Old Nov 04, 2011, 07:48 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Cool
145mm TF8000 development - 17.5kw!!
Guys, I was speaking with Martin on another subject and he brought to my attention the latest exciting developments by JR on the TF8000. JR has been doing testing and Martin should be getting his fan this weekend and asked me to post some information here. Pretty exciting!!
Initial testing is showing upwards of over 17kW but was limited due to cooling of the YGE ESC being used. As you can see in the pics below JR has now upgraded the ESC to a Compro unit.
http://translate.googleusercontent.c...LyNTXDLflUX10A
Of note are the spade type connectors, and the PC cable. Sounds like the software allows a lot of programming flexibility. Can't wait to see additional testing!
strictlyscale is offline Find More Posts by strictlyscale
Old Nov 04, 2011, 07:50 AM
Philadelphia, PA
JR aims to fly the 17KW setup in a new Sportjet named Allegro. It's about 5% larger than the Wild Hornet.
Old Nov 04, 2011, 08:49 AM
EDF Crazy is offline
Find More Posts by EDF Crazy
EDF Crazy's Avatar
UK
Joined Oct 2007
Batteries are the next big hurdle, are they running this on 12s or higher. if on 12s then they going to be in the reign of 380A. you going to need 20,000 mAh for decent flight times. I wonder how much thrust it would produce in the 6-8 kw range.
EDF Crazy is offline Find More Posts by EDF Crazy
Old Nov 04, 2011, 09:10 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Sean, badly I "only" get a TMM 40063, we ordered together
The fan is in development, so it will take some time till there will be a small series production....
Some numbers from the first test with out thrust tube:
12S Setup
41 Volt 310,00 A 12710 Watt 17230 gr. 169,026 N 110,55 m/sec. (efflux is calculated)
14S Setup
48 Volt 365,00 A 17520 Watt 21200 gr. 207,972 N 122,62 m/sec. (efflux is calculated)
Batterie´s must be 12S/14S 2P with ~7600mAh packs or bigger to get flight time.
The sport jet does not need much fullpower with that weight to power so it will fly for the 4-5min.
For the scale jets in the 16kg area there could be ideal version with 14-15S @250A or so. That would be perfect for that job.
I also hope there will be also a version in the 8-10kW area for the Lehner 3060 motors or others.
regards Martin
MaHö is offline Find More Posts by MaHö
Old Nov 04, 2011, 09:15 AM
Philadelphia, PA
Martin, thanks for sharing some of the testing details. I was scared to translate and mess it up.
Old Nov 04, 2011, 09:49 AM
EDF Crazy's Avatar
UK
Joined Oct 2007
Very Impressive, I wonder how many turbine models will have big enough inlets for this thing
Old Nov 04, 2011, 12:17 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
And now it is really time for our next battery generation..
With this Pace of EDF Development, Research and Testings...we really need now a new Generation of Batteries....
380amps...Imagine the weight alone of LIPO Batteries to fly at least a good 5 Minutes??
20000mah, 30000mah?
Plus all this extra weight....jeez...
But the Fan, looks HOT!
NS.
neversommer is offline Find More Posts by neversommer
Old Nov 04, 2011, 03:44 PM
Steve Haynes is offline
Find More Posts by Steve Haynes
There was a crease in the plan
Steve Haynes's Avatar
Joined Jun 2010
That's just plain scary....
Steve Haynes is offline Find More Posts by Steve Haynes
Old Nov 04, 2011, 03:54 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
love the shape of the blades. can't wait to hear the sound. it looks amazing.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 04, 2011, 04:15 PM
twood1 is offline
Find More Posts by twood1
Joined Sep 2011
The BVM f-4 I'm flying with twin evf's 12's carries 2 sets of 6500 mah batts. 10lbs worth of batteries. The planes total weight is about 33lbs with 30 pounds of thrust at full static power. The bvm phantom converted to a single might be a good aircraft for this fan?
twood1 is offline Find More Posts by twood1
Old Nov 04, 2011, 04:19 PM
Luzern/Switzerland
Joined Aug 2008
Dito on the Shape of the Blades.
Pure Seegasm.
NS.
Old Nov 04, 2011, 04:24 PM
Joined Jan 2009
LMAO. nice choice of wording.
Old Nov 04, 2011, 04:40 PM
Luzern/Switzerland
Joined Aug 2008
Cheers Honey
NS.
Old Nov 04, 2011, 04:54 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Man... so much power!
It's the packs that are holding us back.
They will come, all we can do for now is keep the weight, amps down and good throttle managment
Ron101 is offline Find More Posts by Ron101
Old Nov 04, 2011, 04:59 PM
gp125racer is offline
Find More Posts by gp125racer
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
What does the fan unit w/ motor installed weigh??
The ESC is about 1 - 1 1/2 lbs, and a 65c Thunderpower 14s 20000mah setup would come in around 17lbs. That puts the power train at ~20lbs (give or take a few depending upon the weight of the actual fan unit, connectors, etc).
The thrust numbers from those tests are showing the setup as putting out a little over 46lbs of thrust .... that leaves ~26lbs of airframe, landing gear, and electronics to play with and still be at a 1:1 ratio. The 274mph efflux isn't bad either
Cool stuff, can't wait to see one up close!
Don
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Discussion 3.5kw motor for 64mm, 70mm & 80mm Fans Knife Liddle Electric Ducted Fan Jet Talk 71 Oct 31, 2011 08:24 PM
Discussion TF8000 and Big screamer Motor Conversion Littlescreamers Electric Ducted Fan Jet Talk 36 Apr 30, 2010 10:16 AM
Discussion Tf8000 Robert Wagoner Electric Ducted Fan Jet Talk 27 Aug 13, 2009 09:58 PM
Question TF8000 advice Ithacacian1 Electric Ducted Fan Jet Talk 4 Mar 10, 2009 07:11 AM
Discussion Aeronaut Turbo Fan 8000/10 145mm MaHö Electric Ducted Fan Jet Talk 24 Feb 05, 2007 10:33 AM
