Old Apr 01, 2012, 12:21 PM
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Originally Posted by EZflyzone View Post
All channels working when I moved the sticks.
how about the polarity of the servo plugs going into the gyro? Signal wire towards the label side...
Dr.M is offline Find More Posts by Dr.M
Old Apr 01, 2012, 12:24 PM
Joined Nov 2010
Originally Posted by Kauaiguy View Post
I did the pro grips as well and it also fixed my problem.When doing the test with main blades off it was easy to move full pitch when spun up to 100 percent.Before with the same test the extreme ends where hard to reach and I could see why the servo was struggling, so the combo works great( new bearings and the weighted pro grip).
Steve
The weighted grips removes that rubber band effect under load. I did the same test as well and noticed a big difference.
ridge_racer is offline Find More Posts by ridge_racer
Old Apr 01, 2012, 12:33 PM
Joined Nov 2010
Dr M....the only confusing thing about the wag that I had is prior to the grips and bearings the tail worked with a cheap Walkera servo but wagged with the Fitec. Only conclusion I came to is that the Walkera is faster (as tested buy the program box)
Old Apr 01, 2012, 12:38 PM
Dr.M's Avatar
Joined May 2011
Those bearings do wear out...
Old Apr 01, 2012, 01:32 PM
Kauai
Joined Jan 2011
Cx program box isn't very reliable to check servo speed, my fast servo's test slow and my exi213 was very fast but not in use.The Walkera servo is for 4.8 volts and it test very fast on 6v, but doesn't have the needed torque so it would have waged slower or not at all as it wasn't fast enough ( under torque)to follow the gyro signal.Just my theory .
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Apr 01, 2012, 02:46 PM
Joined Jan 2011
Ok so I've got the same issue I had last time. This time I put training gear on. Ok so heres what happens. I spool up to about half throttle and no issues. The blades dont flop around or nothing. Then right as its just about to lift off, the erradic behavour starts. The rotor disc just acts like it doesn't know where to go. It tilts right , left , forward, whatever. Just random. Any ideas? I have my gyro set up on beginner and haven't changed any of the other settings.
Edit: FIXED finally. I had my throttle curve wrong so the HS was about 30% lower than what it should have been. Had my middle point at 50 instead of 80
stingeragents is offline Find More Posts by stingeragents
Old Apr 01, 2012, 03:14 PM
Dr.M's Avatar
Joined May 2011
Sounds like WOD caused by too much cyclic gain. Drop the Roll and Pitch gains a few points.
Old Apr 01, 2012, 03:25 PM
Joined Jan 2011
what is WOD? I think the problem is fixed as it lifted straight off with no wobble
Old Apr 01, 2012, 03:52 PM
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
WOD = Wobble of death
Black_heart is offline Find More Posts by Black_heart
Old Apr 01, 2012, 04:30 PM
Joined Nov 2010
I did a quick 3 part video of setting up the gyro using John NZ's software. I will post it in a minute. Hope it even helps one person.
Old Apr 01, 2012, 04:56 PM
Joined Jan 2011
I'll definatelly look at it once you get it posted. About to head out to try and get an actual flight in. And yea I definatelly had the WOD before.
Old Apr 01, 2012, 05:31 PM
Joined Nov 2010
Part 1 CopterX CX-3X1000 PC setup video using an HK450GT (7 min 30 sec)
Part 2 CopterX CX-3X1000 PC setup video using an HK450GT (8 min 18 sec)
Part 3 CopterX CX-3X1000 PC setup video using an HK450GT (12 min 18 sec)
Old Apr 01, 2012, 09:30 PM
Joined Jan 2011
I got a question. What is the lowest you wanna go on the cyclic gain. I had some bad wobbles after I was in the air so I landed and dropped the gain from 40 to 30. Took back off and still had some wobble but not quite as bad but still there.
Old Apr 01, 2012, 10:09 PM
Joined Nov 2010
I have gone as low as 20. Currently for all my helis with analog servos I have it set at 25. If you have decent digital servos, you should be able to run the default 40 setting.
Old Apr 01, 2012, 11:06 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Quick, change the sticker on the CX and make it ZYX, then you can make PitchP a happy man at last!
2Doggs is offline Find More Posts by 2Doggs
Discussion New CopterX CX-1X100 AVCS gyro ehirobo Mini Helis 191 Mar 25, 2013 05:48 AM
Discussion help link X-GYRO 1000 with hitec aurora 9 danmor2 Video Piloting (FPV/RPV) 0 May 23, 2011 02:00 PM
Discussion X-GYRO 1000 question Shift Video Piloting (FPV/RPV) 0 Apr 22, 2011 06:38 AM
Discussion Help setting up my new copterx with a 401 gyro. SteveCH Mini Helis 2 Dec 26, 2007 04:50 PM
