012, 07:16 PM
Will try to fly anything.
DragonFly711's Avatar
United States, TX, Athens
Joined Dec 2011
Hi everyone,
I'm fairly new to the glider scene but have been flying helicopters for several years. I've read about the many ways to hold the wings together such as the rubber bands etc. but I wanted something that was simple and quick to install and remove.
I went with putting a velcro tab on each wing across the spar area and then a matching long piece of velcro to connect the two tabs on each side. Holds perfectly and the wings can be removed in seconds.
I was flying mine for only the 3rd time today, had it up about 500 feet doing loops and rolls and flying upside down. Flew beautifully in about a 10-12 mph wind for 12 minutes on a 3S 2200mah battery. Had plenty of power to go at least another 5 minutes if I had wanted. Only things I've done to the ARF version is install a 30 amp esc, an APC 6 x 4EP prop and a AR600 Spectrum long range receiver. I also put packing tape down the bottom of the fuselage and along the leading edge of the main wings.
Only thing I think it needs is a stronger spar. In a strong breeze the wings will flex quite a bit. I've been thinking that I might take out the spar, fill it full of expanding foam and put it back in there. Has anyone tried that? It wouldn't add much weight to it.
Anyway, enjoyed flying the Bixler very much. No speed demon but plenty of power with the 2200mah batts. Mildly aerobatic too.
Thanks for everyone's advice here in the forums. I haven't posted in this area before but I've read a lot of the posts about the Sky Surfer/Bixler and it helped immensely.
Donnie
DragonFly711 is offline Find More Posts by DragonFly711
Old Jun 03, 2012, 07:52 PM
Eagle202's Avatar
Joined Aug 2011
Originally Posted by DragonFly711 View Post
Hi everyone,
Donnie
Nice build. I haven't heard of anyone using foam to fill the spar. I used a 4mm carbon tube glued inside the 6mm one that came with my SS. Some people add a 3rd 2mm rod inside the 4mm.
I wanted to comment on your stand. It looks very much like the one I built for about $9. It does a great job to hold the plane while I work on it at home or in the field.
This is a good thread for the SS or Bixler that is used for FPV flying. Although you get a lot of good info just about the planes themselves. Glad you checked it out.
Vince
Old Jun 03, 2012, 08:13 PM
United States, CA, Sebastopol
Joined Dec 2010
I left the spar alone and embedded carbon strips into the bottom of the wings, cut in vertically into a slot. After pushing the strips into the slit, I rad a bead of thin CA down the strip to lock it in place. Turned the wings into concrete!
erkq is online now Find More Posts by erkq
Old Jun 03, 2012, 08:38 PM
Joined Dec 2011
Vince
Thanks Vince,
I may give the expanding foam a shot. If it doesn't work, I'll add a stronger spar.
The stand I have is exactly like yours. Picked up the idea on the forum somewhere originally for my Dynam T-28 which is approximately the same size as the Bixler/SS. Use it all the time to work on my bigger planes.
Donnie
Old Jun 03, 2012, 08:39 PM
Joined Dec 2011
That's an idea. May look into that method also.
Donnie
Old Jun 03, 2012, 09:54 PM
USA, CA, San Diego
Joined Apr 2007
Yes - fly the sim first! Make sure you turn on wind - more than you will really encounter, and more erratic. The most useful learning maneuver on a simulator for me is probably a low pass. But just about anything is useful, as long as you have wind and turbulence turned on.
The big problem in RL when new is losing orientation. So put the sim plane far away, look at your GF for 5 to 10 seconds, and then see if you can recover.
Reegor is offline Find More Posts by Reegor
Old Jun 03, 2012, 11:48 PM
Joined Jun 2011
You can also use Gorilla glue along with your spar in the wings. Fill the hole full of glue, insert the spar and work it in and out to fill voids. The glue will expand once it starts drying. Solid as a rock!!!
Old Jun 04, 2012, 06:55 PM
sharonx's Avatar
Here is my best Bixler FPV video :
http://www.youtube.com/watch?v=un9i6SynyMY
sharonx is offline Find More Posts by sharonx
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
