Old May 07, 2012, 12:55 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
@jamesgrid
Glad you got your plane back....and you didn't land in a junk yard with mutant pitbulls
I can't see flying FPV without OSD w/ GPS and RTH.
@turbodriven
Looking a Nova OSD for the price, but do you have any experience with RVOSD (for example) to compare with the more 'expensive' RTH solutions??
idletime is offline Find More Posts by idletime
Old May 07, 2012, 03:53 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
Update on gopro at 1.4kg at stock motor - just doesnt work. two batteries, fpv cam, gopro, etc....too much load. it flies....dont turn sharp - use rudder to keep the tail flying round nearly without ailerons. but it doesnt climb at all. X8 should solve that
rsands2801 is offline Find More Posts by rsands2801
Old May 07, 2012, 04:22 PM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
Originally Posted by idletime View Post
@turbodriven
I don't. There are some complaints about how the Nova OSD RTH operates (or doesn't) in certain weather conditions. I personally have never had an issue. But I'm in sunny Florida. The only issue I deal with is the incorrect mah reading. You get used to it. I've kept a spreadsheet and for me it consistently shows about 1/3 of actual usage on the screen. Know your plane and don't over extend and it shouldn't be that large of an issue. Whenever I reach XX mah I usually head home and fly local for the last 100 or so mah I've calculated to be on my pack. I think for the money it's hard to beat. Even with issues. You can find them new for as low as $110.
turbodriven is offline Find More Posts by turbodriven
Old May 07, 2012, 04:24 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Nova uses IR, which is only good when there is a good contrast between horizon and ground, and ground is fairly flat.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 07, 2012, 04:43 PM
100mph club member
NW O-town
Joined Jun 2005
Which would explain why it works so well for me here in sunny and flat Florida.
Old May 07, 2012, 04:53 PM
Joined Oct 2011
I live in a mountain area, why I chose FY31AP with it's 3 axis gyros, baro, compass, and temp sensor
Old May 07, 2012, 07:15 PM
jamesgid is offline
Find More Posts by jamesgid
Joined Apr 2012
I have seen a lot of your posts while roaming rcgroups. The FY31AP was too expensive for me, so I went with the Dragon OSD v2 with GPS and Baro. Hopefully that will be enough for me. I too live in a mountain area but want to fly in many different locations and could not trust the IR setup on Nova. Will let everyone now how well it works once it is all built and flying. But from what I have read it seems to be a good cost effective RTH setup.....?
jamesgid is offline Find More Posts by jamesgid
Old May 07, 2012, 07:22 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Hey Rsands2801, take one of your batteries out and you'll have no problem. You're trying to lug around too much weight!!! Why 2 batteries??? How big???
Maddmax is offline Find More Posts by Maddmax
Old May 07, 2012, 07:33 PM
Jcome is offline
Find More Posts by Jcome
United States, AZ, Tucson
Joined Dec 2011
First recorded fpv flight
Hi everyone,
This is my first recorded fpv flight. I launched visually, but after that it was all "under the hood," including landing. The plane was definitely nose-heavy, but it was awesome. This is what I'm using:
Sky Surfer
Futaba 9c and corona receiver
Immersionrc 500mw 2.4 vtx
Airwave 2.4 vrx
Fatshark aviators
Stock rubber ducky on both vtx and vrx.
Keychain #16 for hd recording.
Fpv (3 min 29 sec)
Jcome is offline Find More Posts by Jcome
Old May 07, 2012, 07:42 PM
Joined Oct 2011
I can't really speak for the other OSD's. I didn't want Nova because I feared IR just wasn't good enough, I thought about Dragon but I didn't want to extra equipment of a PWM to PPM converter, and same for RVOSD which is what I wanted the most, though in hindsight it seems RVOSD has problems for some.
Price wise I don't think the FY31AP+Hornet OSD is really that expensive in comparison, at least for any unit with baro/compass/gyros.
I have really been keeping myself from pushing it too hard simply because the FY31AP I had onboard at first had broken pots, and I barely had it working right, I just got a replacement from ReadyMade the other day and got it dialed in and did some tests, so once I get a new antenna for my 1 watt amp (2.4Ghz RC), I am going to push some limits .
I am going to try for 10,000 feet altitude, as well as 4km range, my current records are 2780 feet altitude, and 2.24km range , though both of those flights will be done separately.
Old May 07, 2012, 08:12 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Houston, we have lift off. Please don't hit anything up there.
There is another guidance package called RUBY. It ain't cheap but some of the ZII use it.
Eagle202 is offline Find More Posts by Eagle202
Old May 07, 2012, 08:13 PM
Joined Oct 2011
I don't plan to :P Has to wait until I get an antenna anyway, could be a week or two, in the mean time I am stuck to less then 1.5km
Old May 07, 2012, 08:30 PM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
Ha ha, too funny. Stuck at 1.5 km... That is all I need to have a blast scraping the deck.
cactus is offline Find More Posts by cactus
Old May 07, 2012, 10:12 PM
Joined Oct 2011
I dunno why but I find flying lower then 20 meters FPV to be quite scarey.... I keep TRYING to skirt around the marsh path that I fly over, but I always chicken out at 20 meters, did it again today.
Old May 08, 2012, 12:29 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Depends on conditions and plane stability I spose.
Skimming the ground at moderate pace is alright, but add some wind, or if flying fast and it gets a bit wobbly.. better be at least a little crazy lol.
I found it took me a while with the wide view of 2.8mm lens to get used to what altitude im at.
sammyc is offline Find More Posts by sammyc
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 06:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 05:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 10:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 11:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 07:08 AM
