Old Apr 22, 2012, 05:40 AM
FPV ADDICT
Wirewolf903's Avatar
United States, TX, Austin
Joined Jan 2011
Originally Posted by ToxicToast View Post
Got my sky surfer the other day and planning my plan of attack for the build FPV, custom pod, removable wings, UHF dipole on the tail, RHCP 1.2, GoPro/FPV camera.
Big question that I am considering the pros and cons of:
I don't think I can bring myself to seal the fuse. I just know I'll need to tweak the wiring electronics from time to time and if I have to cut it open to get to some of the wiring is likely going to be a problem. I read in another thread about how some people are taping the fuse together. Does this sound like the way to go for assembly?
Chris.
I have both sealed and open fuses and I like the open the best. You can add tape, zip ties, or a combo of both without an issue.
Wirewolf903 is offline Find More Posts by Wirewolf903
Latest blog entry: Wirewolf903 Blog
Old Apr 22, 2012, 02:16 PM
United States, NY, Wappingers Falls
Joined Jun 2011
What kind of setup are you using to fly that far out?
Maddmax is offline Find More Posts by Maddmax
Old Apr 22, 2012, 05:43 PM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by Maddmax View Post
I still have not flown my Z11 yet. Flew my FPV plane yesterday in 20-30mpg gusts. Very challenging!!
Too windy for me yesterday. I did help a friend try out a bungee launcher using his Bixler look alike. We actually got it to launch without the pvc ramp with about 10 lb of tension on the tubing. Pulled it out and up real fast.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 22, 2012, 07:39 PM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I did 2.24km today, a new record for me . Video coming soon.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: New LC Filters by LetsFPV
Old Apr 22, 2012, 08:31 PM
Joined Oct 2011
2.2km Record FPV Flight (4 min 27 sec)
Flight video from today
Old Apr 22, 2012, 11:50 PM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Thanks for the comments, folks. I'm going to try and tape it up once the electronics are installed. Appreciate the info, all.
ToxicToast is offline Find More Posts by ToxicToast
Old Apr 23, 2012, 10:08 AM
Joined Jan 2009
I would like to go through the entire thread to find out some details for the Bixler I´m thinking to buy / build.
Just as a quick question.... What motor / prop suggest me for FPV purposes...
I will go with a Co-pilot (because Ialready have it) for stabilization.
THANKS guys...
JCesar is offline Find More Posts by JCesar
Old Apr 23, 2012, 10:37 AM
cactus's Avatar
Durango Colorado
Joined Sep 2001
THANKS guys...
I'm flying the PNP brushless Sky Surfer from RMRC at 33oz AUW with 3s 2200 lipo and basic FPV gear. Simple voltage OSD, 300mw 1280 tx and 540 OSD camera on the pan tilt pod. APC 6x4 prop. I get 15 mins of mixed throttle flying and it has plenty of power even at my altitude. I am also using a Dynam GY48 gyro on roll.
cactus is offline Find More Posts by cactus
Latest blog entry: FPV mQX
Old Apr 23, 2012, 10:48 AM
San Marcos, CA
Joined Aug 2009
Hey Cactus,
You gotta help me.. I am using the same Gyro (first time user) and wonder how this actual works.. when I tried this weekend, the plane banked always hard to one side and almost killed it... I have it on the rudder ...
Andy
flyandi is offline Find More Posts by flyandi
Old Apr 23, 2012, 10:54 AM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Any reason you have it on the rudder vs roll channel? Sounds like you might have had it in heading hold mode. I have gain control setup on the gear channel and used the ATV to set two positions for the switch. One position is nearly no gain, so the gyro is not actively inputting anything and a second position which gives me about 30% gain in RATE mode (red light will be off). Very important to be able to kill it in flight if something is wrong. Mine did great helping keep the wings level in gusty cross winds.
Old Apr 23, 2012, 10:57 AM
San Marcos, CA
Joined Aug 2009
Ok I guess it was in holding mode which makes sense.. I have it on a switch, too - so how do you switch it to Rate mode?
Old Apr 23, 2012, 11:37 AM
Joined Jan 2009
Any recomendation to buy the motor alone, HK ? etc...
Thanks again
Old Apr 23, 2012, 12:23 PM
San Marcos, CA
Joined Aug 2009
I just purchased this one here: http://www.hobbyking.com/hobbyking/s...dProduct=24239
One left - hurry up!
Old Apr 23, 2012, 12:51 PM
Joined Jan 2009
I like that motor also, but is on backorder..... so bad....
Old Apr 23, 2012, 01:03 PM
Joined Oct 2011
I was hoping my RCTimer 2200kv was going to be here today, but the tracking # is worrying me :P
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
