Old Apr 21, 2012, 05:11 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by guy1a View Post
Either the motor / esc was too hot and stopped. Or the esc cut the motor due to low voltage ...
Neither, I had only been in the air about 4 minutes on a 2700mah battery using a 40a ESC on stock brushless running at about 4 amp draw, it happened when I panned, I think the pan servo caused the voltage sensor to bump into the RX and loosen the throttle connection based on what I observed.
I was uploading the video but my internet screwed up now I cant get on youtube
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 21, 2012, 07:10 PM
Joined Oct 2011
Ok here is the video of the flight today. I actually lost throttle control at close to 1.2km out, and glided all the way to a landing at 203 meters from my location :P. And awesomely the video was good all the way to the ground, and it didn't even go into fail safe until the nose of the plane was about an inch from the ground in 3 foot grass :P. I also landed 2 FEET in front of a barbed wire fence.
FPV Best Distance Record + Emergency Landing! (5 min 25 sec)
Old Apr 21, 2012, 07:41 PM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
That video had horrible interference of some kind. Was all that glitching from your video tx/rx or part of the encoding process while recording it?
turbodriven is offline Find More Posts by turbodriven
Old Apr 21, 2012, 07:48 PM
Joined Oct 2011
My EZCap can't handle the horizontal sync very well, it's quite annoying but only effects the recording, not my live view, however you will notice the farther I get out REAL interference, which is my 1w 2.4Ghz amp on my RC TX, I am still trying to figure out how to solve that problem (other then move the two antennas 30+ feet apart...)
Old Apr 21, 2012, 08:06 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Just shipped them to me and you can start over with a 5.8g video system.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 21, 2012, 08:08 PM
Joined Oct 2011
I like 5.8 for it's clean video but the distance is not that good.
Old Apr 21, 2012, 08:48 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I thought it works for other FPV installs. I guess it depends on where your location is and how far you want to fly from ground zero.
Did you try the low pass filter as someone had suggested?
Old Apr 21, 2012, 08:52 PM
Joined Oct 2011
I need to get one, I am wondering if a low pass filter would work on the vRX to cut out the noise from the 2.4ghz amp being so close? I really should put one on my plane at either rate :P.
I did notice channel 11 on my vRX was a lot cleaner then 15 (which is 1.280Ghz), also on my vRX up in the 20s channels it was perfectly clear, though my vTX can't reach those frequencies :P. Tomorrow I might try channel 11 (1.200Ghz) but I dunno how well that frequency will work on my SPW setup tuned for 1.280Ghz.
Old Apr 21, 2012, 09:10 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I don't know if the 1.2 will be any better since it is a direct harmonic of the 2.4.
Let me know if it works for you.
Old Apr 21, 2012, 09:13 PM
Joined Oct 2011
If tomorrow is good weather I will be flying again :P. I might experiment with channel 11, but I dunno, can anyone confirm what frequency range -/+ a 1.280Ghz SPW can safely work with?
Old Apr 22, 2012, 12:41 AM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Got my sky surfer the other day and planning my plan of attack for the build FPV, custom pod, removable wings, UHF dipole on the tail, RHCP 1.2, GoPro/FPV camera.
Big question that I am considering the pros and cons of:
I don't think I can bring myself to seal the fuse. I just know I'll need to tweak the wiring electronics from time to time and if I have to cut it open to get to some of the wiring is likely going to be a problem. I read in another thread about how some people are taping the fuse together. Does this sound like the way to go for assembly?
Chris.
ToxicToast is offline Find More Posts by ToxicToast
Old Apr 22, 2012, 12:54 AM
Joined Oct 2011
I have mine glued together, and I setup all the electronics to be reachable. I have since moved the AP slightly farther back then in the picture.
Old Apr 22, 2012, 01:19 AM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
Chris.
You can cut an access hatch into the fuse (cut at 45 deg, then tape shut)
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Apr 22, 2012, 03:27 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
Cut a hatch opening under the wing for easy access. When your ready to fly, put the foam cover piece on with a piece of tape.
Maddmax is offline Find More Posts by Maddmax
Old Apr 22, 2012, 03:31 AM
Maddmax is offline
Joined Jun 2011
I still have not flown my Z11 yet. Flew my FPV plane yesterday in 20-30mpg gusts. Very challenging!!
Discussion Sky Surfer or HK Bixler??? fpsazerbaijan Electric Plane Talk 11 Mar 17, 2012 05:43 AM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
Sold Bixler Sky Surfer Hawk Sky ARF or complete kit porcia83 Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2011 09:24 AM
Discussion Review of my Sky Surfer AKA Bixler , Flew Today for the first time. dllhg Electric Plane Talk 19 Aug 10, 2011 10:41 AM
Discussion Propeller recommendations Bixler/ sky surfer sean11 Power Systems 3 Jun 25, 2011 06:08 AM
