Old Nov 04, 2011, 07:37 AM
srk.heli is offline
Find More Posts by srk.heli
United States, PA, Harrisburg
Joined Jul 2010
RC305 5.8Ghz receiver video out/recording problems
I'm having a problem with my RC305 5.8Ghz receiver that came with the hobbyking 5.8ghz 200mw rx/tx set.
During bench testing, I was using a 7" panasonic dvd player that has A/V in to view the video from the RC305. It was working great; the picture and sound were good.
I then wanted a method for recording the video. I first tried an old sony digital8 camcorder. Whenever I connect the cable up to the camcorder and put it into vtr mode, I hear a loud buzzing and the picture is scrambled whenever it makes an appearance on the little LCD on the camcorder (which isn't often, the screen is usually blue). I tested the cable that I used for the camcorder on the a/v out from a satellite dish receiver and the video displayed fine on the camcorder.
After trying different things to get that set up working, I decided to get an easycap. The same thing is happening, I get a picture that looks like an old "scrambled" tv signal. I noticed that if I pull the 3.5mm plug a click out of the RC305, that I get clear picture on the easycap but whenever I record, I get the load buzzing.
Does anyone have any idea what would be causing this? I have attached 2 screen caps of what I see from the easycap when I have the cable fully inserted.
srk.heli is offline Find More Posts by srk.heli
Old Nov 04, 2011, 08:24 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
I don't think we have enough information, but to me it sounds like the rc305 is having an issue on (one?) of the two TV-out paths. Is it the same on both connections?
Try to get a replacement or if this is too tedious, open it up and check the area around the connectors for shorts or bad solder joints.
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 04, 2011, 09:07 AM
srk.heli is offline
Joined Jul 2010
It happens on both of the outputs, but only when I attach equipment other than that 7" panasonic lcd screen.
When I pipe the output to the 7" lcd screen, it works fine. Video and audio is clear when the 3.5mm connectors are seated all the way in.
Old Nov 04, 2011, 09:16 AM
Registered FPVer :)
Joined Aug 2006
Oups, too quick with answering :-). Do you use the same cable with teh 7" lcd and the recording devices?
Old Nov 04, 2011, 09:18 AM
srk.heli is offline
Joined Jul 2010
Originally Posted by markus123456 View Post
Same with BOTH outputs?
Yes, to the point where I have the 7" LCD in one output working fine and a recording device (either the easycap or the digital8 camcorder) in the other doing the buzzing and garbled video. I swap the two at the RC305 and I'm in the same situation.
Old Nov 04, 2011, 09:20 AM
srk.heli is offline
Joined Jul 2010
Yes for connecting the camcorder, but I can't for the easycap. The easy cap has RCA female jacks. The camcorder and 7" LCD have 3.5mm A/V jacks.
Old Nov 07, 2011, 10:21 AM
srk.heli is offline
Joined Jul 2010
I just ended up pulling the 3.5mm cable out of the receiver until I found a sweet spot where the video and audio were displayed well.
Old Dec 02, 2011, 05:20 PM
HexaTech is offline
Find More Posts by HexaTech
Joined Apr 2011
Some 3.5 mm A/V input have a different pinout. Are you sure that you have the right cable ?
I've seen three differents pinouts for 4 pins 3.5mm connectors.
HexaTech is offline Find More Posts by HexaTech
Discussion 5.8GHZ RC305 receiver channels ustas FPV Talk 141 Feb 02, 2016 08:12 AM
Discussion New HD video camera for onboard recording with Live AV out ! oded mazor FPV Talk 6 Nov 09, 2011 12:49 PM
Help! Debugging 200mW 5.8GHz (RC305) Setup metasim FPV Talk 7 Sep 01, 2011 02:03 PM
Discussion 5.8ghz Readymade RC Basic Video signal problems HELP! marzvt FPV Talk 8 Aug 03, 2011 03:02 PM
Discussion GoPro HD live video out recording Stunt Double FPV Talk 7 Mar 16, 2011 06:00 PM
