Old May 28, 2012, 07:41 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Originally Posted by nogas View Post
How is everyone securing there bixler pods? I used tape yesterday but it is a bit of a pita.
It came with rubber bands but i am concerned there is a chance they could catch on the ground on landing and i'm not really keen on relying on a rubber band to hold $150 of gear. I've seen people use velcro wrapped around the fuse but i figure it could also snag on the ground on landing.
Anyone got any tips?
Hi Nogas,
Best way to do this without question is: simply buy an after market canopy locking hatch, most are spring loaded. I got mine from HK for a few bucks. Remove enough foam on the top of the fuse and use 5 minute epoxy to glue the hatch in place. Prior to doing this, use sewing machine oil to ensure if any epoxy gets into the hatch it will not glue the spring in. then replace the foam you cut out and draw a dot in the end of the hatch where you think it will touch the pod kit. Let it go and the ink will mark exactly where you need to drill out a small hole and its secured ! This looks professional and ensure no matter how you fly, the pod kit will stay put and swapping out Lipos takes a few seconds ! Heres some pix of mine.
OzparkPilot is offline Find More Posts by OzparkPilot
Old May 28, 2012, 08:13 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Thanks Bing, will look into a hatch latch, it certainly looks nice. Only thing i'd be worried about is if the front end flexes and the pin pulls out. Goodbye pod
That RMRC pod looks pretty flash. How much are they with the pan tilt?
nogas is offline Find More Posts by nogas
Old May 28, 2012, 08:18 PM
Watts up ?
Joined Nov 2006
Keep in mind that this hatch I built is for added security - there are already two rare earth magnets actually holding the pod in and everyone else that uses the Pod has not had an issue I just like the added security and knowing it staying put.
http://www.readymaderc.com/store/ind...roducts_id=548
Old May 28, 2012, 09:28 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
The velcro is the strongest method.
Maddmax is offline Find More Posts by Maddmax
Old May 28, 2012, 09:29 PM
Maddmax is offline
Joined Jun 2011
Here's one I flew today, LOS only.
Hudson River Flying 5-28-12 (5 min 7 sec)
Old May 28, 2012, 09:45 PM
Watts up ?
Joined Nov 2006
Velcro is obviously designed to pull apart - A metal pin in wood can not so im affraid your very wrong. No gold stars for you
Old May 28, 2012, 09:49 PM
Maddmax is offline
Joined Jun 2011
Over engineered a simple solution. Looks like your just a bit anal!!!! If you wrap the velcro completely around the fuselage as i mentioned, it will NEVER come loose. Yours, on the other hand, will be destroyed upon first collision. Then you'll be SOL!!!
Old May 28, 2012, 09:52 PM
Watts up ?
Joined Nov 2006
Each to there own .... I like neat simply relaible systems like mine but if your works for you then great stuff ! ( mine still is cheaper and nicer looking lol )
Old May 28, 2012, 10:02 PM
Maddmax is offline
Joined Jun 2011
Who really cares what it looks like??? You can't see it in the air anyways. Build it for functionality, then worry about your beauty. Becauuse after you crash it, you'll change your tune!!!
Old May 28, 2012, 10:06 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Some people care more about looks then others, I personally go the extra mile to atleast make things look as good as possible, it might not be as good looking as some but it's certainly better looking then a majority .
Personally if I had the time and money I would make a plane you would never even be able to tell it had FPV gear on it :P.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 28, 2012, 10:29 PM
Watts up ?
Joined Nov 2006
could not agree more building planes for me is not just about funtioality, its a challange to make things both look good and work perfectly.
Old May 29, 2012, 12:23 AM
Maddmax is offline
Joined Jun 2011
Don't get me wrong, I like my planes to look good also. You do what you can with what you have available sometimes. That's what makes this hobby so interesting. The limits are really your imagination when building.
Old May 29, 2012, 07:43 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Max
Great video. Really nice and relaxing. I forgot what that part of the country looks like. My grandmother is buried up in White Plains which is a little inland East from the river.
Oh. I also have a soft spot for Celtic music and Riverdance.
Eagle202 is offline Find More Posts by Eagle202
Old May 29, 2012, 07:45 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
That would look like a Kevlar coated B2.
Old May 29, 2012, 08:08 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
It looks good but Wow, thats a lot of dough for some cnc cut ply and 2 $3 servos.
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
